Old 03-05-2018, 09:01 PM #61
boyguan boyguan is offline
boyguan is on a distinguished road
Originally Posted by Xtremluck View Post
After adding 200+ lbs of equipment to the front end it was time to switch to heavier springs. I was maxed out on preload on the driver side Icon coilover and was still 3/4” under my original lift height (23” hub to fender). So out with the old 13” 650lb springs and in with the 14” 700lb springs. A couple of pro tips from the install:
1. You need a wall mounted spring compressor for this
2. Make sure you disconnect your wheel speed sensor wire before trying to extract the coilovers. I toasted the passenger side cable when I stretched it out
Preload Before:
Preload After:
Restored Ride Height:
Any particular reason why you went up an inch for spring?
boyguan is offline   Reply With QuoteReply With Quote
Old 03-06-2018, 09:47 AM #62
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
No particular reason, I believe 700lb coils only come in 14".
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 04-20-2018, 09:26 PM #63
Xtremluck's Avatar
Xtremluck's Avatar
Did a bunch of “upgrades over the last month. First up was new Icon 3” rear springs to support my new rear bumper (Along with 285 Ridge Grapplers)
Stripped the 3rd row and rear bumper waiting to install my CBI dual swing outs
The little rear cubby for the 3rd row equipped 4runners make a perfect place to mount my rear fuse block.
Need to finish my rear bumper install and rear electrical work before Moab in a couple of weeks. Going to be tough!
Old 04-23-2018, 01:16 PM #64
JohnTheLuck JohnTheLuck is offline
Real Name: Jean
JohnTheLuck is a name known to all JohnTheLuck is a name known to all JohnTheLuck is a name known to all JohnTheLuck is a name known to all JohnTheLuck is a name known to all JohnTheLuck is a name known to all
Real Name: Jean
Rotopax mounting on roof rack
I am about to order two 3 gallons fuel packs like yours. I just can't find if any of the mounting hardware parts are required, apart from anchors.
Could you tell me how you mounted them on your rack?
What is the use of the universal mounting plate?
Thanks!
2016 Trail Edition Classic Silver Metallic with KDSS, sunroof
ToyTec BOSS lift, SPC Light Racing UCA, RCI sliders, RCI aluminum full skids, RCI Cat Guard, Eezi-Awn K9 2.2m, BFG KO2 275/70R17E, FN Wheels f(X) Pro, ARB Breather kit, Husky WeatherBeater Mat and Cargo, XPEL window tint, 3M wrapped hood
Build thread
Adventures thread
JohnTheLuck is offline   Reply With QuoteReply With Quote
Old 04-24-2018, 08:59 AM #65
Xtremluck's Avatar
Xtremluck's Avatar
Thanks!
Hi Jean,
So the (2) 3.5 Gal Fuelpax are mounted using these: https://rotopax.com/fuelpax-dlx-pack-mounts-clone-.html
and the one 3 Gallon Rotopax is mounted using this: https://rotopax.com/dlx-pack-mount.html?category_id=7
All are bolted through the mesh flooring on the Gobi Rack. Hope that helps!
Old 05-02-2018, 08:56 AM #66
Xtremluck's Avatar
Xtremluck's Avatar
Slowly making progress on the rear setup. Have two more working nights to finish before a week long trip to Moab!
CBI Rear Bumper Installed:
@Magnetic4R made a fantastic plate for me after I did my 3rd row delete:
Installed L-track with cargo tie downs and 65L Dometic fridge:
Rear fuse block hidden under the 2nd row seat + constant on rear power to my house battery:
Old 05-24-2018, 09:36 AM #67
jetranger jetranger is offline
jetranger is on a distinguished road
Thanks for posting the information regarding the facelift headlights and 14+ bumper! We have a 2011 Limited and I don't really like the bumper options for it. Other than the headlights and center upper grill, was there anything else you needed to modify or buy to make the newer aftermarket bumper work?
Thanks again
1976 UZJ40 Build Thread
jetranger is offline   Reply With QuoteReply With Quote
Old 05-24-2018, 05:20 PM #68
Xtremluck's Avatar
Xtremluck's Avatar
Thanks again
That is it! There is a upper support piece that I didn't buy that would be a good idea to get. It's #17 in the attached diagram. It will help solidify the mounting points for the headlights and upper grill. Im not running it right now and my headlights vibrate pretty badly on really rough roads/trails. Will eventually get it.
A couple of additional things:
•As mentioned somewhere else you will need to add some slack to the passenger side headlight wiring harness. I did this by cutting away some of the loom/electrical tape. It will be a tight fit but it will work!
•The side marker bulb holder in the headlights will need to be trimmed down a bit to fit the newer style headlight. Not a big deal (I used a dremel).
•There is a center sheetmetal piece that the pre-`13 bumper used to hang off of. You can safely remove it.
Let us know how it goes!
Old 05-24-2018, 05:21 PM #69
Xtremluck's Avatar
Xtremluck's Avatar
Forgot the diagram!
Xtremluck's 2012 SR5 Build Thread-4runner-gif
Old 05-24-2018, 05:41 PM #70
MemBrain MemBrain is offline
MemBrain is on a distinguished road
Forgot the diagram!
which part on the diagram is the upper grill piece needed for this conversion? or is there another diagrams showing it? thanks
2010 SR5 4x4 Blizzard Pearl, Metal Tech sliders, Bilstein 6112(HD)/TRD5160 + OME UCA + rear coils, ATX AX202 Bronze 17x9 (-12 offset), Cooper Evolution MT 285/70-17 + spare, TMT Skyline full roof rack w/ led light bars, Stubby antenna, Late 5th gen tail lights, C4 Hatch ladder, Full LED low/high/fog, ditch lights, TuffStuff Alpha RTT, Waterport. @blzrdt4r
www.beyondthelensstudios.com @beyondthelens_
www.mrbeardbutler.com @mrbeardbutler
MemBrain is offline   Reply With QuoteReply With Quote
Old 05-24-2018, 05:44 PM #71
Xtremluck's Avatar
Xtremluck's Avatar
Here you go: https://parts.camelbacktoyota.com/pa...&siteid=214329
Old 05-24-2018, 05:53 PM #72
Xtremluck's Avatar
Xtremluck's Avatar
Thanks again
I just read your other thread. One thing to warn you about, the 14+ projectors retrofitted with HID bulbs have worse output than the `10-13` halogen headlights w/upgraded halogen bulbs. The projectors are absolute garbage when it comes to light output even when you upgrade the light source. You will need to retrofit a better performing projector even on the newer style headlights for any meaningful output upgrade.
I have diagnosed night vision blindness so im pretty sensitive to light levels. Sometimes I wish I could have my old headlights back :P
Old 05-24-2018, 06:05 PM #73
Thanks but is this the top grill piece you're talking about? https://www.oempartworld.com/oem-par...YT10b3lvdGE%3D
Old 09-16-2018, 06:24 PM #74
Xtremluck's Avatar
Xtremluck's Avatar
So after several trips with the new rear bumper, fridge and equipment setup. It became clear to me that for times when I have 3+ days worth of food, water and fuel my weight really started to make the rear end sit a little low with my Icon 3” Overland springs. Decided to step up to Old Man Emu’s extra heavy 2899 3” springs.
Swapping them out was a breeze since they are much shorter than the Icon dual rate springs. Now sitting at what I feel is a perfect rake. Sorry I’m not one of those “level bros”.
Ride height measurements hub to fender:
Driver front 23.7”
Driver rear 25.25”
Pass front 23.6”
Pass rear 25.25”
(Gained an inch of ride height over the icons)
Going to be interesting to see how it does this upcoming weekend. Taking 4 humans on an off grid trip for three days. So will be considerably weighed down.
Current stance:
Old 09-16-2018, 10:07 PM #75
JKRunner's Avatar
JKRunner JKRunner is offline
JKRunner is on a distinguished road
JKRunner's Avatar
Awesome
Great Build Thread. I just picked up a 2018 SR5 Premium and the modding has just begun. I am a fellow MTB in South OC and would like to build a truck similar to yours.
Keep the mods and updates coming.
JKRunner is offline   Reply With QuoteReply With Quote
Vegas: 2012 Trail build thread Vegas 5th gen T4Rs 157 12-13-2018 08:56 PM
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
