01-23-2016, 02:52 PM
Stranded - Alternator Problem
I'm driving across NC, playing in the snow, and my electrical system started cutting out. Found an open NTB, they said my alternator has died. 120k miles. No available part until Tuesday. Has anyone else run into this? Could it be a connection issue? Any help would be appreciated!
01-23-2016, 04:09 PM
Real Name: Chris
Real Name: Chris
I doubt its a dead alternator if the electrical is cutting out. If it was the alternator, the battery would continue to run everything until it ran out of juice, which should be about 20-60 minutes (my guess on this, considering the amount of electronic stuff our 4runners have), depending on what battery you have and what you were using electrically during that time.
How exactly was it cutting out? Engine only? Lights? Dash? Everything at once?
Did it just cut out and not come back on again? Or, were you able to re-start it and continue on?
I bet its a loose connection somewhere, but will wait for a bit more info from you to really say. I know this has been covered before, but have no clue what thread it was.
2011 4 Runner (my daily driver)
1987 Xtra Cab (35's and locked front/rear, the trail toy!)
1985 Supra (430rwhp track toy!)
2006 Honduh Odyssey (the wife's van)
01-23-2016, 04:22 PM
Real Name: Kevin
Real Name: Kevin
It could appear to be cutting out, if the battery got to the ragged edge stuff would start flickering and dropping out one by one. Happened to me earlier this winter, ruined a trip into Capital Reef.
OP, do you have access to a multimeter? If you can get the truck jumpstarted and running even for a second, measure your voltage between the charge stud on the alternator and the negative stud on the battery. If that stays a solid 14ish volts, your alternator is probably good and you can look for a connection issue.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
01-23-2016, 04:23 PM
Lights, dash, blower fan, aftermarket GPS and radar detector, windshield wipers. They all cut off, but the engine never died.
They would fade out if a new load was added, but would come back on.
01-23-2016, 04:24 PM
I have a multimeter. I'll see if it starts, check that, and report back.
01-23-2016, 05:27 PM
I'm getting 13.9v at idle. Seems like nothing is wrong with the alternator. What else should I check?
01-23-2016, 07:12 PM
Real Name: Jeff
Real Name: Jeff
Battery connectons. If you can move them at all they are loose.
HERE FISHY FISHY FISHY!
01-23-2016, 08:46 PM
Bad ECU? I believe that the dash etc runs on a separate one from the engine ECU. When you started the truck and measured 13.9v, did the cluster light up normally?
Check the battery connections and the battery quality /charge first.
Okki
Okki's Build Thread - 2010 Limited: Shrockworks Rock Rails & Full Skids, Gobi Rack, OPT7 LED Roof LIGHT Bar, Rigid E-Series Bumper Light Bar, Hella Horns, Auxiliary Fuse Box, Cobra ST75, TRD Rims, Discoverer ATP LT265/70R17, Rotopax, ARB Twin Compressor, Cargo Area Pressure Gauge and Chuck, Icon billet trailing- and A-arms, Dobinsons Shocks/Coils, Fumuto Oil Valve, Northstar Group 31M, CBI Front & Rear Bumpers !!!
Any time...Anywhere.. My cat can take you.
01-23-2016, 09:14 PM
How old is your battery?
01-23-2016, 10:32 PM
This. Check your battery. You likely have a bad cell.
01-24-2016, 12:41 AM
Battery check was okay. Battery was in great shape. It's only a couple years old and no prior issues. I'll check the connections and see. I don't recall any play in the terminal connections.
01-24-2016, 08:37 AM
Battery
Muddy, when my 2010 limited electrical started acting up, 4 wheel drive stuck in low while driving in high in a parking garage, 120,000 miles and 6 mo. old battery, I had a corroded positive battery terminal which is replaceable. No problems since. My opinion is all electrical items must be maintained correctly. BG
01-24-2016, 09:07 AM
Thanks BGunn. I'll check my battery terminals. Are there any other electrical connections that can come loose?
01-24-2016, 10:15 AM
Real Name: Kevin
Real Name: Kevin
Your battery terminals are just one side of a connection, check the other side of the cables too. I don't know what all you've got under the hood of a 5th gen, but at a minimum you'll have a heavy gauge ground cable between the negative terminal and the motor (or to the fender, and then the motor), and a heavy gauge power wire between the positive stud on the battery and the alternator charge post, and at least one lighter gauge power wire between the positive stud on the battery and the fuse box or boxes. Check them all, clean the connections really well.
