Old 01-26-2016, 11:47 AM #1
brian0128's Avatar
brian0128 brian0128 is offline
brian0128 is on a distinguished road
brian0128's Avatar
Clicking/tapping/rattle sound in passenger floorboard area.
I have a 2015 TEP with 15k miles on it. I have a rattle/vibration noise in the passenger floorboard area that is driving me nuts and I can't locate it. Anyone else had this issue?
It happens when the truck gets to a certain RPM. I've located it around 800rpm(truck in drive, foot on brake) and around 1800rpm(driving in 5th gear smooth flat road). It sounds like plastic on plastic so I started by removing my Weathertech floormats and removing everything from the glove compartment. That didn't make a difference. Turning the AC/heat blower motor up to a higher speed sometimes makes the sound stop. It does it with the fan on or off. I've had passengers try putting their hands around door panels, glove compartment door and even the underside but nobody can find it. I took a video but it's hard to hear. I'll see if I can get a better one today. It sounds like it's coming from under the dash itself but it's hard to determine. It is coming from inside the vehicle and sounds like 2 pieces of plastic tapping against each other.
2015 Trail Premium Super White
2018 TRD PRO Super White
brian0128 is offline   Reply With QuoteReply With Quote
Old 01-26-2016, 02:43 PM #2
Hook 'Em Horns!'s Avatar
Hook 'Em Horns! Hook 'Em Horns! is offline
Real Name: Jack Bauer
Hook 'Em Horns! is on a distinguished road
I have this issue as well. It's definitely coming from under the glove box near the compressor/fan thing you can feel when you reach underneath the dash. It started out every once in a while, but has progressed to rattling when truck is idling at stop lights.
I would expect this from a Ford, but a Toyota!??
I've decided to get some foam padding and cut into small wedges, and then place them in between anything I can feel under the dash that could be tapping/making contact while engine is running.
\m/
Hook 'Em Horns! is offline   Reply With QuoteReply With Quote
Old 01-26-2016, 03:35 PM #3
APM APM is offline
APM is on a distinguished road
APM APM is offline
I had a problem with a slight tapping/clicking noise coming from the passenger side as well. Mine was more around the mid to upper dash area. I found that I was able to stop the noise by wiping my hand over the passenger dash speaker with some reasonable pressure. Not sure if this is going to fix your problem, but it solved mine. I don't know if it was a static issue causing feedback from the speaker or if the speaker itself was loose.
APM is offline   Reply With QuoteReply With Quote
Old 01-26-2016, 03:47 PM #4
flyinhawaiian01's Avatar
flyinhawaiian01 flyinhawaiian01 is offline
Real Name: Chris
flyinhawaiian01 will become famous soon enough
Real Name: Chris
Just a shot in the dark, but do any of your vehicles have the manual 4wd shift lever and not the knob?
If so, do you have anything sitting in that shift gaiter? Once in a while, I put my shades in there, and it rattles at certain rpms, sounds like it is coming from the footwell area, as soon as I move whatever's sitting in there, noise is completely gone.
Try this next time you hear it, push forward on the 4wd shifter, see if it goes away. Don't pull it down into 4wd, just push towards the dash to make it stop vibrating.
2011 4 Runner (my daily driver)
1987 Xtra Cab (35's and locked front/rear, the trail toy!)
1985 Supra (430rwhp track toy!)
2006 Honduh Odyssey (the wife's van)
flyinhawaiian01 is offline   Reply With QuoteReply With Quote
Old 01-26-2016, 03:49 PM #5
ST1FLER ST1FLER is offline
Banned
ST1FLER is on a distinguished road
Banned
I had this on my 2015. Ended up being the plastic piece of the lower dash under the glove box vibrating against the metal support. Slapped a piece of 3M foam tape behind it and viola.... drove me crazy trying to figure it out
ST1FLER is offline   Reply With QuoteReply With Quote
Old 01-26-2016, 03:49 PM #6
JerseyMike's Avatar
JerseyMike JerseyMike is offline
JerseyMike is on a distinguished road
JerseyMike's Avatar
Check the fasteners in the wheel well too.
dreaded dash rattle - omg going insane
2012 TE w/ KDSS.
Icon 2.5 CDCVs w/ Dual Rate Rear Springs; Delta Joint UCAs/Total Chaos LCAs; BFG K02 285/70/17 on ATX Crawl; Safari Snorkel; Budbuilt Sliders & RCI Skids; GooseGear plate system, Packasport 115 & Yakima Spare Time to carry the toys; CBI Rear & Front w/Smittybilt 10k; loud speakers; and a bunch of bright lights
JerseyMike is offline   Reply With QuoteReply With Quote
Old 01-26-2016, 03:52 PM #7
JohnPips JohnPips is offline
JohnPips is on a distinguished road
I had this same problem from the day I took delivery. At first I thought that it was the plastic cover that hides the blower motor. Ended up taking to dealer and was able to get the service manager to hear the noise. He looked underneath the dash after taking off the cover, and he ended up moving some wiring harnesses around. It's been 3 months and over 3K miles and no rattling, but still keeping my fingers crossed
2015 Trail Premium
2004 SR5 (gave to dad)
JohnPips is offline   Reply With QuoteReply With Quote
Old 01-26-2016, 03:56 PM #8
philsey's Avatar
philsey philsey is offline
Real Name: Um, Phil?
philsey has a spectacular aura about philsey has a spectacular aura about
philsey's Avatar
There's a noise thread on here somewhere that ended up being a wire loom or a tie wrap in the console - like behind the HVAC controls. More than one person had it. Had good pics too.
Maybe someone remembers ....
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
philsey is offline   Reply With QuoteReply With Quote
Old 01-26-2016, 04:17 PM #9
adam2562's Avatar
adam2562 adam2562 is offline
adam2562 is on a distinguished road
adam2562's Avatar
check to see if it doesn't it when your blower motor is on.. mine chirps.. i take the filter out and put a dab of lube on the center nut
2011 TE KDSS NAV- K&N drop-in, Toytec/Eibach, Bilstein 5100's, Diff Drop, 295 Cooper STT Pro, OPOR Sliders, 17X9 XD Addicts, Sonoran Steel Panhard Bar, SPC UCA, RCI Skids
'97 Corolla, 90 Alltrac Celica, 94 Camry, 99 Solara 5spd, 98 GS400, 93 Accord, 97 Avalon(current daily), 2010 T4R LE sold, 2011 T4R TE
adam2562 is offline   Reply With QuoteReply With Quote
Old 01-26-2016, 04:46 PM #10
brian0128's Avatar
brian0128's Avatar
I did narrow it down to not being the speakers. That was the first place I looked.
This is what I thought it was at first when it was intermittent but then I drove around with my hand on the shifter and it still did it.
This sounds helpful. Does the plastic piece unscrew or snap out?
I will check this today. I missed this thread in the past.
I will be securing the harnesses when I pull off the cover to put 3M tape on it.
I'll check this while I'm at it.
Old 01-26-2016, 05:41 PM #11
Awesome, thanks for the insight. I believe this is the exact location & sound I am experiencing, and will try this once I get to the casa.
\m/
Old 08-10-2017, 01:29 PM #12
cmilviper's Avatar
cmilviper cmilviper is offline
cmilviper is just really nice cmilviper is just really nice cmilviper is just really nice cmilviper is just really nice
cmilviper's Avatar
Did anyone ever solve this rattle, and what to do exactly to fix it? What was stated above describes the noise to a T.
If I press on the compressor type assembly right above the rear part of the floor mat area, the noise stops. I've tried to wedge pieces of weather stripping ect. in different areas, but the noise continues....
The quote below from another member above, also describes the rattle/vibration noise very well:
"I have this issue as well. It's definitely coming from under the glove box near the compressor/fan thing you can feel when you reach underneath the dash. It started out every once in a while, but has progressed to rattling when truck is idling at stop lights.
I've decided to get some foam padding and cut into small wedges, and then place them in between anything I can feel under the dash that could be tapping/making contact while engine is running."
2017 4Runner TRD Pro - Cement Icon RR CDCV (700 lb) w/ Icon Delta Joint UCA's/Billet Rear Link Arms || Icon Overland 3'' Rear Springs+Dobinson's 15mm spacers on top || C4 Fab Sliders || CBI Front Bumper || Shrockworks Rear Bumper || Gobi Stealth Rack/Ladder || Baja Designs & Rigid Lighting || 285/75r17 Toyo MT's (34") || Safari Snorkel || ARB Diff. Breather Kit || Spidertrax || ARB Awning 2000 || Maxtrax || XD Philips 4300K HID's || Warn Winch/Factor 55 || IKamper Skycamp 2.0 4X || SCS Ray10's || Durobumps
2015 4Runner TRD Pro - Super White (Wife's) Icon Stage 2 w/ Icon UCA's || Toytec Superflex HD Rear Springs || Expedition One Sliders || 285/70r17 BFG KO2's || Gobi Stealth Rack/Ladder || 40" Rigid Radiance || Spidertrax || XD Philips 4300K HID's || Philips Yellow LED Fogs
cmilviper is offline   Reply With QuoteReply With Quote
Old 08-10-2017, 07:21 PM #13
cmilviper's Avatar
cmilviper's Avatar
Anyone? (See above post)
Passenger floorboard wet IrmoRabbidMoose 3rd gen T4Rs 19 06-16-2020 02:55 AM
Popping/Clicking sound coming from lumbar area of drivers seat when I accelerating. bigwebb83 4th Gen T4Rs 20 06-17-2013 09:39 PM
LOUD rattle under passenger seat or from door area Rob_G 5th gen T4Rs 5 11-12-2012 04:56 PM
rattle on the floorboard ozana 3rd gen T4Rs 0 02-04-2009 05:14 PM
Rattle Noise On Passenger Door Latch Area SE6R Problems & Warranty Issues 4 12-16-2004 03:01 AM
