01-28-2016, 01:35 PM
Recommendations on sliders with steps
I have been searching through the forums looking for an answer, but cant find exactly what I'm looking for...
I'm looking for recommendations on sliders that are good steps as well. I have two young boys and the climb into the T4R is a bit much. I want to get some steps for my '16 TEP w/ KDSS to make it easier for them to get in and out. I was going to get some N-Fabs, but I figured why not go big and get sliders. I just want some that are good for use as steps as well.
I'm leaning towards Schrockworks or BudBuilt. But before I lay down the big coin, I want to make sure I'm getting exactly what I need.
Thanks for any help!
2016 4Runner Trail Premium...Delivered 1/22/2016. Mods: OME Lift, Husky WeatherBeaters, Interior/Exterior LED, Console Vault, AVS Hood and Side Window Deflectors, 275/70/17 BFG KO2, Rigid Dually SAE fog lights, Rigid 20" E2 Hyperspot, Garmin Dash Cam 55, ToyTec HIDs, Aiden James Saber Pro LED high-beam bulbs.
01-28-2016, 02:04 PM
For the life of me, I cant see the value of nfab on a vehicle which goes offroad. Why would you want two big hooks hanging off each side. They are the dumbest design around imho.
01-28-2016, 02:13 PM
Real Name: Adam
Real Name: Adam
My wife and kids love the shrockworks. Angle is perfect for both acting as a step and body protection.
They are solid. My KDSS lines were easy to get around. Drilling for the one hole that needs it was simple on the passenger front. Just make sure you have a near empty gas tank and you can probably do the install yourself.
Edit: My sliders only took 6 weeks or so, including the holidays, to arrive.
2016 TE Premium w/KDSS, Classic Silver, TRD bits, 275/70R17 BFG KO2, Shrockworks sliders, Rigid fogs, Front Runner rack, XenonDepot HIDs
01-28-2016, 02:17 PM
Check out C4 Fabrication. I just ordered a set of their rock sliders with steps. Ordered last week and just shipped yesterday. Super fast turn around time and awesome to deal with.
2014+ 4Runner Rock Sliders | C4 Fabrication
2015 Toyota 4Runner TRD Pro Inferno Build Thread Here | 2016 Audi S6 Sepang Blue Build Thread Here | IG: Chudiddy_S6
01-28-2016, 02:19 PM
Real Name: Dave
Real Name: Dave
Demello sliders
I just installed Demello bolt-on Hybrid Sliders yesterday. The rock rails make a fine step. The also have the X-wing style which has a larger functional step that also serves as a bump-out.
No pic's yet but I will be posting them soon.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
01-28-2016, 02:25 PM
Real Name: Spence
Real Name: Spence
I love my shrockworks sliders.
2015 Turd Pro 4Runner - Shrockwork Sliders - Grill LED Bar - 2" lift - 285 70 17 Cooper ST Maxx - Bajarack Utility Flat Rack - ARB 2000 Awning
01-28-2016, 02:32 PM
I'm in a similar situation, a 6- and 10-yr old and a somewhat short wife. I currently have to remove the running boards and trim if I want to go off-road, then put them back on again before my wife and kids start complaining. It's a huge pain. Unless something better comes along, I will get flat Shrockworks sliders w/ plates or else C4 with steps this year to replace my OEM running boards. The Shrockworks provide a more ample and lower step, while the C4's provide better leaning ground clearance with the tradeoff of a much higher step.
I don't know of any other sliders that are available with flat steps standard, but I'm sure at least a few of the manufacturers in this thread would entertain a custom build.
As sf said, if you have any plans to go offroad, don't do non-structural boards. They will hang up on anything and everything and may damage your truck. I have a slightly bent rocker panel because one of my OEM running board brackets slammed into a rock back before I figured out that the bolts holding them on could be removed
2011 SR5 4WD, Maroon, no 3rd row, no sliding cargo tray.
ARB Bumper/Bullbar; Southern Style Offroad Sliders; Budbuilt Gastank Skid
OME Nitrocharger Sport Suspension (884 front, 895E rear); Gen Grabber ATX 275/70R/17
Not to be this guy, but I'm gonna be this guy since I've been looking at sliders with kids / step needs in mind too. If you haven't fully checked out the consolidated slider infor thread, it's awesome:
Consolidated Slider Info Thread
The mfr links are included on most of them with pictures as well as people on the forum who are running them. One thing that is definitely part of my considerations that wasn't before I started reading the thread is added weight, too...
01-28-2016, 02:36 PM
Real Name: Halko
Real Name: Halko
Go Shrockworks OP, you won't be disappointed. (Other than the stupid wait time, if you aren't in a rush, wait for a group buy)
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
01-28-2016, 03:21 PM
Why are the sliders different for the 2014+? I didn't realize they made changes to that portion of the vehicle, different rocker?
01-28-2016, 03:48 PM
wish i could see more of these in person to see how far out they sat. took the running boards off of my Trail because they were more of an inconvenience getting in and out for my wife and it. all they ended up being were a way to transfer dirt to the back of our pants (or dress, in her case). i'd like to get something that would be a little closer to the body of the vehicle, but still have a bump out for the boys (8 and 11). probably end up with SW, since they're based in Houston.
cool story, huh?
01-28-2016, 04:58 PM
cool story, huh?
The typical 2 tube angled sliders are the marquee set up. Steps and such just get hung up. They will be closer into the vehicle then the running boards, however picking up road debris and mud on your pants legs still happens. You can get sliders that are close to the body, which is something I used to do, but they dont provide the upper body protection like for doors and fenders that the 2 tube sliders do nor do as a good a job pivoting on boulders.
01-28-2016, 06:19 PM
I have Pelfreybilt sliders with kick-out and top plates. Works fine for the wife, the 6yo and the 3yo.
01-28-2016, 06:48 PM
The SR5 went from the low-hanging Limited style trim to the higher clearance Trail-style trim. If you have a 2010-2013 SR5 you have to order lower sliders (if available), remove the trim and run bare (leaves a unsightly unfinished edge, IMO), cut your trim so the higher sliders will fit, or replace it with the Trail trim (very pricey).
I'm not aware of any rocker trim changes to the Limited or Trail models.
The front bumper had a huge makeover in 2014.
Didn't know these existed... Add them to the list of flat-oriented sliders that can be used as practical steps.
Yes, I'm aware that putting the outer tubes higher and closer to the body will improve ground clearance, but mine is a DD driven by the wife. She needs good steps. I really like the look of the C4's as an awesome compromise, but I'm just afraid the step will be too high with a lift.
01-28-2016, 08:11 PM
I'm in a similar situation for my wife, but will run some trails. I have been looking at the Hefty Fabworks sliders made in Colorado Springs.
2010-2015 4runner rock sliders Hefty Fabworks
