Old 01-28-2016, 09:24 PM #1
WBechiom WBechiom is offline
WBechiom is on a distinguished road
Help with direct wiring a CB.
Hey gang. I recently installed a CB in my passenger foot well area. I chose the spot because it's relatively out of the way and I can still put the passenger seat fully forward when I'm sleeping in the cargo area.
My first try was to splice the power and ground to a cigarette light adapter and plug it into the rear of the center console, running the wire between the console and seat. This works for power, however when I turn the fan up now in the cabin, I'm getting a ton of noise being generated, I can literally watch my Rx level go up as I turn the fan speed up.
I'm thinking it might be because I have the power running right next to the coax for the antenna. So this brings me to my question. I'd like to tap into switched power somewhere around the rear of the CB and run ground to chassis. Does anyone have any idea of where I should start looking for a good source? I was thinking I could run the wire up behind the glove compartment, but I don't know where to install a vampire tap, or if that's even the best option.
Thanks in advance.
2015 Superwhite TEP, 275/70/17 BFG KO2s, Viper 5806V, Baja Full Length Utility Rack, Rigid D2 Drivers and Hyperspots
WBechiom is offline   Reply With QuoteReply With Quote
Old 01-28-2016, 10:40 PM #2
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about
I went directly to the battery. Best place to tie into for 12v live outlet
Maybe your CB is different but mine always goes back to channel 9 when the power is turned off and I would sometimes forget to put it back on the station we are using.
03_4x4Runner is offline   Reply With QuoteReply With Quote
Re-direct advertisement? characterzero 5th gen T4Rs 1 09-04-2012 10:27 PM
Magnaflow Direct-fit Cat for 2nd gen battleax619 Classic T4Rs 4 02-18-2011 11:41 PM
Can someone direct me to the thermostat spahrster Classic T4Rs 1 11-28-2007 04:55 PM
Cars Direct alaskaman 4th Gen T4Rs 3 06-17-2007 02:29 PM
Can I please direct you..... Expat 4th Gen T4Rs 0 06-15-2004 08:51 AM
