Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 02-01-2016, 12:20 PM #1
Titanpat57's Avatar
Titanpat57 Titanpat57 is offline
Senior Member
Real Name: Patrick
Titanpat57 is a jewel in the rough Titanpat57 is a jewel in the rough Titanpat57 is a jewel in the rough
Senior Member
Titanpat57's Avatar
Real Name: Patrick
Cool The 2016 ROAM 4Runner Build
Hey All,
ROAM = Recreation Optimized All terrain Module. I've decided to carry over my trailer name to the truck as well...it's just the life style I'm living...
I never documented my first build (2010 Silver Trail) so instead of listening to @Antman whine for the next six years...it'll probably be easier to document it...plus my mods are way cooler then his.
The second 4Runner is a 2016 TEP, no KDSS again, on purpose. Got white instead of silver. A few things I miss are the more utilitarian interior of the first truck, now this one is a bit more refined...not my style really..
and one with old 4Runner
First mod out of the gate was BFG KO2 275/70/17's E rated, installed at the dealer before pick up. Love them so far.
Next up was tinted front windows, 35% to match the rears, and Lam X fogs.
As she sits....
Some things on the burner..
- electrical upgrades
- North Star Group 31 battery up grade
--aluminum roof rack with integrated solar and light bar, my own design
- OME BP-51 upgrade
- New ARB front bumper and winch
- RCI aluminum skids
- Rocky Road slider / steps, using black OEM running board covers
- Custom drawers, a bit deeper and 6" longer then the last set.
These are the major ticket items....I know there will be smaller goodies along the way...let the mods begin!
__________________
White 2016 TEP .....My ROAM Truck Build....... My ROAM trailer Build
Titanpat57 is offline   Reply With QuoteReply With Quote
Old 02-01-2016, 12:44 PM #2
Titanpat57's Avatar
Senior Member
Real Name: Patrick
Senior Member
Titanpat57's Avatar
Real Name: Patrick
Next up was a 12 circuit panel in the jack area located at the rear of the truck.
I ran a 6 gauge wire from the engine bay, to the rear, hooked to a 100 amp Buss circuit breaker located under the hood.
I also added 12v outlets and USB's on both sides. The 12v sockets are all run with #12, and will power fridges, or what ever.
I also added a NoCo charging port, that will eventually tie into the solar on the roof. It has a neat little blinking light that indicates percent of charge in the battery. I also added a voltmeter to display the battery voltage.
__________________
Old 02-01-2016, 12:45 PM #3
phillyd2's Avatar
phillyd2 phillyd2 is offline
Senior Member
Real Name: Dave
phillyd2 is a jewel in the rough phillyd2 is a jewel in the rough phillyd2 is a jewel in the rough phillyd2 is a jewel in the rough
Senior Member
phillyd2's Avatar
Real Name: Dave
Quote:
Yeah, good luck with that
__________________
Them Be Me Mods - 2011 Black Limited / Trail Mutt
phillyd2 is offline   Reply With QuoteReply With Quote
Old 02-01-2016, 01:02 PM #4
Osmith Osmith is offline
Member
Osmith is on a distinguished road
Member
Nice! I'm excited to see the solar powered light setup!
Osmith is offline   Reply With QuoteReply With Quote
Old 02-01-2016, 01:30 PM #5
weeeee's Avatar
weeeee weeeee is offline
Senior Member
weeeee will become famous soon enough
Senior Member
weeeee's Avatar
__________________
IG @go.xplre
weeeee is offline   Reply With QuoteReply With Quote
Old 02-01-2016, 01:44 PM #6
Titanpat57's Avatar
Senior Member
Real Name: Patrick
Senior Member
Titanpat57's Avatar
Real Name: Patrick
Next up...the North Star battery replacement
Battery is the PL-AGM-31M I got in a group buy here, and it ran at Tacoma World as well. Seems Sears Platinum AGM's are no more, so it time to look for an alternative...a buddy recommended this.
Initial impressions are favorable. Build quality looks good, as does the warranty. It's a tight fit side to side on the length, and it's about an inch higher then the stock, so the OEM hold down doesn't reach.
The terminals don't reach either, so I bought some thick wall copper at Lowes, crushed it in a vise, drill out new holes for the terminals, and bolted it back together. Is it safe?...lol...we'll find out. (if you do this shit to your truck and it cooks it, it's on you) I only do these kind of things because, it seems to make sense, and I don't know any better. I did order solid 3/16" x 3/4" copper from Mcmaster-Carr, to redo it, although I think it's fine as it is. It's very solid, bolted to the separate pieces of the terminal, which really made it easy to do it this way.
I had some 1/8" aluminum plate laying around. I cut it to size, drilled out some small holes, and siliconed it in place. After that I took some rubber roofing I had lying around, and cut and fit 2 pcs. of that into place, to supply a little cushion under this monster.
After the battery was in place...Murphy's f'in Law never takes a vacation day, so the hold down bracket was short. I had some 1/8" x 2" flat stock, so I bent up a new bracket to fit, and added the ROAM garnish...just to piss Jeff off.
Any you old school Chevy guys may remember the under the hood light that was featured in the trucks back in the 90's...I saw one on Fleabay for 30$, so I always missed it. Now I just have to convert it to LED...it easily reaches the back of the truck, and is magnetic.
__________________
Old 02-01-2016, 03:36 PM #7
weeeee's Avatar
Senior Member
Senior Member
weeeee's Avatar
After reading this I went to look on the Sears website. Dammit- the 31M is not there anymore. I was going to pull the trigger on one but was waiting for it to go on sale again.
__________________
IG @go.xplre
Old 02-01-2016, 03:50 PM #8
Antman's Avatar
Antman Antman is offline
Elite Member
Real Name: Jeff
Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all
Elite Member
Antman's Avatar
Real Name: Jeff
Love you man!
Yes, your mods are cool!
But not as cool as mine.
Everybody can click on my sig below to see the difference...
__________________
HERE FISHY FISHY FISHY!
Antman is offline   Reply With QuoteReply With Quote
Old 02-01-2016, 04:25 PM #9
Rotorgeek Rotorgeek is offline
Member
Rotorgeek is on a distinguished road
Member
Nice truck! I bought the same one. I love the location for the fuse block. Where did you move the tool pouch? Are you thinking about adding a second battery? I'm trying to figure out where to put it.
Rotorgeek is offline   Reply With QuoteReply With Quote
Old 02-01-2016, 04:34 PM #10
1engineer's Avatar
1engineer 1engineer is offline
Moderator
Real Name: Greg
1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light
Moderator
1engineer's Avatar
Real Name: Greg
Hey Pat,
When are you going to put in floor mats and LED lights so it can be a real mod?
1engineer is offline   Reply With QuoteReply With Quote
Old 02-01-2016, 04:37 PM #11
toseeg toseeg is offline
Member
toseeg will become famous soon enough
Member
...no KDSS again, on purpose
Could you explain your reasoning for dropping KDSS? I will be making that decision in a little while. Thanks!
toseeg is offline   Reply With QuoteReply With Quote
Old 02-01-2016, 04:49 PM #12
Titanpat57's Avatar
Senior Member
Real Name: Patrick
Senior Member
Titanpat57's Avatar
Real Name: Patrick
Quote:
Because honestly...I just feel it's entire system hanging down, waiting to get caught on something. I can't point you to any specific article, it's just what goes through my head. Just seems like one more thing to go wrong.
I drive at least 90 miles round trip to work everyday, and so I have a great reason to have it. I get that it helps the ride, especially when I'm doing 99% on road driving, and 1% off road. It seems there are minor issues with fit on sliders and skids, but nothing insurmountable.
I would classify my style of off road driving as calculated....I'm perfectly happy with the truck as is, and would rather pump the extra grand into a serious suspension upgrade.
__________________
Old 02-01-2016, 04:52 PM #13
Sundog7121's Avatar
Sundog7121 Sundog7121 is offline
Member
Real Name: John
Sundog7121 is on a distinguished road
Member
Sundog7121's Avatar
Real Name: John
Silver better.
__________________
2013 4Runner Trail Edition | Classic Silver Metallic | KDSS | Demello Offroad Hybrid Sliders | RCI Metalworks Skid Plates | GOBI Stealth Rack | Bilstein 5100 F/R | Stealth Satoshi Mod
Sundog7121 is offline   Reply With QuoteReply With Quote
Old 02-01-2016, 09:17 PM #14
Jhalko's Avatar
Jhalko Jhalko is offline
Senior Member
Real Name: Halko
Jhalko has a spectacular aura about Jhalko has a spectacular aura about
Senior Member
Jhalko's Avatar
Real Name: Halko
It's so cute how you and @Antman bicker, true love for sure...
__________________
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
Jhalko is offline   Reply With QuoteReply With Quote
Old 02-01-2016, 09:51 PM #15
Titanpat57's Avatar
Senior Member
Real Name: Patrick
Senior Member
Titanpat57's Avatar
Real Name: Patrick
Quote:
Originally Posted by 1engineer View Post
Hey Pat,
lol..does the LED rear back up lights count??
Quote:
you have no idea what a pain in the ass that guy is...
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Northeast Expedition's 2016 TRDPro build NEExpo 5th gen T4Rs 154 03-12-2018 09:48 PM
2016 SR5 White Storm build bbenson 5th gen T4Rs 32 06-04-2017 02:39 PM
RunnerPDX - 2016 TEP Build Thread RunnerPDX 5th gen T4Rs 3 01-11-2016 12:43 AM
(2016?) 4Runner to get 2016 Tacoma V6? ProspectiveBuyer 5th gen T4Rs 6 07-27-2015 03:55 PM
Contour Roam 2 H&KRunner For Sale: Non-T4R Items 3 04-20-2013 10:29 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2026, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
Copyright © 2020
