02-20-2016, 12:08 PM
#46
Originally Posted by barryhiram
IMO philsey did it right! Go2Slp, link should also be added to your list
Already in there, and yes he did.
02-20-2016, 02:23 PM
#47
Real Name: 3 guesses..........
Ha, must have missed that, sorry Go2Slp.
Note to self, check 2nd post before posting........D'oh
'12 SR5, Blizzard Pearl * Factory (style) Fog Light Switch-Fits knock-out! * 30" BD Stealth LED Light Bar, Upper Grill '12 SR5 * Reverse Light Mod-SR5 Factory Bumper * FN f(x) Pro Wheels - Custom Coating * LLumar Paint Protection/Tint, Flowmaster Cat-Back, Bilstein 6112/5160, LR UCA's, AirLift w/Load Control, 285/70/17 Nitto TG, LW's D2S 4.0 HID low beam mod, V-LED Interior/Reverse/LMZ High Beam/Turn Signals/V-6 DRL Lights (all 5000K), Kappa Dash/Doors/Hatch Speakers, CompuStar Remote Start, B&M Trans Cooler, Devil Horn Emblems, XB LED Fogs, Dongle Mod, TRD CAI, DC 270-XP Alt
02-20-2016, 02:57 PM
#48
Real Name: Ted A Hamilton
Originally Posted by Salvo Jimmy
Anyone have experience with Sylvania ZEVO LED replacements???
I'm contemplating using their 1157R (R=Red) for the jury rig rear fog.
They are readily available in my area. Three different named auto parts stores carry only them and they are available at WalMart as well. Can't find any JDMs except on line.
Forget the "Super Bright" Sylvanias. Saw a pair on sale at a good price so I said what the heck, give'em a try. Maybe at best half as bright as the incandescent.
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
02-20-2016, 03:08 PM
#49
Try this guy, might be willing to custom build you something to your specifications... Home
02-20-2016, 08:17 PM
#50
I did see any replacement DRL LED's listed for 2014 and up
02-21-2016, 09:40 AM
#51
Seems the best economical solution might be a "rewired" 4 pin trailer light extension cord. I had to get a 4 pin extension to get power to the short lead on the Bully CR-007A.
If an extension were wired so that when plugged into the trailer connector and Bully, the Bully bulb brake light function were on when the tail lights are on, that would give the desired brightness. And the brake light wire(s) on the extension not powered when braking. Then just use the brightest red LED 1157 I can find to reduce current/heat from the incandescent brake light. LED might be necessary with the brake light on continuously with tail lights.
This would also allow the "cheap" Bully to be periodically replaced when needed with no further mods.
So any ideas on the rewire?? And I'll check out the custom site.
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
No Mods, Yet😇
02-21-2016, 10:28 AM
#52
Headlights – High Beams
- Installing LED bulbs into the ‘14+ T4Rs is complicated by the fact that they also serve as the Daytime Running Lights (DRLs). In order for and LED bulb to function correctly in the HB spot (i.e. without flickering), you’d need a relay (like the CanBUS sold by XenonDepot)…and unfortunately this relay would make the DRLs have the same intensity as the high beams because these LEDs do not dim. Alternately, you can disable the DRLs and run LEDs in your HB spot.
Disabling the DRLs: DRL Disable but keep Auto Headlights
Maybe I'm misunderstanding your question, but the above quote is why replacing the OEM combo HB / DRLs with LED bulbs on '14 and up won't really work as a "plug n play" mod. In order to run LED DRLs, you have to install different DRLs (like, in a different spot, which would require running / splicing new wiring). There are a couple of different options for this listed in the second post of this thread.
02-21-2016, 01:58 PM
#53
Thank you for the help. I'm probably not explaining it correctly that link shows the amber outside blinker. I want to change that bulb on the inside near the grill that's the DRL bulb. It goes off when you turn the headlights on. And it's Kind of dim. I wanted to be like an LED bulb with that bluish tint .
02-21-2016, 02:59 PM
#54
I think maybe you're misunderstanding what I'm saying. That dim bulb you're talking about near the grille is indeed the DRL, but it's also the high beam- turn your high beams on and go look outside the truck and you'll see what I mean. The DRLs and High Beams are the same bulb / spot on the '14 and newer T4Rs, the truck just runs the 9005 bulb at a lower current to produce dimmer DRL light. Replacing this bulb with an LED is complicated by this fact for the reasons I noted in the quote earlier.
If all you care about is the whiter light, you could buy a blue tinted halogen bulb such as the Philips CrystalVision that would allow you to get the whiter light and preserve the functionality of the DRL / High Beams.
02-21-2016, 03:37 PM
#55
Don't you hate it. Toyota screwed the front lighting in 5th gen T4R by trying to be "smart ass" and use computer (ECU) to control last century technology (Edison bulbs). Early models (pre 2014) have blinkers as DRL, later have high beam as DRL. What's wrong with just adding a dedicated bulb for DRL, Toyota?
2012 4Runner SR5 4x4 (Bismarck) - all stock with minor improvements.
1995 Tacoma LS 4x4 ExCab (Taliban Truck) - all stock with minor improvements.
My "Bismarck" is the first 5th Gen 4Runner in Poland. Local Land Cruiser Diesel is just a luxury form of a farm tractor.
Motto: Diesel is for heating, gas is for cooking, electricity is for lights. Cars use petrol.
02-21-2016, 04:00 PM
#56
Yep , thank you I was not getting it. I will re-read thread.
02-21-2016, 04:06 PM
#57
This is the bulb I was referring to. It will give you a whiter light from the DRLs and High Beams. Since all you are doing is replacing the bulb, it will work for both while an LED will not.
9005 - Philips CrystalVision Ultra 9005CVS2 bulb
Good luck.
02-21-2016, 04:07 PM
#58
Good luck.
Thank you so much for the part number
02-21-2016, 05:48 PM
#59
What does the options mean? What's CANbus and 2015+ Mopar?
I planning on getting the h11 hids.
02-24-2016, 02:12 PM
#60
Excellent thread!
