Originally Posted by bmwmotorcycle
I have a towing package on my 2015.
The trailer weighs 2500 plus traveling stuff.
There is an electrical connector for the trailer at the back bumper
The trailer mfg. says I need a need a brake controller.
Is this a plug and play item which is mounted to the lower dash and plugs into some connectors which came with the towing package.
Or is this some major surgery to the wiring harness in the dash.?
Is it better to have my Toyota dealer install this or should I go to a travel trailer place? Thanks for help.
Your truck should've come with a wiring harness that plugs under the lower left dash. Some manufacturers (Tekonsha) sell adapters meant to plug into specific vehicles. IIRC, I used both the Tekonsha adapter and the Toyota-supplied harness in conjunction with one another, although I may have only used the Tekonsha part.
In any case, it's quite simple and you can do it yourself with simple hand tools.
