02-22-2016, 11:17 PM
14 trail skid plate bolts broke :(
Well did the oil change this weekend and the first 2 bolts snapped.. The others came out fine. Soooo I am guessing previous owner over-tightened these.
I have heard of people tapping and putting in larger screws.
Whats everyone suggestion?
Tap and replace stock, or tap and put in bigger ones.
lifted 2018 4Runner Sr5 (Wifey Mobile)
lifted 2015.5 GMC 1500 Denali (Dad Mobile)
Follow me on Instagram @GuynHisToys
02-22-2016, 11:44 PM
Were they the front two bolts?
02-22-2016, 11:49 PM
the EXACT same thing happened to me 2 weeks ago, luckily it was only one of the front bolts... TRD skid plate on order, problem solved!
16 T4R TE Premium w/KDSS | Fuel Beast 17x9 | KO2s 285/70/17 | OME BP-51 | TC UCAs | SSO Slimline Hybrid | x20 10k
11 Cadillac CTS-V
Graveyard:
14 T4R TEP, 11 Sierra Denali, 07 Sierra Denali, 04 Cadillac CTS-V,03 LR Disco, 99 T4R SR5 - TRD Supercharged, Headers, Exhaust...
02-22-2016, 11:53 PM
try a Screw extractor set... once you get it seated, attach a ratchet and or break bar to pop them loose.
Troner envy... the struggle is real!
02-23-2016, 12:00 AM
Yes they were
02-23-2016, 12:01 AM
What did that run you. 300?
02-23-2016, 12:09 AM
249 on fleabay
11 Cadillac CTS-V
Graveyard:
02-23-2016, 12:12 AM
02-23-2016, 12:16 AM
I put on my lift in December and had this same issue. Snapped one of the front bolts off while taking the bolt out! I just figured the bolt had issues. I took that little piece off, drilled the center and used an small ez out. It worked like a charm and no damaged threads! I wasn't aware that the skid plate bolted up any differently?
02-23-2016, 12:18 AM
I snapped a front one off a while back too. I drilled it out and ran a larger bolt through with a nut on the back as I was pressed for time. I ended up replacing the support that it bolts into.
02-23-2016, 12:20 AM
Had the same thing happen to me. Said screw this tin piece of crap and ordered real skid from shockworks.. Never looked back..
'13 trail, kdss, nav, weather tech, canvas back for the dog, plastidip rims and emblems inside and out, LED interior, Metaltech sliders, 20% tint up front 35% on the rear, vled triton led drl's, toytech ultimate 3in lift, total chaos UCA, 285/70/17 BFG at/ko, gobi stealth 4-6" rigid e2's, Shockworks front skid, Morimoto LED Fogs ***TOTALED***
02-24-2016, 08:29 PM
It's not the skid plates issue. It's the locking bolts they put on. Great bolts thin skid plate.
02-24-2016, 08:32 PM
I know is wasn't the skids fault but instead of drilling out all the holes and tapping them again I just went with a beefier skid. Used it as a excuse to talk the wife into approving the purchase.
