Thread Tools Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Old 03-04-2016, 11:51 AM #16
1engineer's Avatar
1engineer 1engineer is offline
Moderator
Real Name: Greg
1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light
Moderator
1engineer's Avatar
Real Name: Greg
Originally Posted by renau001 View Post
A couple things I'd love some help on if anybody knows an official Toyota position.
1) There are tons of opinions on how much to grease a slide yoke on the drive shaft. Some say 2-3 pumps. Some say pump until you see the first bit of extension. Some say pump till it purges out the seal. Some say don't overfill. Some say you can't overfill. I have no idea and I could find nothing in the repair manual. If there are any Toyota techs with some official info that'd be great. Until then, I'll probably go with 2-3 pumps every oil change to be safe.
2) The mythical 'Tighten nuts and bolts on body and chassis' that is recommended for severe service conditions. I'm at a loss as to what all this really should include. The "glove box" maintenance guide says to tighten "re-tighten the seat-mounting bolts and front/rear suspension member retaining bolts to specified torque." Okay, that's not too bad, but still pretty un-specific. The Repair Manual from TIS has a much longer list:
(a) Where necessary, tighten all the parts of the chassis.
Front axle and suspension Drivetrain
Rear axle and suspension Brake system
Engine mounting, etc.
(b) Where necessary, tighten all parts of the body.
Seat belt system
Seat
Doors and hood
Body mounting
Fuel tank
Exhaust pipe system, etc.
That's easily hundreds of bolts, and many I would not want to touch with a 10-ft pole unless there was a problem, plus many that are not easily accessible. This almost just seems like a CYA maintenance recommendation from Toyota. If anybody has any recommendations as to what you should actually torque up periodically, let me know and I'll look up all the specs and add to the OP. Thanks!
It's mythical because, if a bolt is torqued correctly to begin with, you must have bolt stretch or thread fatigue (or deformed mating parts like bushings) for it to become loose. On a 15 year old vehicle that stays off road then I agree. For a new or even five year old vehicle that does a fair amount of off road it's not gonna stretch or fatigue, providing it was designed correctly. It's CYA from the manufacturer so 15 years from now you can't come back and say "I crashed because my bolt came loose." I wouldn't think twice about it unless you know of a specific problem area.
1engineer is offline   Reply With QuoteReply With Quote
Old 03-04-2016, 12:01 PM #17
renau001 renau001 is offline
renau001 will become famous soon enough renau001 will become famous soon enough
Originally Posted by flyinhawaiian01 View Post
Fantastic write-up! Only thing I would add to the list are the recommended intervals for each of the items. That would make this a perfect thread to refer to on when services are supposed to be performed. Doesn't need to be crazy, just something like:
Replace engine air filter
(interval, every XXX miles or XX months)
Parts:
Filter - Toyota part # 17801-38051
Tips:
1) DIY video
I'm always having to search around for what's due at the mileage I'm at, it would be awesome to just refer to this list and see what's due and when!
Done, somebody please check behind me.
Caveat: I will probably follow closer to the severe intervals for fluids regardless of whether I was severe or not. Others will agree or disagree. This a drive till the wheels fall off vehicle for me.
renau001 is offline   Reply With QuoteReply With Quote
Old 03-04-2016, 12:02 PM #18
Kinda what I was thinking, thanks.
Old 03-04-2016, 12:06 PM #19
Originally Posted by Lester Lugnut View Post
Great work. The following applies to A750E/A750F automatic transmissions:
Automatic transmission pan gasket - 3516860010
Automatic transmission pan drain plug gasket - 3517830010
You know if the drain plug gasket number is good for the overflow plug too?
Old 03-04-2016, 12:43 PM #20
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is just really nice Cymon is just really nice Cymon is just really nice Cymon is just really nice
Cymon's Avatar
Real Name: Chris
Thank you!
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
Old 03-04-2016, 01:41 PM #21
Rmack Rmack is offline
Rmack is on a distinguished road
Here is the transmission service PDF from TIS if anyone needs it
File Type: pdf A750E Automatic Transmission Service.pdf (330.8 KB, 951 views)
2015 2WD Blizzard Pearl Limited, Black Interior
Rmack is offline   Reply With QuoteReply With Quote
Old 03-04-2016, 02:33 PM #22
Peyto's Avatar
Peyto Peyto is offline
Peyto is on a distinguished road
Peyto's Avatar
Great thread and contribution. I'll definitely be saving this for future reference as it's nice to have all the information in one place.
Power steering fluid
1) Between min and max (cold and hot lines provided)
2) Cold - not driven in last 5 hours (50-85 degF fluid temp)
3) Hot - driven 50 mph for 20 mins (140-175 degF fluid temp)
I would consider adding to this section the replacement fluid type because in the past there has been some ambiguity from Toyota leading to confusion. The manual specifies that power steering fluid is a Dex II/III ATF. Where people have been confused in the past is that the colour of the OEM fluid looks like power steering fluid. Whether OEM is PSF or undied Dex ATF, no one is sure, however forum members seem to have used both PSF and ATF with no problems. More info on this here: Power steering fluid, or ATF?
2014 Canadian TE Alpine White, Cooper AT3 / Michelin X-Ice XI2, Shrockworks Step Sliders, Compustar 2-way Remote Start, Side-Exit Exhaust, Morimoto XB LED Fogs, Interior LEDs, 3M Clear Bra.
Peyto is offline   Reply With QuoteReply With Quote
Old 03-04-2016, 05:53 PM #23
01100101's Avatar
01100101 01100101 is offline
Real Name: e
01100101 is on a distinguished road
01100101's Avatar
Real Name: e
BOOKMARKED!
Nice work and thanks! I need to change my differential oil soon and it beats doing a search and reading countless of threads on this.
01100101 is offline   Reply With QuoteReply With Quote
Old 03-04-2016, 09:00 PM #24
Added some socket sizes. Will finish the rest when I get a chance to crawl around.
Old 03-04-2016, 10:35 PM #25
Deuskid Deuskid is offline
Deuskid is on a distinguished road
WoW!
Great post OP...
Definitely need this as I'm buying soon. Stopped by the local Toyota dealer today after 'committing' through Costco a few days ago. Still trying to figure out what I really want/need.
Subscribed for the good info here and to come..
Thanks
Deuskid is offline   Reply With QuoteReply With Quote
Old 03-05-2016, 12:30 AM #26
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
Not sure. I checked the numbers I provided against a couple of online parts sites. None showed a part number for the overflow plug.
It's out there somewhere - I'm just not sure where.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 03-05-2016, 01:07 AM #27
96r50 96r50 is offline
96r50 is on a distinguished road
Both plugs on the bottom of the transmission pan use the same crush washer (35178-30010).
2010 4Runner Trail Edition
96r50 is offline   Reply With QuoteReply With Quote
Old 03-06-2016, 12:07 AM #28
dirtman dirtman is offline
dirtman is on a distinguished road
Awesome!
Thanks for the write-up! I was looking for info. on changing my ATF. Thanks!
dirtman is offline   Reply With QuoteReply With Quote
Old 03-06-2016, 06:22 PM #29
K12pilot K12pilot is offline
K12pilot is on a distinguished road
Great write up! I will keep this handy )
K12pilot is offline   Reply With QuoteReply With Quote
Old 03-08-2016, 04:43 PM #30
Think I got all the bolt sizes now. Let me know if you find any errors.
5th Gen Maintenance Documentation and Reference WhiskeyCop 5th gen T4Rs 108 12-25-2023 04:57 PM
Quick reference: How much deflection in alternator belt? Frontier719 3rd gen T4Rs 17 11-14-2015 01:34 AM
Anyone want a quick reference guide for maintenance items? Cubslover Maintenance/Detailing 0 10-28-2010 10:10 PM
AU001R-06 02/26/2007 Audio System - Quick Reference Diagnostic Guide CBR_GUY_IA TSB 0 07-12-2009 09:37 PM
Just did a quick 30K maintenance!! TRD04RUNNER 4th Gen T4Rs 16 07-15-2006 02:38 PM
