Thread Tools Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Old 03-05-2018, 01:58 PM #61
Randyman...'s Avatar
Randyman... Randyman... is offline
Randyman... is on a distinguished road
Originally Posted by renau001 View Post
When the time comes, I will just do a drain and fill.
I did just that. Incredibly easy. Was doing an oil change at the same time, so had to drop skid plates regardless.
Radiator drain cock opened with little effort. Passenger-side engine block draincock (10mm bolt) + 2' of appropriate hose made this very easy and fairly clean. Old coolant appeared a little cloudy - not bad for 6 years and 155K
Used the fill/burp method from the 2010 FSM. Didn't need the air bleed tool at all!
RE: Refill Capacity: I used about 2 1/3 gallons - so 2 gallons would not have been enough. And I have a spare 2/3 gallon on-hand if needed (and we have other 'yotas)...
Also lightly detailed the engine bay, and did a quick wash. Didn't get to spark plugs or belt - next weekend (or so I tell myself) ...
Thanks for the input
Randy V
2013 4Runner * SR5 * 4x4 * Leather * Convenience Package * Black-on-Black *
* BFG KO LT265/70R17/C * SR5 Wheels + SpiderTrax * 5100's @ .85" * GrillCraft Grill Mods & TOYOTA Emblem * H9 & H9011 Headlight Swap *
* Alpine W910 DVD/NAV + H800 DSP * ARC Audio * JBL * JL * Morel * DieHard Platinum 31M * Total system power = 4,048 Watts RMS ! *
Randyman... is offline   Reply With QuoteReply With Quote
Old 03-05-2018, 08:28 PM #62
renau001 renau001 is offline
renau001 will become famous soon enough renau001 will become famous soon enough
What type of hose did you use on the engine block drain plug? Anything else I need to update in the OP that would be helpful for others?
2016 Trail Edition Premium w/ KDSS. LT265/70R17 BFG KO2s, Ceramic Pro, TSO pro grille, sliding cargo tray, WeatherTech floor liners, '10-'13 trail running boards.
Nobody cares about your vehicle as much you do. DIY Maintenance Quick Reference
renau001 is offline   Reply With QuoteReply With Quote
Old 03-09-2018, 10:16 PM #63
RCFJ RCFJ is offline
RCFJ is on a distinguished road
Awesome thread. Thanks a ton.
Wanted to get a 3oz grease gun for greasing the prop shaft. Will these 2 work as the 2 types of grease needed?
Moly for the 2 on the slide yokes
https://www.amazon.com/gp/product/B0...A3I1KK2PZWH1ET
Lithium for the 4 spider joint fittings
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
RCFJ is offline   Reply With QuoteReply With Quote
Old 03-09-2018, 10:28 PM #64
Moly for the 4 spider joint fittings
Lithium for the 2 on the slide yokes
Can’t see from the pic on website, but look for NLGI #2. Need to swap up your order though. Both greases are lithium based. For the spiders, use non-moly. For the slide yokes, moly is preferred. The ones I link to in the OP definitely fit the bill. But they are not 3oz.
Old 03-09-2018, 10:32 PM #65
Quick reply too, yep already caught it and reversed it.
Both are NGLI 2. Thanks again
Old 09-03-2018, 02:08 PM #66
J.F. Sebastian J.F. Sebastian is offline
J.F. Sebastian is on a distinguished road
Well after coming across this thread linked from another, wondering why it isn't stickied? Have been going through these forums quite heavily and never saw this comprehensive archive of specs!
Thanks a LOT for doing this renau001! Bookmarked for easy reference.
J.F. Sebastian is offline   Reply With QuoteReply With Quote
Old 06-17-2019, 12:25 PM #67
heybert heybert is offline
heybert is on a distinguished road
Want some input.
New to the Gen5 maintenance schedule, so was wanting some input. I have a 2014 4Runner SR5. When I purchased it at 72000 km's, the dealership could not tell me if the driveline fluids have been changed as they did not have any info on the vehicle between 48000 to 72000 km's. Should I change the diffs and transfer case fluids now that I have 76000 km's?
Next question is when should I change the automatic tranny fluid?
Thanks in advance.
2014 SR5 Premium
heybert is offline   Reply With QuoteReply With Quote
Old 06-17-2019, 04:29 PM #68
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
Thanks in advance.
Now would be about the right time to replace all fluids IMO. Toyota claims the tranny is "lifetime fluid" under normal conditions however there is no such thing and fluid that never wears out. I changed my OEM diff oil out at 10K and i'm glad I did. The rear diff was pretty dirty and had metal in it but nothing that is of any concern, just normal wear. I was happy to get all that out of there and know the fluid is clean. Front diff was almost like new but I use 4WD ever month as stated in the manual so it did have a little bit of a darker color. For the diffs, I will service them every 30K or so moving forward. Transfer case and transmission will be every 50K or so. I also change engine oil and filter every 5K and grease the 6 zerks on the u joints and slip yokes with every oil change. At the end of the day, your fluids can never be too fresh or too clean and IMO it's just cheap peace of mind.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 06-17-2019, 09:26 PM #69
Originally Posted by 2016 4runner sr5 View Post
now would be about the right time to replace all fluids imo. Toyota claims the tranny is "lifetime fluid" under normal conditions however there is no such thing and fluid that never wears out. I changed my oem diff oil out at 10k and i'm glad i did. The rear diff was pretty dirty and had metal in it but nothing that is of any concern, just normal wear. I was happy to get all that out of there and know the fluid is clean. Front diff was almost like new but i use 4wd ever month as stated in the manual so it did have a little bit of a darker color. For the diffs, i will service them every 30k or so moving forward. Transfer case and transmission will be every 50k or so. I also change engine oil and filter every 5k and grease the 6 zerks on the u joints and slip yokes with every oil change. At the end of the day, your fluids can never be too fresh or too clean and imo it's just cheap peace of mind.
thanks!
2014 SR5 Premium
Old 07-24-2019, 11:18 PM #70
5thgen20's Avatar
5thgen20 5thgen20 is offline
5thgen20 is on a distinguished road
5thgen20's Avatar
Tranny Fluid Change?
First off- excellent write-up, thank you!
So I’m about to change my tranny fluid in my 2011 T4R. I just got it at 155k on it and the ATF fluid has never been changed. Reading the manual, this has me a bit concerned, but other places I’ve read that the fluid is good for the life of the car... so is it worth going through the trouble of dropping the pan and all that or should i just leave it be?
The ole “if it ain’t broke don’t fix it”? 😂
2011 4Runner SR5 - Toytec Bilstein 3" lift
5thgen20 is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 07:55 PM #71
Real Name: Chris
Real Name: Chris
Drop the pan, change the filter, change the fluid. There is absolutely no such thing as lifetime fluid, that's total BS Nothing lasts forever.
Old 09-07-2019, 11:28 AM #72
TN4RNR TN4RNR is offline
TN4RNR is on a distinguished road
137 lb ft torque on the front caliper mounting bolts? Really? Man, that sounds high. I’ve also seen 91, possibly from a 4th gen or earlier?
Can anyone confirm?
Thanks
TN4RNR is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 03:15 PM #73
Can anyone confirm?
Thanks
I can confirm that is what the factory service manual says. I can't say for sure whether or not that is a typo. So use at your own risk.
Old 02-26-2020, 05:16 AM #74
andyinoly andyinoly is offline
andyinoly is on a distinguished road
thanks for the post! looks full of great material. I'm a noob to this gen and have some parts I'm having a hard time finding guidance to replace/repair. Stupid things like the butt warmer isn't working on one side, shifter area backlight not working, and a couple random plastic interior trim pieces... any points in the right directions would be appreciated! sorry if this isn't the right place... still figuring this stuff out thanks for the resource!
andyinoly is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 09:24 PM #75
Partsouq.com has dealer style parts diagrams. Best I’ve found for hard to figure out stuff.
Bring your vin # for best results.
5th Gen Maintenance Documentation and Reference WhiskeyCop 5th gen T4Rs 108 12-25-2023 04:57 PM
Quick reference: How much deflection in alternator belt? Frontier719 3rd gen T4Rs 17 11-14-2015 01:34 AM
Anyone want a quick reference guide for maintenance items? Cubslover Maintenance/Detailing 0 10-28-2010 10:10 PM
AU001R-06 02/26/2007 Audio System - Quick Reference Diagnostic Guide CBR_GUY_IA TSB 0 07-12-2009 09:37 PM
Just did a quick 30K maintenance!! TRD04RUNNER 4th Gen T4Rs 16 07-15-2006 02:38 PM
