07-27-2021, 01:40 AM
#211
Originally Posted by mynameistory
Yeah it does seem a bit haphazard. Did it snap into place as advertised? And was it easy to remove the outer shell once you took it off of the roof?
i actually had a second antenna around that i was modifying the sharkfin. debating if i want to install this.. the sharkfin cover definitely cannot be removed with it still on the roof, so easy way is to cut it off..
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
07-27-2021, 01:50 AM
#212
Got it. I'll probably remove the antenna first, just in case I decide to go backwards too.
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
07-27-2021, 12:22 PM
#213
good idea honestly. the shark fin delete is nice. but theres not much difference doing this and cutting the fin off and applying a blob of silicone...
07-27-2021, 05:19 PM
#214
-Tory
07-28-2021, 12:26 PM
#215
I think that the screws were located outside of the sealing strip, so water intrusion should be next to impossible.
07-28-2021, 12:49 PM
#216
Real Name: Jeremy
Real Name: Jeremy
Don't ever plan on using the satellite radio so this is on my list..
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
07-28-2021, 12:53 PM
#217
Yes true, shouldn't leak to the cabin (at least directly). But it might seep into the PCB via capillary action. I'm not too worried about it. I don't care much about satellite radio, as long as my headliner doesn't turn into a mold fest.
This retains the satellite radio antenna so you're good to go either way!
-Tory
07-28-2021, 02:08 PM
#218
Real Name: Jeremy
Real Name: Jeremy
will definitely make loading my kayak a lot easier..
10-22-2021, 04:36 PM
#219
I wish I could find pictures for getting access to my 2015's headliner area
Owner, BladeForums.com
10-31-2021, 12:04 PM
#220
It's easy. There's 3 pop pins that hold it up in the back, they're plastic and the same color as the headliner. Use a trim tool (or carefully with a sharp flathead screwdriver) and pop them out. To get more space, I popped out the plastic trim around the D-pillars. Didn't remove them completely, just popped them out a little bit. This gives you all the access you need.
-Tory
01-12-2022, 09:35 PM
#221
2010 T4R shark fin stolen
I don't subscribe to satellite radio so why do I need a replacement fin anyway? I have duck tape over the hole in my roof but any suggestions on how to repair or fix this? thx
Sara
01-13-2022, 07:31 PM
#222
Sara
No, you're fine. Duck tape is a great solution
-Tory
03-28-2022, 07:48 AM
#224
Real Name: Jeremy
Real Name: Jeremy
For those who have used the GFC delete kit any issues with leaks?? I'm about to do this myself and just want to make sure you still have a good seal. Thanks.
03-29-2022, 12:07 AM
#225
I've had mine for a few months now, but with very little rain in socal (until LOTS today). I will check my headliner etc. in the morning for you.
-Tory
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
