04-12-2016, 11:51 AM
#61
It's on a 2016 trail premium.
Second layer
It makes me want a 3D printer, it would be fun to model a low profile cover that replaces the existing plastic.
04-12-2016, 03:17 PM
#62
That looks totally different from any antennas I've seen on Toyotas. Interesting that they would change the design halfway through the cycle. I'll see what I come up with.
IG @go.xplre
04-12-2016, 08:10 PM
#63
Sorry for suck pic but this was what was inside mine ! Which don't I need ?
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
04-12-2016, 09:46 PM
#64
Do you have a limited?
EDIT: Nvm, looks like you have a 2011 SR5. I have a 2014, so unfortunately I can't be much help. I'm thinking one of those is a GPS chip.
@ mdogg
can you assist?
IG @go.xplre
04-12-2016, 09:52 PM
#65
No sir 11' sr5 but had the trim pkg . I just left it unplugged so far ok . Bought used think guy before had xm & other stuff but I don't need fine using the bluetooth !
04-13-2016, 07:51 AM
#66
@ mdogg
can you assist?
Unfortunately, I don't remember what was underneath my OEM one or what was underneath the 8696006030A1 replacement. I'll snap a pic of the OEM version later today to check it out. It will be a few hours, but I'll check it out.
It looks like
@ oljedi11950
bought 86960 02050 (instead of 86960 06030 like mine) - I'm not sure exactly what that part number is for. I remember when I was searching they had multiple versions - for Safety Connect (with/without) and either GPS or Satellite (with/without; perhaps even all combinations).
04-14-2016, 08:31 AM
#67
It looks like
@ oljedi11950
A little late, but as promised..... pictures of the electronics and connector from a 2013 Limited with JBL.
04-14-2016, 09:50 AM
#68
I saw a Camry antenna that looks identical to the ones people are installing with that same plug on eBay. It was 40ish. Might be worth checking out if you have the 3prong connector
Air 4rceRunner One, 04 Sr5
04-14-2016, 10:01 AM
#69
Banned
Banned
@ Brandon_Reed
, mind checking the dimensions of your slot? I also have a 2016 and don't care about or want XM radio, so I may put an NMO mount there but I don't think that it will fit
04-14-2016, 11:13 AM
#70
Originally Posted by e60ral
@ Brandon_Reed
Sorry, I don't plan on taking it apart again unless there's a solid prospect of replacing it with a low profile unit.
04-14-2016, 01:13 PM
#71
Based on the previous few photos it appears that the outer sharkfin design does actually have a purpose. Anybody know which antenna the thin fin shape one serves?
Nearly bone-stock 2015 TRDP<paid under sticker!, TRD Supercharger, Helo 904 17x9 rims, 285/70-17 BFG KO2, BMC, MetalTech OPOR Sliders w/extension, Hella Aux Fogs, Ultragauge, Rockford Fosgate Speakers, FJC Sub Woof Box, Kicker Woof, Cheapo Boss Woof Amp, Aux Glovebox Outlet, etsy TRD hub covers, Shaved/trimmed Mud Flaps and Fenders, Cobra WX75 CB, Rear Storage Drawers, Shovel Mount, Radar, FZ-1 Fuzeblock, AVS LP Visors, Window Tint, Painted Roof Rack, Low Profile SiriusXM Antenna, Dash Cam, Exhaust Tip, Accessory Meter Mod, Some Stickers. 2008 FJ Cruiser, FJNE Member DMAND.
04-14-2016, 01:31 PM
#72
You should be good to go. For 2014-2015 models the extra space is cosmetic. 2010-2013 models there may be a slight issue with either the safety connect or the GPS, and the 2016+ (with the white plastic exterior) doesn't have an alternative yet.
IG @go.xplre
04-14-2016, 07:04 PM
#73
If it makes a difference I didn't loose anything still have radio , bluetooth, & just used it to cover up the hole left it un-plugged ! When & if I want xm for the road just pop it back in !
04-15-2016, 06:27 PM
#74
Any chance you could post link to that particular one ? Most of them won't or don't show the connector ! Appreciate if possible
04-15-2016, 07:16 PM
#75
2012 Camry Black Satellite Antenna 86960 06020 | eBay
Look at pic 2. Looks pretty similar to me. I made an offer and they countered with 42. I ended up buying a flat black one with the gray connector. I have the newer style so I was just planning on the internal swap
