04-02-2016, 11:45 PM
#31
No, mine doesn't have KDSS.
2016 TEP in Barcelona Red. Bilstein shocks set at 2.5" in the front and a Daystar 1.5" spacer in the rear. BFG KO2's size 275/70R17. Compustar remote start with Drone app and EZ-GO
04-03-2016, 04:23 PM
#32
1.75 and stock rear with bilstein shocks
I will be adding a 10mm spacer by OME in the rear here soon.
04-04-2016, 12:09 AM
#33
Originally Posted by winston70
Does your Trail have KDSS? I am thinking of doing the same exact lift to my 2015 Trial.
I have KDSS on my trail and have had no issues with it.
2010 Ford SVT Raptor-sold
2014 Toyota 4Runner TEP: 2 JL Audio 12" with JL 500w amp, Toytec BOSS 3" Method NV's on 285/70/17 Cooper ST Maxx's, and Demello 3 hoop front bumper
04-05-2016, 06:41 PM
#34
Originally Posted by kingofZroad
Yesterday I had my Bilstein 5100's installed. I went with the 2.5" setting up front and added a Daystar 1.5" spacer in the rear. Ditched the stock Dunflop tires for 275/70R17 KO2's.
MAJOR improvement in looks and ride quality!! No more major nose dive during breaking and it soaks up bumps better. Absolutely zero rub and I get to leave the mud flaps on!
I was worried about it looking "goofy" with that amount of lift on 275's, but I actually love the look!!
What is the daystar 1.5 spacer part# you used?
2013 T4R SR5
Follow me on Instagram: Xclusive808_
04-05-2016, 07:02 PM
#35
Real Name: Mr. Co
Real Name: Mr. Co
My Bilstein 5100s will be for sale soon...
04-05-2016, 09:08 PM
#36
I'm not sure what the part # was, sorry...
04-07-2016, 09:49 AM
#37
KT09127BK
is what you want..
2012 4Runner SR5 Premium
Bilstein 5100 F&R 2.5" front TJM lift springs rear
Firestone Air Bags
04-07-2016, 11:56 AM
#38
Do you know your rear measurements from ground to fender?
2013 T4R SR5
04-19-2016, 01:03 PM
#39
Real Name: Ben
Real Name: Ben
1.5 or 1 in spacers
Thanks again for all of the help. I'm still deciding if I want 1 in cornfed rear spacers or 1.5 daystar spacers. What's everyone's opinion about which one I should go with?
04-19-2016, 03:12 PM
#40
I was able to get the Daystar for 28.75 on ebay open box(never installed). I haven't gotten to the actual install yet as I am trying to decide if I want to deviate from stock wheels, so I can not speak to the ride. However, from everything I have seen here, the Daystar and Cornfed products are great! Not sure you will go wrong either way. One may be a little truer to 1.5", but other than that, I'm not sure you'd see/feel a difference.
2011 T4R SR5 premium- Magnetic Grey
Suspension: Dobinsons heavy duty suspension with JBA upper control arms l Tires and Wheels: 285/70R17 Nitto Ridge Grapplers on Level 8 MK6 17x9 -12 l Armor: Coastal Offroad front and rear bumpers, LFD Offroad full roof rack and wide skid, RSG Sliders l Other: 23Zero Walkabout 72, Spyder Auto headlights, Warn Evo VR 10s l Coming Soon: ?
04-25-2016, 12:09 PM
#41
I was worried about the 1.5" in the back being to "high" (my fronts are set at 2.5"). Glad I went with the 1.5" though, as 1" would have resulted in a "reverse rake" look...
If you are setting the fronts to 2.5", I'd go 1.5" in the rear. If you're only going 1.75" up front, I'd do 1" in the rear...
Phil
04-25-2016, 03:35 PM
#42
Phil
Phil, do you have will spacers or just running stock on wheels? I am looking to probably throw 285/70s on mine after the lift. Can't decide if I am going to want to change the width with new wheels or not.
04-25-2016, 06:28 PM
#43
+1 for the 2.5 & 1.5 set up.
Just finished mine last week, it rides great.
No more feeling like a boxer in the ring; bobbing and weaving my head back and forth while driving. Very nice sporty and firm feel now.
E.
2012 SR5 on Bilstein 5100's x4, OME 884, Daystar, Yokohama Geo A/T's, PIAA, K & N, Husky liners
Always remember those that just went to work that Tuesday. 9/11
04-28-2016, 09:50 AM
#44
Originally Posted by mybabydaddy
To each his own; you are more than welcome to try/do it.... But I'm telling you, somethings not right with that. Either he isn't on the highest setting, or something else is going on. TONS of us have all done this mod, and you WILL HAVE NEGATIVE rake with that setup. Heck, there is approx 1/4 inch negative rake at the 1.75 front setting and nothing in the rear (tho the fenders will look level).
The pics below are 1.75 front (which is NOT the highest setting) and stock rear... And it's level to the eye, but slight negative frame rake.
Again, do as you please, it's your rig, your time, your money. But with a completely stock 4Runner, 5100s at all four corners, and the fronts set to the highest, you will not be level.
What about putting a 2.5 bilstein and a 2 inch rear spring? Cos im planning to do that by next year..
04-28-2016, 10:39 AM
#45
That is a different story.... Should be fine with that, depending upon what springs you plan on installing. Do a lot of (re)searching, but I know that you can find members who have that setup. Tho, I’d bet most replaced all four springs at the same time.
I, too, will eventually most likely remove the rear spacers and replace the coils to lift, along with front coils to do the lift up there as well (while putting the front shock settings back to normal height)... thereby getting my lift all in the coils, and not by using spacers or pre-loaded shocks. But I’m not in a hurry, and have much more research to do on it first.
2017 Porsche Macan GTS - Carmine Red w/ matching side blades
2014 Black TEP w/ KDSS / nFab steps / Yakima Cross Bars / Bilstein 5100s (front at 1.75) / 1 inch rear Cornfed Spacers / FN Countersteer Type X / Nitto Terra Grappler G2s 265/70/R17 / RCI Aluminum (front) Skid - sold
2011 Silver Limited - sold
2007 SE Shadow Mica - sold
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
