03-26-2018, 10:31 AM
#766
Originally Posted by KP Texan
Ok, thanks! Looks like I need to give Bilstein a call and let them know I didn't get one of those plastic clips. My current washers and cushions only have 2500 miles on them, so I'm thinking they'll be in good enough shape to reuse; just wanted to make sure those weren't missing from my struts too!
Just got off the line with Bilstein technical, and they said the plastic retainer is just there for shipping to help the boot stay on and keep from getting damaged in the box. The guy said if you were to leave that retainer on, it would just get destroyed since it would end up being sandwiched between the steel boot grommet and the steel top washer during installation.
2012 Limited, 4WD, Classic Silver Metallic
2018 TRD ORP - Sold
2006 Sport Edition - Sold
03-26-2018, 03:06 PM
#767
So, I shouldn't have any issues with it being left in there?
2017 MGM TRD Off Road Premium
03-26-2018, 03:14 PM
#768
Real Name: Jesse
Real Name: Jesse
Heres my thought: if the plastic retainer was taking up a 1/4" or 3/8" whatever thickness it is, when it breaks or smashes, you will end up with a gap causing the shock to be loose. Anyone else thinking the same?
03-26-2018, 03:23 PM
#769
Bilstein technical said it would just be destroyed the second there is any load on the shock and the retainer would come out in little pieces immediately. There shouldn't be a gap if something is pushing down on it, I mean it's literally the thickness of 2 business cards.
03-26-2018, 04:06 PM
#770
I'd venture to say the same. The rubber isolators compress more than the thickness of that, so it wouldn't really technically be loose. Worst case, just stick a wrench up there on the top nut and make sure it's still relatively close to 18 ft-lbs. of torque.
2018 TRD ORP - Sold
03-26-2018, 05:54 PM
#771
Here’s a photo that shows the plastic washer on one of them. I’m thinking it doesn’t need to be there?
The plastic washer needs to be removed. If you go "bootless" you need to press out that metal washer and reuse from what I've read.
03-27-2018, 10:12 AM
#772
I am going to go ahead and install mine with it in place, worst case scenario I have little plastic pieces fly out when I put the truck back on the ground.
03-27-2018, 01:10 PM
#773
Originally Posted by Strokin99
I put the 5100's all the way around with the front setting at 1.75. It set my 2016 perfectly level. Took about 4 hours by myself on the install of all 4 shocks.
Did you install any spacers in the back?
03-29-2018, 02:02 AM
#774
Originally Posted by SoFloT4Run
If you don't mind, can you please share your floor to fender measurements on the front and the rear?
Thanks
36in front. 37.9in. Rear. You can probably get away with not trimming if you lower the caster a bit. I didn’t mind trimming a little off...can’t even tell lol.
2017 TRDORP White | 275 KO2 on Stock Rims | Stock Stereo with JBL GX302/GTO638/938, Kenwood KSC-SW11 | DDM 35W HID Ultra | Shrockworks Step Sliders | FR 5100s @1.75 RR Daystar 1.5 | Victory 4x4 Rack
03-29-2018, 01:32 PM
#775
Real Name: Andrew
Real Name: Andrew
I am new to this forum, so forgive me if I am not doing this correctly. I just bought a 2011 Limited 4WD. the Xreas shock are all leaking. after going through this forum as much as I can, I have discovered the for a TFR that is used primarily on pavement, that the Bilstein 5100's are the best replacement (Or at least very common) for Xreas. but I can not find an answer to this question. Can I use the stock springs and simply remove the Xreas, and Install Bilstein 5100's? I am thinking I can, and I also would use the 5100's to lift the front by using the second setting on the holstein 5100. Can you help a newbie out?
03-29-2018, 02:00 PM
#776
Are you using the search function at the top of the page? If you do a search for "XREAS replacement" or the like, I think you'll find that your exact question has been addressed many times before.
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
03-30-2018, 07:31 PM
#777
Thanks!! The truck looks great! U mentioned that you used a daystar 1.5 spacer for an FJ Cruiser in the rear?
Is the FJ Cruiser spacer different from the 4runner?
Also, do you have more side pics of the whole truck?
Thanks again
2WD-2014 SR5
JBA UCAs
Front - Bilstein 6112
Rear - Dobinsons GS59-705 and C59-505 rear coils
18x9 VTX Outlaw Wheels - P275/65/18 Wildpeaks AT3W
03-30-2018, 09:53 PM
#778
For the .85 setting, how urgent do you guys think it would be to get an alignment? Ideally, I’d like to head straight to the shop after the install, but I’m wondering what if I do it on say Saturday and then have to drive somewhere on Sunday when a shop isn’t open? Or what if the shop can’t get me in for a day or two? Just trying to plan ahead so I’d like to hear your thoughts!
2018 TRD ORP - Sold
03-30-2018, 10:08 PM
#779
For the .85 setting, how urgent do you guys think it would be to get an alignment? Ideally, I’d like to head straight to the shop after the install, but I’m wondering what if I do it on say Saturday and then have to drive somewhere on Sunday? Or what if the shop can get me in for a day or two? Just trying to plan ahead so I’d like to hear your thoughts!
I have it installed at a shop. The initial alignment reading is not far from spec at all.
2012 SR5 4x4 Blizzard Pearl
03-30-2018, 10:16 PM
#780
Yes !! Also goggle search bar
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
