Originally Posted by rowdydaoudy
Anyone have advice on the 5100 set up versus PTR13-35140 (FJ TRD set up)?
While I have no personal experience with the FJ kit, it is considered a more premium setup than straight 5100s: new springs, bigger shock bodies, remote reservoir on rear shock, etc. I strongly considered going that route but, in the end, decided against it for the following reasons:
Price - slightly cheaper to go with 5100s, although the FJ kit could be considered a better bargain for what you get. The $200 difference isn’t huge, but it’s still there.
FJ Parts - the parts are different on the FJ kit than the T4R PRO kit. Why is this? The answer is that nobody knows. Springs are different, and all shock numbers are different. If this was an ideal setup for the 4runner, I’d think Toyota would’ve used it. We know Toyota likes to use the same parts across multiple vehicles, so this never sat quite well with me.
Replacements - when you get down to it, both the 5100 and FJ shocks are wear parts. Sometimes they last awhile and sometimes they don’t. When a 5100 goes out, you know you’ll be able to easily find a replacement at a reasonable price. I don’t think this is the case with the FJ shocks, since I’m sure replacements are quite costly and getting your hands on it won’t be as easy. Additionally, the 5100s have a lifetime warranty, whereas the FJ shocks don’t...actually if used on a 4Runner, they probably have no warranty, assuming you’re honest about it.
I wanted about an inch lift on the front so either option would’ve worked for me in that regard, but the 5100 also offers more built in flexibility for lift height.
Either way, I don’t think you can go wrong with the 5100 or the FJ kit. The 5100 just made more sense to me sense to me, and I’ve been very satisfied with their performance so far. Time will tell on durability, but I’m not concerned because they have a good reputation.
