Old 07-12-2011, 10:41 PM #1
-JD-'s Avatar
-JD- -JD- is offline
-JD- is on a distinguished road
-JD-'s Avatar
Anyone gone with an Old Man Emu OME lift?
Just looking for opinions/reviews on this lift. I've really liked what I've seen and read about OME stuff on other vehicles. Just wanted to know how it was on the t4r. Haven't been able to find much info so far tho....
-JD- is offline   Reply With QuoteReply With Quote
Old 07-12-2011, 11:44 PM #2
sandcrawler's Avatar
sandcrawler sandcrawler is offline
sandcrawler has a spectacular aura about sandcrawler has a spectacular aura about
timely question. ARB 4Runner build.
10 TE - salsa, KDSS+JBL+Nav
ICON XT COs (+IVD) & tubular UCAs • ICON rear coils & 2.5 remote reservoirs + shin guards • Shrockworks • FN Five Star + 285/70 Mickey Thompson MTZ • TRD CAI + aFe Pro Dry S • Magnaflow • ARB diff breather • rack delete + Thule • H9 lo, 9011 hi, selective Y fog • FJ shifter • ScanGauge
06 SE, galactic gray V8: sold // 93 SR5, lots of rust, salt, & mods: R.I.P. // 71 FJ40, never should've let it go
sandcrawler is offline   Reply With QuoteReply With Quote
Old 07-13-2011, 10:17 AM #3
Airwolf's Avatar
Airwolf Airwolf is offline
Airwolf is on a distinguished road
Airwolf's Avatar
As soon as the front shocks come in from Wheelers mine will be installed hopefully the 25th. I went with 884 front and 895E rear with their nitrocharger shocks. I was going to keep the stock shocks but got worried I would be paying "twice" for the install so I dropped the coin to do it right the first time. Seeing my off-roading is a minimum and I just wanted a more aggressive looking runner I went with OME and saved a few hundred over other lift kits. When finished I will post the pics and give a review.
Mike S.
2020 TRD PRO Army Green
2011 Metallic Gray SR5 3" Lift - SOLD
Airwolf is offline   Reply With QuoteReply With Quote
Old 08-18-2011, 06:55 PM #4
-JD-'s Avatar
-JD-'s Avatar
So, i still haven't been able to get a definitive answer on this....
Can ANYONE running this lift please comment on whether or not you replaced your UCA's (upper control arms)?
Old 08-18-2011, 07:22 PM #5
thebwlife's Avatar
thebwlife thebwlife is offline
Real Name: Jordan
thebwlife is on a distinguished road
thebwlife's Avatar
Real Name: Jordan
I've done quite a bit of research on OME stuff for the 2010+ 4Runner and I haven't seen anyone do UCA's.
Here is some of my info.
Info on OME lifts
I can't wait to see this, i was debating this or doing 5100's @ 2.5" w/ 895e's, thanks for testing this out for me.
thebwlife is offline   Reply With QuoteReply With Quote
Old 08-18-2011, 08:10 PM #6
Airwolf's Avatar
Airwolf's Avatar
Lift is in and wheels/tires will be installed Monday (Fuel Throttle 17x9 and 285/70 Nitto Terra).
As far as the lift goes, here is the run down:
I installed 884 springs on the front and 895E on the rear, with Bilstein shocks all around. Wheelers just could not get them in...
Ride is a little stiffer then stock, with less nose drive on braking. It actually feels pretty good.
Stock height was 34.5" front and 36" rear (ground to fender edge).
Now 38" front and 38.5" rear drivers side, passenger side sits a touch higher.
My alignment numbers weren't to bad, seeing I did not do UCA.
Camber is 0.1 both sides, caster is 1.9 / 2.0 (wanted more just not any adjustment left) and toe is .03 / .04 (total toe .07). Steering feels better then stock, so who knows what the numbers were from the factory!
I am sure UCA's would bring the caster numbers into (or better) spec but this will not cause any "strange" tire wear, just maybe not track as well as it could, but to be honest, it feels better then when I drove it off the lot. pics of how it looks now are in my album.
Stay tuned for Monday evening pics and posts!!!
Mike S.
Old 08-18-2011, 09:44 PM #7
-JD-'s Avatar
-JD-'s Avatar
^Airwolf, are you going to get it re-aligned on monday when you put wheels/tires on?
Old 08-18-2011, 10:20 PM #8
thebwlife's Avatar
Real Name: Jordan
thebwlife's Avatar
Real Name: Jordan
Bilstein 5100's? No lift setting on the Bilstein's?
Also why didn't you go with the OME shocks that are set for these springs?
Old 08-18-2011, 10:34 PM #9
Airwolf's Avatar
Airwolf's Avatar
I wanted to, but waited 2 weeks to receive them but still could not get an answer when they would be in, so the Bilstein's were it. I wanted to make sure the rear shocks had the additional travel from the 2+" lift and they filled the bill. I like the ride and the silver Bilstein look pretty nice compared to the yellow unobtainum nitro shocks. I had to cancel my first appointment and just could not wait any longer for them (may still have been waiting for all I know) If the OME shocks are better then what I have then it's my loss... Just would have a hard time believing it, besides, I actually SAVED $$$ going with the Bilsteins!!! And yes, the fronts are set at the lowest setting, no lift.
Mike S.
Old 08-18-2011, 11:06 PM #10
Whistler RKT's Avatar
Whistler RKT Whistler RKT is offline
Whistler RKT is on a distinguished road
Yes, OME 885/889 & Nitrochargers, no to after market UCA's.
1999.5 SR5 Fox 2.5 Coilovers Fox 2.0 shocks with Land Cruiser Coils 285 Duratracs Accidentally ended up with 4:30 diffs ARB Bumper Thule Rack Yakima Mega Warrior Basket Weathertechs all around Saving for the winch and sliders...
Whistler RKT is offline   Reply With QuoteReply With Quote
Old 08-19-2011, 12:24 PM #11
wdlsmaerw's Avatar
wdlsmaerw wdlsmaerw is offline
Real Name: Woody
wdlsmaerw is on a distinguished road
wdlsmaerw's Avatar
Real Name: Woody
Getting mine installed on Monday. 887s on front, 898s on back. Staying with stock 265/70/17 for a few more miles (and until I pay for the lift). I will get some pictures up soon after that.
And the alignment comes with my labor charge.
2010 SR5 :: Blizzard Pearl
OME 3" Lift || Nitto Terra Grappler 285/70/17 || Debaged || Yakima PowderHound 6 || Addicted Offroad Sliders || Antman's rear stoarge box || Kappa 32.9 front speaker mod || Fiamm El Grande || Removed front air-dam || GPS hardwire behind dash || Rocky Road Adventure Rack || Midland 75-822 CB Radio hardwired w/ 4ft Firestik || IBS Dual Battery System || Sound Ordnance B-8PT Powered Sub || Satoshi (adio3x) Grill || BudBuilt Hidden Front winch w/Smittybilt X20 10 Synthetic || Mods/Toys in the works: Rear bumper, Roff rack, rear gate speakers, Rosen head unit, more money!!!
wdlsmaerw is offline   Reply With QuoteReply With Quote
Old 08-22-2011, 07:48 PM #12
Airwolf's Avatar
Airwolf's Avatar
Done! The ride is very nice, not harsh and not floaty (is that a word?).
Very happy I went with the springs and shocks.
Mike S.
Old 08-22-2011, 08:00 PM #13
thebwlife's Avatar
Real Name: Jordan
thebwlife's Avatar
Real Name: Jordan
looks great, make sure you put your lift stats in your signature or guys like me will be asking you all the time what kinda lift, springs, shocks, tires, etc., you have.
Old 08-22-2011, 08:32 PM #14
Airwolf's Avatar
Airwolf's Avatar
Good call.
Mike S.
Old 08-22-2011, 10:18 PM #15
wdlsmaerw's Avatar
Real Name: Woody
wdlsmaerw's Avatar
Real Name: Woody
Got it back from the shop, rides a lot nicer than stock, I really enjoy not having it dive every time I come to a stop. It was dark when I got home so I will get pictures up soon.
Daystar 2.5/1.5 lift (newer easy version) - exact height of lift? BigEd 4th Gen T4Rs 1 05-06-2011 11:10 AM
3" Suspension lift- What size Body lift for 35x12.50's? BB6-213 3rd gen T4Rs 10 11-23-2010 10:18 PM
WTB: Spacer lift kit, body lift, diff drop kit for 2007 4Runner deedubb Want to Buy/Trade 0 05-12-2010 11:45 PM
mixing daystar front lift with rear lift spring??? hdoggie24 3rd gen T4Rs 2 04-27-2010 01:52 PM
Why NOT to install a body lift or use inferior lift products Sac State 4th Gen T4Rs 6 05-05-2005 03:23 PM
