Thread Tools Rating: Thread Rating: 26 votes, 2.35 average. Display Modes
Old 04-28-2016, 10:43 AM #46
CoMtn4Runner's Avatar
CoMtn4Runner CoMtn4Runner is offline
CoMtn4Runner is on a distinguished road
Also my plan down the road. I will be interested in hearing what you land on when the time comes. I agree on enjoying the set up for now since I just installed the 5100's/spacer recently.
Originally Posted by mybabydaddy View Post
I, too, will eventually most likely remove the rear spacers and replace the coils to lift, along with front coils to do the lift up there as well (while putting the front shock settings back to normal height)... thereby getting my lift all in the coils, and not by using spacers or pre-loaded shocks. But I’m not in a hurry, and have much more research to do on it first.
Cement 2013 TTSE FJ
Silver 2012 TE
CoMtn4Runner is offline   Reply With QuoteReply With Quote
Old 04-28-2016, 12:32 PM #47
spawn's Avatar
spawn spawn is offline
spawn is on a distinguished road
spawn's Avatar
Yep. 1.75 front with 1 inch rear spacers gives it a nice stance (lessens the factory rake), but doesn't really affect DD (that I've noticed anyhow).
Is your rear suspension stock or replaced witj Bilstein too?
Sent from my SAMSUNG-SM-G935A using Tapatalk
spawn is offline   Reply With QuoteReply With Quote
Old 04-28-2016, 02:53 PM #48
mybabydaddy's Avatar
mybabydaddy mybabydaddy is offline
mybabydaddy is on a distinguished road
I replaced all four shocks with Bilstein 5100 at the same time. I doubt it would have made a huge difference even if I hadn't, but I figured why the heck not since I was already popping things off to install the spacers.
2017 Porsche Macan GTS - Carmine Red w/ matching side blades
2014 Black TEP w/ KDSS / nFab steps / Yakima Cross Bars / Bilstein 5100s (front at 1.75) / 1 inch rear Cornfed Spacers / FN Countersteer Type X / Nitto Terra Grappler G2s 265/70/R17 / RCI Aluminum (front) Skid - sold
2011 Silver Limited - sold
2007 SE Shadow Mica - sold
mybabydaddy is offline   Reply With QuoteReply With Quote
Old 04-28-2016, 03:11 PM #49
spawn's Avatar
spawn's Avatar
Thanks for the info. I just ordered Bilstein 5100 front. I might get the cornfed and leave the rear stock.
Old 04-28-2016, 05:11 PM #50
Rhino11's Avatar
Rhino11 Rhino11 is offline
Rhino11 will become famous soon enough
Rhino11's Avatar
There would be no need to hold off on an alignment until replacing the rear shocks, would there? I plan to do front 5100s and rear spacer only at first.
2011 T4R SR5 premium- Magnetic Grey
Suspension: Dobinsons heavy duty suspension with JBA upper control arms l Tires and Wheels: 285/70R17 Nitto Ridge Grapplers on Level 8 MK6 17x9 -12 l Armor: Coastal Offroad front and rear bumpers, LFD Offroad full roof rack and wide skid, RSG Sliders l Other: 23Zero Walkabout 72, Spyder Auto headlights, Warn Evo VR 10s l Coming Soon: ?
Rhino11 is offline   Reply With QuoteReply With Quote
Old 04-29-2016, 08:42 AM #51
No, I wouldn’t hold off. Any time you mess with the front suspension, most will tell you to get an alignment done as well. Even if it drives straight, usually good to get it done anyhow.
Old 04-29-2016, 03:02 PM #52
Rhino11's Avatar
Rhino11's Avatar
Awesome. Thank you! Adding the rear shocks shouldn't change things to where I would need another alignment either, correct?
Old 04-29-2016, 03:07 PM #53
This. I luckily was able to get it in the next day and had only driven 20 miles prior to the alignment. My tires would have been roast had I had held off from getting the alignment.
Cement 2013 TTSE FJ
Silver 2012 TE
Old 04-29-2016, 03:45 PM #54
karmatp karmatp is offline
karmatp is on a distinguished road
Great info in this thread for a 4 runner newb. Thanks to all who posted.
karmatp is offline   Reply With QuoteReply With Quote
Old 04-29-2016, 06:41 PM #55
4runnerFreakz 4runnerFreakz is offline
4runnerFreakz is on a distinguished road
Confused
Ok so I know this has been asked here million times, but the more I read the more I am confused, so I will go ahead and ask the question again.
I have 2014 TE. Ordered 5100s Bilsteins for all 4 corners as well as TRD pro rims (springs and everything else is OEM). I am looking to do the install next week and will be running original tires for now.
My 4runner is sitting 34.5" in the front (measured from level ground to the top of the fender) and 37" in the back.
I just want to have it leveled. Online it says that the highest setting on the front Bilsteins provides 2.5" lift, so how come you guys are saying that with the highest settings it will have a reverse rake (34.5 + 2.5 = 37 no??)?
I am not sure what the heck I'm missing, but one thing for sure is that I want to do this once and get it right. I can put rear spacers on while at it, but really would prefer not to do that.
Sorry for being a rookie and appreciate the help.
4runnerFreakz is offline   Reply With QuoteReply With Quote
Old 04-29-2016, 07:22 PM #56
Lawaia's Avatar
Lawaia Lawaia is offline
Lawaia is on a distinguished road
Lawaia's Avatar
With the 2.5 setting, your fenders will be level, but the body will have reverse rake.
Lawaia is offline   Reply With QuoteReply With Quote
Old 04-29-2016, 07:36 PM #57
Confused
So I am best of going with the 3rd setting (1.75") in front and nothing in the back for more leveled look?
Old 04-29-2016, 08:03 PM #58
Lawaia's Avatar
Lawaia's Avatar
As previously noted earlier in this thread, the consensus seems to be:
for Bilstein 5100's all around:
.85 front, no lift rear
1.75 front, 1" spacer in rear
2.5 front, 1.5" spacer in rear
still haven't done mine yet, but I'm going to do the 1.75 front, 1" spacer in rear
Old 04-29-2016, 09:06 PM #59
This. You can get away with stock size tires with the first two options but I would suggest bigger tires with the highest setting.
Cement 2013 TTSE FJ
Silver 2012 TE
Old 04-29-2016, 10:27 PM #60
.85 front and stock rear will still have slight rake...
1.75 front and stock rear will level your fenders but actually give you about 1/4 inch negative frame rake
1.75 front and one inch rear spacers will give you same rake as .85 front and no spacers, but lift the ENTIRE truck up a little thereby giving you a slightly lifted look (see my pics)... Still okay to use stock tires IMO.
2.5 front with stock rear will definitely give you negative rake (think off-road racing truck)
2.5 front with one inch rear spacer will give you the fairly level look, but LIFTED, thereby probably making the stock tires look a little small
2.5 front with 1.5 inch rear spacers will yield a little normal rake with a nicely sized lift... Def make the stock sized tires look (too) small.
Wouldn't recommend doing any 2.5 front settings without considering going to larger tires... But that's just my 2 cents...
Another Bilstein 5100 set-up question(s) westwind77 5th gen T4Rs 128 07-09-2021 07:18 PM
OME+Bilstein 5100 question Rancid13 4th Gen T4Rs 57 03-18-2018 02:35 PM
Bilstein 5100 question ahagin107 3rd gen T4Rs 5 11-06-2014 02:02 PM
Bilstein 5100 question 4runnerAzGuy 4th Gen T4Rs 14 12-02-2013 05:36 PM
