Originally Posted by Medic5443
I am getting ready to pull the trigger on a Bilstein 5100 set up with the 1" Cornfed spacer in the back. I will eventually put my winch on along with a Southern Style Offroad bumper. I like the look of the 1.75" in the front and 1" spacer in the rear, but I do not know how much a winch and bumper will make the front end drop.
Any info or suggestions?
May look into the Dobinson spring route with the 5100s. I'm definitely no expert but here is the setup that others are using:
Dobinson
Front:
C59-300 - Stock front end load, 1.75" lift. 385/385mm, 17mm wire, 586LB
or
C59-302 - 100-220LBS heavy load front weight, 2" lift. 395/395mm, 17mm wire, 586LB
Rear:
C59-599 - Stock rear end, 1.0" lift (keeps rear end low, allowing to level the vehicle rake with 2" front lift). 390/390mm, 17mm wire, 220LB
or
C59-505 - Stock rear end load, 1.25 to 1.5" lift. 405/405mm, 17mm wire, 220LB
You can always email them as well.
