Originally Posted by SR52011
That's exactly what I'm doing on my first lift. Just not going as smooth as it should be. Did you have to get UCAs to get the proper alignment since the camber will be off or will a quick alignment correct the camber?
Thank you for all your great information.
I’ve been running stock UCAs with no issue. I’ll have to find my last alignment report but I’m within .2 degrees of spec with most adjustments exactly on point. I’ve had zero issues with odd wear or drive-ability. I’m running 285/70-17 Falken Wildpeak MT01.
Over these past 6 years, I started at .85 being my first lift and of course was hooked to off roading. Went 2.5/1.5 very quickly thereafter. I off-road several times a year. I tow a lot. I use the truck as a truck. I went this route because it was cheap and conservative and again, everything refuses to break or quit. This has easily been the absolute best bang for the buck I’ve ever done on my Runner.
