04-03-2016, 07:26 PM
foglight mod for 2014+???
Someone please tell me you have a write up to do this mod, wanting to do this to my 15 sr5
98 limited-3" body lift, toytec/eibach, toytec superflex, bilstein5100, spc uca, 285/75/16 nitto trail-grappler, 16x8 procomp 7031, 1.5" spider trax wheel spacer, elocker, b&m transmission cooler, Isr and deck plate mod, satoshi grill, 30" led bar, plasti dip front/rear bumpers and fender/cladding,
04-03-2016, 07:44 PM
We obviously need more information before anyone can help you.....
Auxiliary fog lights, Dual function LED fog lights with DRL, Morimoto direct replacement LED fog lights, just putting another ole' bulb in your fog light housing, putting LED's in your fog lights?????
See there are numerous ways and numerous answers!
Best Regards,
Saker
04-03-2016, 11:05 PM
Installed mine last night
04-04-2016, 12:59 AM
As in running fog lighs when parking lights are turned on not just when headlights are on
04-04-2016, 04:02 PM
Real Name: Chris
Real Name: Chris
I also have one here, just more of an extension of Antman's. Because yours is newer, you'll need to double-check the wiring to make sure its the same as the older 5th gens wiring.
Super easy if you don't mind not having the green foglight led in the dash when the lights are turned on.
2011 4 Runner (my daily driver)
1987 Xtra Cab (35's and locked front/rear, the trail toy!)
1985 Supra (430rwhp track toy!)
2006 Honduh Odyssey (the wife's van)
04-04-2016, 06:22 PM
Honestly i was just gunna get a h11 wire harness and tap the power to the tail lamps and get a aftermarket push foglamp switch with it, seems like it would work, but if i could find a way to use the factory switch and without having to get another harness that would even be better, i guess ill oneday open up my dash and check if the wiring is the same as the earlier model 5th gens
04-04-2016, 07:33 PM
Real Name: Chris
Real Name: Chris
If you're good with wiring, then all you need is a relay and some wire, here's my diagram for wiring it in:
If you wanna go the extra step and getting the fog led in the dash to work, you'll need a 12v green led too. This will allow you to have it wired to parking lights for power, and if you don't wanna screw with the stock switch, then just add an SPST switch in the dash somewhere!
Make sure to take pics and notes for the newer guys if its not the same!!!
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
