04-05-2016, 02:41 PM
Ride height is way off
Hey guys,
Quick question and some help, I have a 2014 Trail Edition and the ride height in the back is off by a pretty significant amount. It's visually different. On the rear left you can see behind the wheel well and the leaf spring system while on the right, you can't see the leaf spring system. The truck is currently at Toyota and of course they're telling me that while there is a difference in height by a bit more than half an inch, it's "within measurement limits". While i understand the range of limitation, I've never seen another 4Runner sit like this, nor is there a 4Runner on their lot that sits like this. There is also a clunking and creaky spring sound coming from the back of the truck any time i go over a speed hump or imperfections in the road. The back of the truck also bounces independently on each side (if that makes sense?), for example, going over a speed hump evenly the back left and back right bound/rebound independently giving a back-and-forth feeling like if i approached the speed hump at an angle.
Has anyone had this experience with their T4R or have any ideas or input? It's not lifted, everything is stock, and it's always been stock. I really don't feel this is normal or common. I'm supposed to go to toyota at 2:30 to talk to them and do a ride along.
Thanks for any help you can offer
2014 MGM TE Premium w/ KDSS
2012 Red VW Golf R 4D
04-05-2016, 02:49 PM
Lots of intelligent guys here. You'll get better responses than mine, but:
1 - no leaf springs on the 4Runner. It's a rear coil spring and 'track bar' or panhard bar setup.
2 - you say its stock. I assume that means no lift, right? Does it have KDSS? The odd behavior COULD be explained by a broken suspension link but if it's at the dealer, and they are looking, they SHOULD spot that. It could be a blown shock. How many miles?
3 - a half in or so of height difference is no big deal. It's the '4Runner lean' most often described after lifting and with KDSS. I wouldn't worry about the difference too much.
2015 Trail Edition w/ KDSS, Super White, Toytec Ultimate Lift, Airlift Airbags, 255/80/17 Cooper ST Maxx, RCI aluminum skids and bumpout sliders, H9/9011 Headlight Mod, Rear Diff Breather Mod, Homemade Roof Rack, Katzkin leather interior
04-05-2016, 02:54 PM
Real Name: Juan
Real Name: Juan
Originally Posted by VoodooTitan
Hey guys,
The odd thing is, the "lean" is suppose to be towards the driver side.
could be either a broken link, or a damaged/broken spring maybe? the other thing that can be easily overlooked, tire pressures...
2014 T4R Super White Trail Edition a.k.a Donkey - Shrockworks Sliders, Shrockworks Front Bumper, Shrockworks Skids, Shrockworks Rear Bumper, Gobi stealth rack, OME Lift (FC 2887/RC 2898), 285/70R17 KO2s
Instagram
04-05-2016, 03:02 PM
Banned
Banned
Park on a flat surface and measure from the frame to the ground in the same location on each side. What is that difference?
04-05-2016, 03:08 PM
It has KDSS, yes.
04-05-2016, 03:10 PM
I just had it serviced Thursday and tire pressure is good all around. I'll try and get more pics to show what I mean. I don't think it's tire pressure tho
04-05-2016, 03:12 PM
Originally Posted by HerT4R
we have leaf springs?
No I guess not, thanks for first comment making my concerns invalid and feeling like an ass.
What I meant was the frame that sits behind the wheel well. I'll correct this verbiage so I can get more helpful responses tho.
04-05-2016, 03:23 PM
Banned
Banned
no need wasting your time trying to guess and estimate with photos
do this and post the results:
1. park on flat surface
2. measure straight down from the frame rail to ground from some point near one rear wheel
3. on the exact same point on the other side of the vehicle measure straight down from the frame rail to the ground
4. post results
04-05-2016, 03:28 PM
4. post results
Where is the frame rail?
Thank you.
04-05-2016, 03:33 PM
Banned
Banned
don't have a clean pic, but it's this thing:
*for demonstration only, not sure what truck this is
kinda curves up over the rear axle
Reason: *
04-05-2016, 03:36 PM
Ok I'll measure it, I should have measurements soon, I'm pretty sure tho the frame is ok and level. it's so strange and it sounds crazy but it's like the body of the truck itself isn't sitting flat on the frame. I'll post the measurements once I get to Toyota.
04-05-2016, 03:40 PM
It has ~34k on it. Services on time, never off road, routine driving in California.
04-05-2016, 03:41 PM
When did you first notice? Is it a recent thing? Did you notice the suspension clunkiness before you noticed the lean? My has appeared to lean at times, but when parked in my flat garage it does not. I had pretty significant lean to the right after installing my lift (which again is odd because "KDSS lean" is usually to the left), but it went back to normal after my springs settled.
2014 Trail Edition Premium w/KDSS - 3" Suspension Lift - FOX 2.5 DSC Coilovers - FOX 2.0 IFP Shocks - OME 3" Springs - LR UCA's - Metaltech Sliders - XD Enduro Pro Wheels - 285/70r17 BFG KO2's - Kenwood 5 Channel Amp w/ JBL speakers and JL 12" W3V3 - K&N intake - HID low beams - TRS LED Fogs
04-05-2016, 03:48 PM
So I noticed it a while ago (a few weeks) but wrote it off because it was parked in my space in front of our house, the space has a handicap spot next to it and between the two spots is a "ramp". I attributed the lean to the 4Runner not being level.
The picture included was taken in a level parking garage at carmax. So I know it's level. Looking at it from the side you can well see more of the frame and some suspension components than the right side. It's constantly leaning, it doesn't resolve at all even when parked at an angle with the right side higher.
