04-11-2016, 10:14 AM
Dealership Oil Change - Total Time?
Tried to search this forum and couldn't find anything specifically related to my question. How long should it take a dealership to complete an oil change on a 5th Gen 4Runner?
I don't change my own oil for a few reasons, one the amount of money I would save would be negligible, two I have a bad back and shoulder, and three I like having the service logged in the computer under my VIN so I have a complete service history. However I hate how long it takes.
The first dealer I had been using would not schedule service and the last oil change took almost 2 hours of waiting at the dealer. I recently moved and the new dealer will schedule, but is quoting an hour. Is it wrong to believe that this shouldn't take more than 30-45 min tops? Don't want to go to a Quicklane, but at least they get you in and out quickly...
2013 MG SR5 4x4 - Stock
04-11-2016, 10:31 AM
short answer: how long? too long! haha. a 2 hour wait seems normal to me, honestly. i'd rather spend my morning in my own garage, but i do understand your physical situation complicates it.
i'd definitely avoid any quick-lube joints. between dropping the skids and working with the canister filter housing it just seems far too likely they'd screw it up and you'd end up spending more time waiting at the dealership for them to complete some far more concerning repairs.
my 2¢.
10 TE - salsa, KDSS+JBL+Nav
ICON XT COs (+IVD) & tubular UCAs • ICON rear coils & 2.5 remote reservoirs + shin guards • Shrockworks • FN Five Star + 285/70 Mickey Thompson MTZ • TRD CAI + aFe Pro Dry S • Magnaflow • ARB diff breather • rack delete + Thule • H9 lo, 9011 hi, selective Y fog • FJ shifter • ScanGauge
06 SE, galactic gray V8: sold // 93 SR5, lots of rust, salt, & mods: R.I.P. // 71 FJ40, never should've let it go
04-11-2016, 10:34 AM
Moderator
Real Name: Greg
Moderator
Real Name: Greg
The actual oil change itself is 20 minutes. But there are other steps:
Initial drop off
Logged into database for appt
Documenting VIN
Documenting Mileage
Moving vehicle from check in to oil change bay
Changing oil, filter
Running engine to check oil level
Check for leaks
Grease and check fluid levels
Visual check on brakes and air filters (both cabin and engine)
Moving vehicle back to customer pick up
Paying bill
It usually takes 45 min to an hour at my dealer and yes, they do all those steps there.
04-11-2016, 10:45 AM
Real Name: Um, Phil?
Isn't there an annoying skid plate to deal with too?
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
Initial drop off
Documenting VIN
Documenting Mileage
Check for leaks
Paying bill
Thanks for the detailed response. Sounds like I'm being impatient, I'll stick with the appointment and hope it goes faster than the quoted time. Oil Changes rank with my least favorite things to do... so the idea of wasting an hour of my evening sitting in a car dealership is hard to accept.
04-11-2016, 10:47 AM
Yeah I definitely forgot they have to unbolt the skid to access the oil drain plug.
04-11-2016, 10:48 AM
..... and it's only once every 10K. (A comment which will undoubtedly take this thread OT).
04-11-2016, 11:03 AM
Absolutely a fair point, 10k means the oil change doesn't come up as often... but I still hate them, and don't want to waste anymore time than I have to sitting at a dealership when I could be doing anything else. I can get through an hour (hopefully less) but I will never go somewhere that doesn't take scheduled appointments again.
04-11-2016, 11:04 AM
Real Name: Ron
Real Name: Ron
My dealer usually takes about an hour and a half. All of the things listed by 1engineer plus a wash job. I make an appointment about three days in advance. I don't mind spending the time walking around checking what is displayed on the lot and chatting with a sales guy.
It's a very large dealership; plus it's a 45 minute drive each way into Reno. I generally enjoy the experience.
Totally stock 2013 SR5 4WD. Have added Toyo Open Country M/T LT 265/70-R17 (E) tires the first week I owned it. Added second set of Toyo M/Ts at 86900 miles.Added RCI OFF-ROAD Rock Slidersat 84000 miles. Added RCI OFF-ROAD front skid plate at 90,000 miles. Daily driver and so far spending about 30% of time/mileage off-road. Previous truck 2004 Land Rover Discovery that also spent about a third of it's life off-road. I HANG AROUND HERE "THE T4R FASHION FORUM" JUST FOR LAUGHS.
Perfect vehicle as it stands for northern Nevada terrain. Keep it stock - it'll go most anywhere as is.
04-11-2016, 11:11 AM
My local toyota dealership in Utah - I just went there on Saturday. I was a bit late - 17.5k miles for my 15k service so they just did the oil change with the late 15k service and then I'll change again at 25k and go every 10k from there on.
It took about 30 minutes from when I drove up until I drove away. Not too bad.
The dealership I bought from in Montana is a bit faster. Their lube/service shop will do the oil and tire rotation while you sit in the car. It's a team of 3. One in the engine bay, one in the pit below, and one person at the window of your car. Takes about 10 minutes and you never get out of your car.
At the Lexus dealership it takes about an hour. I usually go check out the new models and they have food and coffe/soda so I usually grab a snack while I'm there.
04-11-2016, 11:39 AM
I just had service performed and from the time I pulled up in the service bay to driving off the lot was about 40 minutes.
04-11-2016, 12:02 PM
Real Name: Jim
Real Name: Jim
Mine takes around an hour. Not bad once a year as I don't rack up the miles like I used to, and killing the time looking at the new trucks is fun.
Lovin' my 4R
04-11-2016, 12:03 PM
I prefer they take their time and do it right. I don't mind the wait.
2014 Black SR5 4x4 - 285/70/17 Falken M/T, C4Fab Gas Tank Skid, RCI Steel Engine/Trans Skid, Shrockworks Sliders
https://www.youtube.com/user/Locked32114
04-11-2016, 12:17 PM
Im fortunate my dealer is 5 minutes from my work. I schedule a week out, drop off, get shuttled to work, and then either catch a ride with a coworker or shuttle back when service is done. They seem to let me know its ready within an hour of when appointment is set up for. I do hate to wait there and I cant even look at new vehicles because the service department is a block down the road across a very busy intersection.
"I bet you're one of those guys that never takes these things off road."
-Some guy who liked my T4R but drives a Hummer...probably
04-11-2016, 12:22 PM
I absolutely agree, was trying to figure out how long it would take a competent tech to perform an oil change. I could certainly go to a smaller lube shop and get a cheaper quicker oil change but I prefer the peace of mind that comes with taking it to Toyota.
