04-13-2016, 11:33 PM
#31
A lot of good feedback here. I am considering all options. The portable would be nice and something I could leave at home if needed.
I don't have easy access to CO2 so that option is on the back burner.
I like the idea of using the AC unit but would have no clue how to rig it... .
I will defiantly look into the portable models mentioned in the thread.
Again, it will be some time before I pull the trigger because things are very busy here and I do a ton of research before buying something.
All of the feedback is very much appreciated.
Glad so many have shared their experiences. This forum played a huge part in my purchasing a TE over any other model. It's always good to hear what you guys are doing to your rigs.
'16 MG TE - Leather Seats - Bilstein TRDPro Tuned Suspension - 265/70 17 Nitto Terra Grappler G2's - GGACC Club Patch - Patagonia Fitz Roy Trout
04-14-2016, 07:16 AM
#32
You don't have any welding gas suppliers near you???
04-14-2016, 07:59 AM
#33
Originally Posted by Jono.ful
Have to be careful with mounting below deck. No matter what sort of coating your tank has you will eventually run into rust issues, and unless you have a swing out tire carrier, there really isn't a whole lot of room underneath. I have seen them done behind the front bumper, but underhood or in the cargo area are the best options I've seen.
I've had the tank under my 80 since 1996 and its still in great shape. I am in the Northeast and that thing gets a 4 month salt bath every year.
My Build Thread
www.AnytimeBackupCamera.com
2011 4Runner Trail loaded w/KDSS
1992 Land Cruiser
04-14-2016, 08:10 AM
#34
Real Name: Kevin
Real Name: Kevin
Originally Posted by Jeremy556
The ARB twin compressor is what I would use if I were to do my air setup over again. I have dual Viair400s now with basically the same CFMs, but it ended up being more expensive, time consuming, and takes up more space.
On paper at least, the Viair dual 400C kit is a couple hundred less than the ARB twin compressor. What'd you run in to that made your Viair setup cost more?
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
04-14-2016, 09:20 AM
#35
You're lucky then. I've seen pc viair tanks rusted nearly beyond recognition here in Alberta after only a year
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
04-14-2016, 12:02 PM
#36
just to make it easier.
Amazon.com: Smittybilt 2781 5.65 CFM Universal Air Compressor: Automotive
like you, I do a lot of research prior to purchasing. for the money, I didn't find a 12v compressor better than that one. knowing full well going in, its made in china "crap", I took a chance on it. I'm glad I did. its amazing, and I am impressed every time I use it.
they make a smaller version also, that's about half the output, for half the price. I got one of those for my dad, it works great also.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
04-14-2016, 02:01 PM
#37
Real Name: Charles
Real Name: Charles
Interesting, even at no load that seems like a very high output compressor for the price.
2014 Trail Edition Premium, 285/70/R17 BFG KM2, RadFlo 2.5" Coilovers and Rear Shocks, 50qt ARB Fridge, OTRATTW Switches, BudBuilt Bumpout Sliders, Gobi Rack + Ladder / 40" Rigid E2 /Rotopax and MaxTrax mounted, ARB CKMTA12, 270amp Alternator, Southern Style Slimline Hybrid Front Bumper w/ Warn Zeon 10S and Front Fogs, Metal Oil Canister, Sound Deadening Insulation w/ Focal Front Speakers,Black Weather Tech mats and custom pin striping & dents (the trees & bushes did it for free)
04-14-2016, 02:06 PM
#38
yes, and though I don't have the equipment to test it, I would guess it does put out the stated amount. it airs up my tires very quickly.
I tried timing it a few times, though just using my watch. but from 10psi, up to about 32 on my 35's, was around 15 minutes for all 4.
have also done my 35's, and my buddies 42's, back to back. no issues from the compressor. and it never got too hot.
time will tell, but so far its an amazing compressor for the price.
04-15-2016, 11:15 PM
#39
Mostly time involved with trial and error. Using different leader hose lengths, manifolds, check valves, electrical setups, mounting options, chasing leaks, finding the best thread sealants.
04-15-2016, 11:24 PM
#40
How big are the CO2 tanks?
I use a 10lbs tank. It fits perfectly behind the driver or passenger seat, even when the rear seats are folded. that locks it in place so it cant move. I just filled it up again earlier this week at a local welding supply store. It costs about $30 to refill, and that lasts me about a year. I also use it to refill a smaller Soda Stream tank for our kitchen.
'14 Trail Premium
06-11-2016, 12:32 AM
#41
Pulled the trigger on the Viair 400p. Wife got home and said... What is a portable compressor and why do you need one!?!
I really wanted the ARB on board but could not justify paying $500 for something I would use once or twice a year. Viair had good reviews and should fit the bill.
I appreciate all the feedback received on the thread! I'll post again when it gets some use.
06-11-2016, 08:15 AM
#42
I got the VIAIR 85p on Amazon for $49.95. Very small, nice carry bag, quiet and works well. Aired down to 20psi for some beach driving and it took, maybe, 3 minutes per tire to air back up.
06-11-2016, 11:47 AM
#43
Real Name: Max
Real Name: Max
ARB Single - Slee Bracket
Just installed my single ARB on the new Slee off-road bracket. It should be more than enough to air up after a day of wheeling, and it left plenty of extra space under the hood (and on the Slee bracket) for other accessories. I might use the extra space on the bracket for a Switch-Pro or Bussman panel.
06-11-2016, 11:53 AM
#44
I picked up the large smittybuilt from the local 4wp, with a 3 year warrantee for $20.
It was recommended on 2 occasions. Now I see why;
It's unbelievably fast.
The downside is the proprietary fittings. I'd much prefer the ARB inflator chuck.
But 5.65 cfm- unreal.
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
06-11-2016, 12:43 PM
#45
I really like ViAir products. Very solid and good value. I have a portable that moved into my daughter's Jeep when I got a 1/2 price deal on a big 480P and mounted it under the hood.
2014 SR5/P Bilstein 5100, BFG KO2, SSS Slimline Bumper, Goose Gear drawer system, ViAir OBA
