04-12-2016, 09:37 PM
Air compressor recommendation
Hello everyone,
I have recently purchased a '16 TE and one of the first mods I would like to complete would be installing an air compressor.
It looks like there is room to install a compressor under the hood, though I am not sure of what brand or model I should install.
I would like to hear your opinions and recommendations on which air compressor I should install.
Thanks in advance!
'16 MG TE - Leather Seats - Bilstein TRDPro Tuned Suspension - 265/70 17 Nitto Terra Grappler G2's - GGACC Club Patch - Patagonia Fitz Roy Trout
04-12-2016, 09:51 PM
In the list of mods posted by Antman is one titled "Onboard compressor install" That might be of help.
04-12-2016, 09:54 PM
The ARB twin compressor is what I would use if I were to do my air setup over again. I have dual Viair400s now with basically the same CFMs, but it ended up being more expensive, time consuming, and takes up more space.
04-12-2016, 10:55 PM
The mounting solutions are much better too... I'm still fighting my 400.
2014 Classic Silver TE w/ KDSS - The Waco Kid's Build and Adventure Thread
Wife's Ride: 2017 RX 350
Past Vehicle:2001 Dodge Dakota Sport 4.7L V8 Quad Cab.
04-12-2016, 11:07 PM
I have both of my 400s mounted to a piece of plastic cutting board, behind the airbox, mounted to factory threaded holes in the fender and a couple of aluminum straps attaching to the firewall and fender. Using extra long leader hoses for heat dissipation, leading to a manifold on the firewall that has pressure switch, leads to front and rear bumper quick disconnects, and air locker stuff, filter/water seperator, etc.
04-12-2016, 11:09 PM
The ARB twin (if I recall correctly) still has the highest flow out of any portable 12V compressor at more than 6 CFM @ 100% duty cycle. If you can swing the price it's the best bang for the buck.
@ bandi
makes a great mount for it by the passenger side firewall with some different configuration options (i.e. ARB 1 gal tank, locker manifold, etc.).
IG @go.xplre
04-12-2016, 11:33 PM
I have an ARB twin, I use it frequently. Great compressor. I would recommend getting a tank (I haven't gotten one yet) When you are moving from tire to tire and having the tank full to start will speed everything up.
At 7000'~ it takes me approx. 15 minutes (sometime faster when it's colder out) stop to start to fill 4 265/70/17 from 15 to 40 lbs.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
04-12-2016, 11:36 PM
Thanks for the info! It will be a couple of days before I can do the research on the ARB and look threw the recommended builds.
I am looking forward to modifying the truck. I will not be able to do anything crazy but little things like this I'm excited about.
04-12-2016, 11:53 PM
Just turn your ac compressor into your onboard air compressor. It takes up no more room and has the highest possible output and duty cycle, Plus you already have a switch on the dash for it. Make that your first mod and then custom full width axles + SAS up front for your second mod. Those are pretty much the first two mods most 5th gen owners do.
Seriously though, my opinion is onboard air is really overkill. Just do a portable it will meet all your needs and cost about 80% less and be way more versatile overall. Onboard makes sense if you have air lockers, but besides that it is along the lines of those 50" light bars in my opinion. Way more than you need. But it is your truck to do with whatever you please ;-)
04-13-2016, 12:48 AM
Real Name: Dave
Real Name: Dave
Portable air compressor
I agree with wfo9. The portable air compressor requires no installation and is more than enough. I have the Viair 400P Automatic stored in the canvas bag it comes with. I leave it out of the vehicle and leave it in the garage when it's not in use. Go to the Viair website to see the fill rates listed in the specs. I replaced the cheap coiled air hose that comes with all of these compressors with a better 3/8" flexible air hose and quick connect couplers at each end. It's easier to use.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
04-13-2016, 01:09 AM
Also with the portable crowd. Had and went through 2 of the bigger $50 harbor freight ones. Just upgraded to the $150 smittybilt one. The smittybilt one is nice.
2016 TEP// Non KDSS// 2.5" Icon RR Ext. Coilover with CDC// Total Chaos UCA// 2.5" RR Icon Rear shocks with CDC// Sway A Way rear coils// BFG KO2 285/70/17// Pelfreybilt Bolt on tapered kickout sliders// Method NV wheels Machined finish// Rci skids bare aluminum// Front Runner Slimline II roof rack with HI-Lift and Awning Mounts// ARB Awning// Hi-Lift Xtreme 48//Icon Rear Shock Shin Guards//Baja Designs Squadron-R Pro//Xenon Hid Headlights
04-13-2016, 01:23 AM
Originally Posted by Jasalvas
Hello everyone,
Thanks in advance!
I use a CO2 tank. It takes roughly 2 seconds for every 1 PSI to air back up. If you're going from 15 to 40, that's roughly 50 seconds per tire. Each tank of CO2 lasts me about a year. I can get back on the road very fast.
'14 Trail Premium
04-13-2016, 01:40 AM
How big are the CO2 tanks?
04-13-2016, 07:44 AM
PUMA Air compressor. Thing is a beast. Not the same cfm as the ARB but it comes in at half the price and comes with a tank and other goodies.
My Build Thread
www.AnytimeBackupCamera.com
2011 4Runner Trail loaded w/KDSS
1992 Land Cruiser
04-13-2016, 09:11 AM
another vote for a portable. you already have the rear e-locker in your TE, so unless you're seriously planning to install a new front air-locker you can put the considerable cash saved to better use in other functional mods.
10 TE - salsa, KDSS+JBL+Nav
ICON XT COs (+IVD) & tubular UCAs • ICON rear coils & 2.5 remote reservoirs + shin guards • Shrockworks • FN Five Star + 285/70 Mickey Thompson MTZ • TRD CAI + aFe Pro Dry S • Magnaflow • ARB diff breather • rack delete + Thule • H9 lo, 9011 hi, selective Y fog • FJ shifter • ScanGauge
06 SE, galactic gray V8: sold // 93 SR5, lots of rust, salt, & mods: R.I.P. // 71 FJ40, never should've let it go
