Originally Posted by 4RunnerINprogress
I have the bilsteins set at 0. The toytec springs will give about a 2.5in lift. I added the toytec 1/2in spacer to get to 3. The shop told me it's better than bumping the bilsteins up because it would make it bouncier. I also added the camburg uca.which you would probably need for anything over 2.5. I added the toytec 2" superflex in the rear. It is pretty much leveled. If you don't add the spacer in the front, I would probably get the SAW 1.5 or day star 1.5 to get leveled or else you will get a rake in the front.
Yeah they had to different toytec front springs. I opted to go with the 112-620, so ill be using the 2nd notch. I also went with the superflex for the rears. I just hoe it doesn't give the rake in the front. But with the amount of research I've done it should be good. Well see how it goes and see if this will look good and ride good as well. If not, gonna change the whole set up lol
