04-21-2016, 09:45 AM
MaxTrax and BajaRack Mount
I had on order from BajaRacks a set of MaxTrax and the rack mounts for them and an ax/shovel recently. I finally got in the MaxTrax and mount, but still waiting on the ax/shovel mount to be shipped.
Anyway, for those of you who are wondering, a standard basket (5" height) will clear most garages without a lift, but as soon as you install the MaxTrax mount, it adds additional height which may not. On my rig, the rear mount sits high enough that it bangs into the lower lip of the garage door when I pull it in. YMMV, but I figured I'd mention it.
Here's a pict of the MTs mounted:
https://drive.google.com/open?id=0B4...kRtU3RiUjFSTkE
Here's the mount height in my garage.
https://drive.google.com/open?id=0B4...lc1bjRUZG02U2M
04-21-2016, 10:15 AM
Real Name: Charles
Real Name: Charles
I know it eats rack space but why not mount them flat instead of on their side? Mine fit inside the Gobi rack, granted it takes up a lot of rack space but it adds little to no overall height and because your rack sides are much taller it wouldn't add any height.
Because of the height of your rack sides you actually may be able to put them perpendicular across the rack and just have a inch or two of the ends sticking out the rack sides. (essentially mount them how
@ LawnDart
has on his Gobi but yours would be on the rack bottom with the edge of the Tracks hanging out instead of on top of the rack sides). Mine are fully within the sides of the Gobi but to do that I have to mount then diagonally which took up essentially 50% if not slightly more of the rack floor.
Anyways, thanks for sharing the experience
2014 Trail Edition Premium, 285/70/R17 BFG KM2, RadFlo 2.5" Coilovers and Rear Shocks, 50qt ARB Fridge, OTRATTW Switches, BudBuilt Bumpout Sliders, Gobi Rack + Ladder / 40" Rigid E2 /Rotopax and MaxTrax mounted, ARB CKMTA12, 270amp Alternator, Southern Style Slimline Hybrid Front Bumper w/ Warn Zeon 10S and Front Fogs, Metal Oil Canister, Sound Deadening Insulation w/ Focal Front Speakers,Black Weather Tech mats and custom pin striping & dents (the trees & bushes did it for free)
04-21-2016, 10:16 AM
That is an odd way to mount them.. IMHO. I looked at those mounts and thought it would be problematic, so I made my own mounts and they sit flat on the rack. Obviously not ideal when loaded up with gear, but it works great 95% of the time.
04-21-2016, 11:04 AM
The biggest reason is access. Mounted on the side, I don't have to climb up onto the roof of my rack to access the MTs when I need them. Since BajaRack won't sell their ladder until Gobi gets off their nutts, I'm limited by what I can reach.
04-21-2016, 11:20 AM
Real Name: Dave
Real Name: Dave
I stand on my Domello rock sliders or the back tires to access the roof. I could use a ladder but only to reach the middle of the rack.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
04-21-2016, 11:27 AM
I don't have sliders yet. I'm limited to the tires or the back bumper, which, when carrying heavy gear (5G gas tanks weigh 30lbs each), isn't exactly the most stable platform.
Anyway, installing them on the side works for me at the moment. Easy to mount, easy to take off and use in a pinch, plenty of space left over on top. If the sacrifice is that I have to be careful pulling into the garage, that's the least of my worries.
