04-24-2016, 06:15 PM
Real Name: Danny
Real Name: Danny
Uneven wear on tires
Still trying to figure out my FOX adventure ... I am due to go over there and have them make them rights sometime in June... I will make sure to update the forum with feed back.. Me and a couple of the other guys on here have had issues with their FOX 2.5 DSC coil overs
with that said. I noticed that I have major uneven wear on my tires post the install. I'm not sure what is the deal, though I have had two alignments done after the install.
I called the tire shop to complain about the uneven wear and they mentioned it might be due to the suspension. What in the suspension could cause uneven wear on the inner walls of the tires?
Like i said, I have FOX DSC 2.5 with Camburg ball join UCA's
Pic for reference:
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
04-24-2016, 06:24 PM
Looks like too much camber to me
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
04-24-2016, 06:39 PM
Ball joints ?
2016 TEP// Non KDSS// 2.5" Icon RR Ext. Coilover with CDC// Total Chaos UCA// 2.5" RR Icon Rear shocks with CDC// Sway A Way rear coils// BFG KO2 285/70/17// Pelfreybilt Bolt on tapered kickout sliders// Method NV wheels Machined finish// Rci skids bare aluminum// Front Runner Slimline II roof rack with HI-Lift and Awning Mounts// ARB Awning// Hi-Lift Xtreme 48//Icon Rear Shock Shin Guards//Baja Designs Squadron-R Pro//Xenon Hid Headlights
04-24-2016, 06:54 PM
Real Name: Halko
Real Name: Halko
Both alignments from the same place? Didn't you post that it was an "old school" place that didn't use the machines? Maybe go someplace that can give a printout and see what it looks like.
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
04-24-2016, 08:22 PM
Moderator
Real Name: Greg
Moderator
Real Name: Greg
Alignment is the only way to wear it like that. Camber.
05-03-2016, 04:17 PM
Real Name: Danny
Real Name: Danny
Alignment specs....
After manual alignment but before second alignment at Firestone
Front:
Back:
Post Firestone alignment:
Dual Battery Thread
05-03-2016, 04:23 PM
Is that wear since your last rotation (less than 5k miles?). You're tires are obviously worn out, but I'd want to correct that before a new set starts to wear funny.
05-03-2016, 05:08 PM
Real Name: Danny
Real Name: Danny
That's my goal.
I got manual alignment done right after lift.
than another one at Firestone about 3k miles later when I noticed the wear
However, I think it's still not right.
Any feedback on the alignment specs?
Dual Battery Thread
05-03-2016, 05:10 PM
Banned
Banned
Can you type out your alignment values? I can't read any of them
05-03-2016, 05:20 PM
I can't tell all of your specs, but it appears that you have a camber issue and a toe issue. Negative toe means the tires are pointed away from eachother slightly in the front. That will cause wear on the inside of the front tires. Combine that with caster problems on that side and you've probably found the culprit. Hate to say it - but it may need another alignment. Unfortunately the shop techs are usually going to do the bare minimum to get into spec, rather than move the adjustable points to zero and then set all the alignment from a baseline of neutral.
05-03-2016, 05:40 PM
Real Name: Danny
Real Name: Danny
Sorry
Dual Battery Thread
05-03-2016, 05:44 PM
Real Name: Danny
Real Name: Danny
Thanks for the input, with the lift.. what should Toe and Camber be set at?
Dual Battery Thread
05-04-2016, 08:59 AM
the 2010 toyota repair manual shows all the alignment spec and procedures. camber should be close to zero . also you should have a slight toe in . not sure but 2 MM or so , measuring the rear to front front closer .
if the toe is out both tires will wear as you have. and hard to keep the vehicle going straight on bumps/dips in the road.
when the vehicle drops down you will get the tires to be more out of alignment creating more wear on the inner tire treads.
front tire edge should be closer than the rear edge.
suspension pg 2924
05-04-2016, 09:09 AM
Real Name: Anthony
Real Name: Anthony
Improper tire inflation can also cause uneven tire wear.
