04-26-2016, 08:58 PM
Re-gearing diff advice
Hey guys,
I've almost completed my build. I have my lift, 285/70/17 tires, wider wheels and a winch. I'd like to re-gear my differentials to get more torque. I have a few questions.
I have a 2014 4Runner SR5. According to the parts department at the dealership, I have a 4.11 gear ratio from the factory, is this correct?
Using rough country's diff calculator, I need to go to at least a 4.375 ratio to get back to "factory power". I don't mind sacrificing a bit of gas milage and top end speed to have more torque. What sort of ratios have you guys gone up to, and what's your highway driving experience like? I'm thinking if that is the correct ratio, I'd like a bit more torque than factory.
Can someone explain to me how this is calculated? I'd love to know.
I'm not sure I really have the need for ARB lockers, my a-trac has sufficed so far. Is it possible to simply change the ratio of the existing factory diffs with new gears, or do I have to buy aftermarket lockers?
Cost is an issue, so I want to weigh my options. For a full ARB setup I'm looking at 4k, and I don't really envision doing anything hardcore enough to need them for at least a few more years.
Thanks in advance!
04-26-2016, 09:29 PM
Real Name: Charles
Real Name: Charles
3.73 from the factory
2014 Trail Edition Premium, 285/70/R17 BFG KM2, RadFlo 2.5" Coilovers and Rear Shocks, 50qt ARB Fridge, OTRATTW Switches, BudBuilt Bumpout Sliders, Gobi Rack + Ladder / 40" Rigid E2 /Rotopax and MaxTrax mounted, ARB CKMTA12, 270amp Alternator, Southern Style Slimline Hybrid Front Bumper w/ Warn Zeon 10S and Front Fogs, Metal Oil Canister, Sound Deadening Insulation w/ Focal Front Speakers,Black Weather Tech mats and custom pin striping & dents (the trees & bushes did it for free)
04-26-2016, 09:34 PM
Real Name: CJ
Real Name: CJ
And I THINK 4.56 is your only option.
2014 Trail Edition -
Build Thread
2015 Epic in my own mind trip
04-26-2016, 09:39 PM
Real Name: Swartwood
You can go lower...
There is also a 4.88
In case you wished you'd bought a tractor or have some way of running 37s.
10 TE - KDSS - Icon Suspension - 285/70/17 Hankook MTs - 4.56 nitro Gears - URD equal length headers
Shrockworks front bumper and sliders - MT Rear bumper- RCI aluminum skids - Dif breather mod - K9 Rack - Warn 10S Winch
Come ride with me: PDX 4X4
04-26-2016, 09:40 PM
Nitro has 4.88s out now, too. Can also do 3.91 with Toyota gears but they are pricey
04-26-2016, 10:01 PM
3.91 is probably cheapest because you could buy a used set out of a wrecked GX460, but the jump from 3.73 to 3.91 probably isn't worth the effort. 4.10 would be ideal IMO for 285s, but there are no 4.10 or 4.30 gears for the 4runner.
The way it's calculated is by how many rotations of the pinion gear (drive shaft) it takes to make one rotation of the ring gear (tire). So a 4.10 ratio has a 10 tooth pinion and a 41 tooth ring gear. A 3.73 usually has an 11 tooth pinion and 41 tooth ring gear. Unfortunately you can't mix and match a 10 tooth pinion with a 41 tooth gear for a 3.73. The teeth are cut differently.
04-26-2016, 10:14 PM
I'd go 4.56 , you'll be set if you ever want to go up to 35's , or if you want to bolt on a bunch of weight . Don't waste your time by not going low enough , the first rule of re-gearing is you only want to do it once.
I'm a big ARB fan , $4,000 is a lot but front and rear selectables is...
04-26-2016, 10:39 PM
4.56 is really your only choice. With 285s its a little high strung on the hwy, but not a big deal. Your mpg will go to total crap above 75mph though...
34s(315s or 305s) will drop the rpm a bit and then true 35s will take it back to near stock characteristics (but I doubt you would ever be running those).
Offroad with 285s, you will notice a huge difference in control. The truck will walk over stuff without even touching the gas and your speed will be much more controlled when you are descending and holding first gear. The tq converter will flash way less also... Overall, just way more control of the power.
If you don't have a factory rear locker.... I would highly recommend that you take the plunge and put an ARB in the rear at the same time. ATRAC is OK and can get you out of most situations, but that rear locker is really mandatory when you start pushing things. ATRAC can get really sloppy and put a lot of stress on things in tough terrain. The front is much more of an optional thing that most people don't need or want to bother with managing (it can get you into major trouble without steering, or POP a CV...). Gears without lockers is OK I guess, but it just seems odd to add them without having the complimentary equipment. Sort of like adding a huge lift and running stock tires..... Plus since you have the 3rd member out anyway.. It just seems like a waste not to put it in....
04-27-2016, 12:07 PM
Moderator
Real Name: Greg
Moderator
Real Name: Greg
Originally Posted by gm350reratliff
Gears are on my list as well. Does anybody know if the 4.30 gears offered in the Tacoma would work in our 4Runners? To me, 4.10 is not enough and 4.56 is a bit too much but 4.30 seems to be what I need.
They will not work. The only ones available are the ones the guys listed above.
04-27-2016, 10:01 PM
Thanks for all the feedback guys. I spoke to Ben at Slee off road today. He was recommending going to a 4.56 diff, as well as going to a 265 or 275 Goodyear wrangler to reduce tire size and weight. He feels this will give me the best torque for better power, and keep my fuel consumption reasonable.
What are your thoughts on this?
04-27-2016, 10:20 PM
Real Name: Krister
Real Name: Krister
4.56 with 285/75's (34") tire is about as close to stock as you can get. Actually a little more on the bottom end. This Combo equates to a 7% lower gear than stock. The smaller the tire, the larger the difference.
2020 Tundra Limited Crew Max 4X4 - Tundra Build
2014 4Runner TE - rochmpr Build - SOLD
04-27-2016, 10:25 PM
Moderator
Real Name: Greg
Moderator
Real Name: Greg
You won't get better power as you say. You will get more torque. You will drop efficiency running stock size tires with 4.56's. Do you want more torque? If so then do it. Do you want better efficiency? Stock size tires and stock gearing. Your choice.
If you run bigger than 285's then 4.56 will help efficiency and bring torque back close to stock values.
04-27-2016, 10:46 PM
Real Name: Chris
Real Name: Chris
What exactly are you trying to accomplish with your vehicle? It makes no sense going back to a stock sized tire (265/75r17 is oem size) and re-gearing the vehicle, as you'll only gain torque at the expense of rpm at 60+mph.
There's a trade-off for lifted trucks with bigger tires, and that's fuel consumption and peppiness at all speeds, that's just the fact of life. Trying to re-gain that torque and mileage by doing gears is great, but re-gearing with stock tires, or something so close as a 275 or 285 series tire, just makes no sense to me, especially with a (dare I say it!) decent 4 litre V6!
My take on this is that you probably like the lift kit and the way it looks with the 285's on there, and being that you have a winch already, I can assume you'll be using this for the trails sooner or later, if not already. Keep the tires, install the gears, call it a day!
And, if its any consolation, having 4.56 gears in there already, you'll be ready to go another size up in tires without too much degradation in power.
And for the record, your gears, according to the 2014 product info guide from toyota, your stock gears in the diffs are 3.727, generally speaking, you're going down 3 gear sets (had toyota made a 3.92 and 4.10 set for the new diffs), that's quite similar to what us 4 bangers have been doing for many years! Most of the older toyotas came with 4.10 sets and stock tire sizes of 30-31" tires. For me, I went to 35's and 4.88 gears, and its a good balance with what it is. Its not a race car, even though I sometimes drive it like one, and it still gets 21mpg if I drive like grandma!
Do the gears and see where it goes from there if you really need to gain some performance back from doing the lift and tires. Just understand that highway speeds are going to be clocking a lot higher rpms, especially with 265's~285's!
Btw, going from 265's to 285's is only a 6.6% change in revolutions, yet your rpms with the different gear set is almost a 20% reduction.
2011 4 Runner (my daily driver)
1987 Xtra Cab (35's and locked front/rear, the trail toy!)
1985 Supra (430rwhp track toy!)
2006 Honduh Odyssey (the wife's van)
04-28-2016, 10:14 AM
FWIW the 6th gear rpms range varies dramatically in the new tacoma depending on MT or AT. In the 6 speed MT version with 4.30 diff gears, 80mph = 2,750rpms. In the AT version with 3.73 gears 80mph =2,000rpms. There's a 35% difference in RMPs at highway speed between the manual and auto versions. That's a big difference!
With 285s and 4.56 gears, you'd nearly identically match the gearing at highway speed of a stock manual transmission 2016 tacoma. It's not a direct comparison as the 3.5L is more comfortable at higher rpms and can actually decrease its displacement so it can run like a 2.5L engine. Possibly that gives it a big advantage in efficiency at high rpms. But just something to give a comparison.
