Old 05-06-2016, 11:22 AM #1
sure74's Avatar
sure74 sure74 is offline
sure74 is on a distinguished road
sure74's Avatar
Qi Wireless Charging (OEM Style)
Goal here was to add a Qi wireless charger that could be mistaken for an option that came from Toyota or just not be seen at all.
The lower bin in the center stack seemed like a logical choice. My phone fit there pretty well (also tested with a note 4 which is just over 6") and it is easy to grab the phone from that spot at stoplights and such. Also, the plastic there is pretty thin and the 12V power outlet was the perfect spot to grab power for the mod.
Parts for the mod were actually pretty cheap, the whole thing came in under $30. I used the PowerBot PB1020 Qi Enabled Wireless Charger for its wireless charging component and I used the HitCar DC 12V to 5V Power Inverter Mini / Micro USB DC 3.5 Hard Wired Converter Kit to supply the power. I also used an old Digital Optical Audio cable to redirect the LED from the charging board and I used some Extreme Mounting Tape to secure the charging board to the underside of the bin.
Here you can see where I grabbed power from the 12V power outlet. I removed the protective cover, soldered the wires from the HitCar DC 12V Inverter and slid the cover back on.
I removed the board from the PowerBot Wireless Charger to mount it to the bottom of the bin. The other side of the board has the wireless charging coil which has to be as close to the bin plastic as possible. Two layers of the extreme mounting tape provided the perfect spacing. I carefully trimmed two layers of tape to fit around the coil and applied it to the bottom of the bin.
The LED indicator is soldered to the board and I was definitely going to need to know the status of my new charger. I used an old optical audio cable to redirect the light from the LED to the top of the bin. In this pic you can see how I used hot glue to fix the cut end of the optical cable directly in front of the LED to pick up the light.
The other end of the optical cable is attached to the top of the bin using hot glue. The original connection was perfect since the exposed core is about as long as the bin plastic is thick. I just needed to make a pin size hole in the top of the bin to let the light shine through. Behind the optical cable you can see the power inverter which is also attached with mounting tape.
Added bonus, once I disconnect the the AUX and 12V power outlet connectors the unit comes out same as before the mod.
The finished product. When the unit is not charging the LED is green. It actually makes for a pretty nice little light for the lower bin. When it is charging (most of the time I am in the truck) the light is blue.
So far so good. It's been installed for a month or so and I have had no issues with overheating or my phone not charging. I just throw the phone (or any Qi enabled phone that fits) in the bin and it charges.
Let me know what you think & thanks for checking out my mod.
2016 TEP NBlue KDSS
sure74 is offline   Reply With QuoteReply With Quote
Old 05-06-2016, 11:52 AM #2
TrkyMfns's Avatar
TrkyMfns TrkyMfns is offline
TrkyMfns is on a distinguished road
TrkyMfns's Avatar
excellent use of that cubby.
2011 SR5/P 4WD Blizzard Pearl - 285/70/17 Falken Wildpeak AT3/W - Bilstein 5100 Lift @ 2.5 - SPC UCA's - Two-Tone Katzkin Interior - 15% Lumar Pinnacle Ceramic Tint - Canvasback Liner - Husky Weatherbeater Liners - Phillips Interior LED's - Completely upgraded ICE.
TrkyMfns is offline   Reply With QuoteReply With Quote
Old 05-06-2016, 03:35 PM #3
yotaflame's Avatar
yotaflame yotaflame is offline
Real Name: Jon
yotaflame is on a distinguished road
yotaflame's Avatar
Real Name: Jon
Awesome mod, any particular reason you used that specific qi charger?
2014 Toyota 4Runner TEP Magnetic Gray | Bilstein 5100 shocks | TRD Pro Wheels | 265/70/17 Nitto Terra Grapplers G2 | GOBI ladder | |RCI front skid + filler plate | OPOR sliders | Blacked out silver trim | Lamin-x yellow fog light film | 15%/25% front/rear tint | Rola roof rack
yotaflame is offline   Reply With QuoteReply With Quote
Old 05-06-2016, 04:22 PM #4
sure74's Avatar
sure74's Avatar
Thanks TrkyMfns
Thanks, yotaflame. Yes, size of the board was important since the bin is pretty narrow. Also the first Qi I bought had 2 separate boards in it and this one was an all in one board which I liked much better.
2016 TEP NBlue KDSS
Old 05-06-2016, 04:25 PM #5
tslycord tslycord is offline
tslycord is on a distinguished road
Was planning this out 2 weeks ago with a 3d printer to mold around the specific Qi charger... my current charger is picky on charging depending how my phone is sitting. Iwas worried about the extra layer of material if its solely mounted on the underside. My focus got shifted elsewhere, but you have renewed my interest
2012 5th Gen SR5 Premium- interior led bulb swap, rear storage mod, engine bay led light mod, stealth wireless charger, Michelin Defender LTX, debagged, FX-R stage 3 projector retrofit
To do: powered sub, rear cargo led, suspension upgrade
Ideas to design and fab: build custom roof rack
tslycord is offline   Reply With QuoteReply With Quote
Old 05-06-2016, 05:37 PM #6
JET4 JET4 is offline
JET4 is on a distinguished road
Very nice, been thinking of a way to use a wireless charger in the 4runner and you just gave me the idea.Thanks
2018 Magnetic Grey Metallic
2011 Salsa Red TE W/KDSS & Nav 275/70R17
2007 White Toytec lift 285/70R17 (sold )
1999 Imperial Jade Mica SS lift 305/17R16 (sold)
JET4 is offline   Reply With QuoteReply With Quote
Old 05-09-2016, 09:44 AM #7
sure74's Avatar
sure74's Avatar
With the board out of its original case you are not charging through any more or less plastic, essentially using the bin as the case. Also, if you look at my pictures you will notice that the board is mounted a little to one side. While test fitting I had the bin and charger board hooked up in the house and I just moved it around until I found the best spot. For both of the phones I tested the charger worked better skewed slightly toward the bottom of the phone.
Thanks JET4
2016 TEP NBlue KDSS
Old 05-09-2016, 09:59 AM #8
Slow Slow is offline
Slow is on a distinguished road
Great Mod and great write up.
'16 SW T4R Trail With Some Stuff
'14 Mag Grey 4Runner SR5 4x4 NAV Wifes Ride
'13 Iceberg white FJ Cruiser 4x4,Budbuilt skids and Beefy bump out sliders,Boztec diff skid,Metaltech links,Bilstein 5100's,BFG KM2's in 285/70r17 flavor, Mpac side rack,10lb Powertank,5lb Badger,kenwood V71 drilled NMO,Ellis precision Knobs + Some Stuff. (SOLD)
http://www.toyota-4runner.org/image.php?type=sigpic&userid=107195&dateline=14433  89183
Slow is offline   Reply With QuoteReply With Quote
Old 05-10-2016, 12:10 AM #9
Do you have a case on your phone? I feel like I need to search around for another Qi charger that will fill up more of the space,. Thanks for pioneering this!
Old 05-10-2016, 02:32 AM #10
TK-422's Avatar
TK-422 TK-422 is offline
Real Name: Chris
TK-422 will become famous soon enough TK-422 will become famous soon enough
TK-422's Avatar
Real Name: Chris
I had thought about it after seeing the one built into the Tacoma. Now you made me open up my muti-coil charger. Nice, its one piece. Now I will have to see if it will fit under there.
I see mine is 5V. Is that what the power inverter you refer to is for?
<a href=http://www.tophersworld.com/imagesb/tk422_signature.jpg target=_blank>http://www.tophersworld.com/imagesb/tk422_signature.jpg</a>
"I hope yours took a bath once in a while, kid. This guy's armor smells like he lived in it."
―Han Solo to Luke Skywalker, while donning TK-422's armor.
TK-422 is offline   Reply With QuoteReply With Quote
Old 05-10-2016, 03:11 AM #11
DenverTrailRunner DenverTrailRunner is offline
DenverTrailRunner is on a distinguished road
Dude,
Love this MOD, I would love to get rid of the wires in my runner. Very Clever Indeed.
Will be working on this soon enough.
DenverTrailRunner is offline   Reply With QuoteReply With Quote
Old 05-10-2016, 06:13 AM #12
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 05-10-2016, 02:20 PM #13
sure74's Avatar
sure74's Avatar
Thanks Slow
tslycord, I have a slim jelly type case. See TK-422's post, I think his charger is just what you are looking for.
TK-422, that multi-coil charger is pretty cool and I think it will fit for for sure.
Originally Posted by DenverTrailRunner View Post
Dude,
Thanks DenverTrailRunner
2016 TEP NBlue KDSS
Old 05-10-2016, 02:58 PM #14
What brand/ model is that?
Old 05-11-2016, 02:02 AM #15
TK-422's Avatar
Real Name: Chris
TK-422's Avatar
Real Name: Chris
Choetech
It's nice because you can just toss the phone (Note4, S5, S6 in my house) on them in any direction and they will charge. I have two of them so one just might go missing.
I pretty much stick to the lightning charger at home but on the road there is no hurry to charge it.
TRD Cold Air Intake - New Style and Where Can I Find the Old Style ts9790147 4th Gen T4Rs 25 08-30-2014 08:55 AM
DIY: Add wireless charging in your cabin for smartphones/tablets xxaarraa 4th Gen T4Rs 11 11-11-2013 02:27 PM
Need approx. 30x9.50r17 size, All Terrain style that aren't heavy 10 ply style! chainring Engines / Suspension / Wheels / Tires / Audio / Accessories 1 07-06-2011 12:10 PM
Need approx. 30x9.50r17 size, All Terrain style that aren't heavy 10 ply style! chainring 3rd gen T4Rs 2 07-05-2011 06:40 PM
PIAA Wireless mysticz Engines / Suspension / Wheels / Tires / Audio / Accessories 1 03-14-2007 02:01 PM
