I posted this in the huge wheel and tire fitment thread, but thought it might be relevant here since this is secific to 285s.
These are 17x8s with 4" BS, wrapped in 285s (285/70r17). They stick out a hair past flush, but it us still relatively subtle. I eyeballed a bit over 32.75" with my tape measure, so they are pretty standard size-wise. Agressive mud tires with squarer shoulder lugs might be at greater risk of rubbing.
I pushed the front of the fender liners forward at least 1.5 inches (about as far as I could) and have the mudflaps removed. It has a pretty typical alignment, but looking at the LCA cam bolts there should be some room to increase caster and push the wheels forward a bit.
I got it as far into "full stuff" as I could. With the left front on a mound, completely turned to the left, and the left rear quite a ways off the ground. Tere was about 1/4 to 3/8" of space between the back of the tire tire and the body mount.
This is on a TRD pro with factory suspension, so I am not 100% sure how this might work with TE or SR5 factory suspension for aggressive wheeling. (Does the TRD front suspension just use springs to increase the ride height, so overall travel is not actually changed? Or are there other hardware differences that change the front ride height?) There isnt a huge difference in static ride height, though, so this might still work on a TE or SR5.
Hope this helps!
