05-10-2016, 08:09 PM
#16
Thanks for the advisory, the issue you are experiencing are quite concerning. Considering these racks are close to $1K and supposed to be "durable" upgrades.
I am currently running a Baja Rack Spy I got from the group buy in winter.
It has been installed since December but I don't run a lot of weight on there for a long period of time. I probably ran extra 80-100#s and added about #150 for a quick picture when my kid and wife sat on top. In my initial install I used a heat-gun and a tight ratchet strap to make sure there was a good amount of pressure on while the VHB tape cured~ 1hr. This weekend I removed the rack and only looked under the "A" mounts (mounted most forward) and didn't notice any dents. I wish I had time to inspect under the "B" and "C" mounts for damage.
From my experience with BR is they try to make things right, but it does take them some time. I had an issue with the packaging of my rack and we came to a resolution. It did take about 2-3 weeks, it was a small issue. I noticed that they do take what seems to be a long time especially when the issue is perceived as "big". You have every right to be pissed as I would also be. We might not have the same rack but let me know if you need any reference pics of my brackets / roof etc.
05-10-2016, 08:16 PM
#17
Thanks for sharing your experiences with all of us. Out of curiosity, what are you hoping they will do to make things right? I would be very P'O'd with those dents but I don't know what they could do to fix that other than some serious body work.
2013 4Runner Limited | OPOR Sliders | BFG KO2 in 275/70R17 on TE Rims |Bilstein 6112/5160s and SAW 1.5" | Some RCI Aluminum Skids | SPOD | Gobi Stealth No-Rise | Aurora 40” and 6” Single Row LED Light Bars
05-10-2016, 08:48 PM
#18
Real Name: Patrick
Real Name: Patrick
I'm so sorry to see these results...you have a great build.
My guess is it was just too much weight and compression(obviously). In the process of designing my own rack, that area is the biggest concern.
I'm trying to figure how to "spread the load" so to speak. Every inch longer and wider helps to distribute the load.
I also feel they (the feet) need to find a fine line between resting in the gutter and resting on the the actual roof. I'm to the point I'm ready to start molding spacers out of Starboard.
That really sucks ..I hope they resolve it for you.
White 2016 TEP .....My ROAM Truck Build....... My ROAM trailer Build
05-10-2016, 08:53 PM
#19
I had my rtt on my Baja for several months, camped probably 6 times before moving it to the trailer. Never noticed any dents around the mounting points.
Also running the same awning mounts, will keep an eye on those down the road.
Other than the weak powder coating (which is known) I've had no problems with mine.
[B]2015 TE - [B]Fox 2.5 DSC front/2.0 C rear, Baja Flat Utility, RCI front/trans/transfer steel skid, Led DRL/Driving lights, Outbreak Expedition amber/white led bar, PIAA LED driving lights, ShrockWorks Sliders, 265 BFG KO2, 8' Outbreak awning, Outbreak RTT, Husky liner mats
05-10-2016, 08:57 PM
#20
Moderator
Real Name: Greg
Moderator
Real Name: Greg
More feet along the sides and arch the transverse supports a bit, maybe 1/8" up in the center. You would be surprised how much that little bit of bow increases the load bearing properties of the bar.
05-10-2016, 09:16 PM
#21
I emailed them yesterday morning just to inquire about lead times for a rack and to install in their parking lot (which I read is common). Haven't heard a peep, they're either busy or based on your experience, they aren't very responsive. Maybe I'll just bite the bullet on a Gobi.
05-10-2016, 09:44 PM
#22
Real Name: David
Real Name: David
2016 super white Trail Premium W/KDSS , 2000 emerald green metallic SR5 Highlander. Gone but never forgotten 2010 black SR5.
05-10-2016, 10:18 PM
#23
Real Name: Keith
Real Name: Keith
I did a fair amount of research in various forums and called Baja to ask questions about using it for a RTT. There are plenty of people doing it and Baja stated there were no issues at all with my planned setup and I am well within the weight limits of the rack. If you look at other pictures in my build thread you will see its pretty centered between the feet. I have 1/4" of clearance between the ladder and tent. It's as far back as it can go. I don't think it's a weight issue. I think its horrible quality control and a bad rack.
What do I expect from Baja? Good question. I really just wanted their input and opinion. Fixing the damage would surpass the cost of the rack. There's zero chance of installing this portion incorrectly so it's clearly a manufacturer defect. They should just refund my money at a minimum. If it was my product, that's what I would offer my customer.
The problem is that nearly any other rack is going to leave that area exposed and constantly visible, which would piss me off every time I looked at it.
If I had it to do over again I would go with the K9 from Equipt. I'd install their long rails and add some nutsert attachment points up front. I'd use 4 feet on each side with their 2.2m base. I've seen this in person and its far superior and stronger. Definitely disperses the weight better.
Again, my intent is to educate the future consumer population and hopefully save good people from spending their hard earned money in the wrong place.
2015 TEP/KDSS
05-10-2016, 11:31 PM
#24
Wait a minute here...
This rack has been installed for a year and the only thing mounted to it was a James Baroud tent that weigh's 130lbs, a Fiamma awning that is mounted with the Baja brackets that weigh's 19lbs. The combined weight of the two people sleeping in the tent is 270lbs.
Let's break this down a bit by playing devil's advocate..
1. The standard basket BR weighs in at 65lbs.
2. You put a RTT on it which weighed 130lbs.
3. You put an awning on it which weighs 19lbs.
4. The combined weight of both people is 270lbs.
If we add up all that static weight, you're looking at almost 500lbs load on the roof. Standard OEM roof loads are only 150lbs.
With a rack, that raises it up to 300lbs, but only with even weight distribution. You've exceeded the maximums by almost 200lbs and you want BR to be responsible for dents in your roof? I'm a little confused as to how you came to that conclusion, to be honest. If I were BR, I'd point back to the manufacturers "when used correctly the rack has a max limit of 300lbs" and put it back on the owner.
05-11-2016, 12:15 AM
#25
Real Name: Keith
Real Name: Keith
Let me fill in your logic, engineering and mathematical gaps and help your "thinking" process. I will let
@ 1engineer
explain the difference between static and dynamic weight ratings to you if self initiated Google or the free clues below don't fill that gap for you first. From Baja's website " Load Capacity: Dynamic (while driving) 300Lb (136 kg); Static 600Lb (272 kg)". Load capacities of the rack do not include the 80lbs of the rack itself. Although I have tried several times to occupy the tent while I drive (free hint on the word "dynamic"), I have not been able to succeed. Thus the dynamic state of the setup is approximately 160lbs at best with the bedding and whatnot inside the closed tent. When were parked and occupying the tent (free hint on the word "static") the load on the rack is at most 460lbs with people and personal affects.
The factory rack rating has nothing to do with the rating of the roof, which no one publicly knows that I have been able to find.
Specifications can be found here: Baja Rack: racks_list_inside
2015 TEP/KDSS
05-11-2016, 02:18 AM
#26
Real Name: Dave
Real Name: Dave
Baja Rack dents roof
Keith,
I'm surprised so many people gave you static about this thread. The forum is not being dynamic.
All kidding aside, I am sorry to see the dents on your roof. I wondered about this when I put my new Baja Rack on my 4Runner this past Sunday. I think your 1/4" aluminum or steel plate may be the answer. It gives the rack a larger bearing area. I filled this space with closed cell foam because it will easily catch dirt and rainwater. I don't want to find 1/4" of dirt in the track some day.
I ordered a custom rack without the Xm Sirus radio antenna loop cut out. I wanted a stronger rack and I think I got it. It barely touched the antenna so I added 1/4" shims to the tops of the 4 brackets in order to raise the whole thing up so it would clear. Now it's about 1/8" off the antenna. I used a 1/4" neoprene rubber sheet and cut the shims to fit over the plate on top of the bracket. I made a punch out of copper pipe to cut the holes. I think with the 1/4" plate you made you could add 1/4" of neoprene cut to be slightly larger than the bracket foot and re-install the foot over both shims. The neoprene could deform and spread the load. Is the roof track any stronger than the roof body?
I didn't like how the front feet rest on the roof so I cut a shim to fit much wider than the steel foot and stuck the 3M tape that came on the front feet to the neoprene. It spread the load and let the foot rest flat and stable, not half way on the roof top strip and half on the sheet metal. It will probably deform a bit over time and I will have to readjust the height of the front feet so the wind deflector clears the roof.
Good luck with Baja Rack. It's harder to return the rack than it is to fix it, I think.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
05-11-2016, 08:52 AM
#27
Real Name: Charles
Real Name: Charles
Thanks for sharing, I hope they end up getting back to you, even if its to say take a hike at least they would have communicated. It would do them well to try and clarify if this is a one off issue with your rack as to set others minds at ease.
You are being reasonable and I think if it turns out to be a issue with the rack itself (appears to be) that refunding you the cost of the rack is good solution. If I owned the business I would be thrilled that is all you asked and not for body work.
For what its worth for others , and I have posted this in previous Gobi threads. I ran into customer service issues with them as well. During purchasing everything was smooth and communications were generally within a day or two but after I received the rack I had an issue with my ladder and the top bracket was bent and would not install without being bent back. While I ended up doing this myself I was trying to confirm with them/get there input as had I popped the powder coat off etc I would have liked there "assurance" they would help cover fixing that but as they never responded I wasn't even able to bring that up.
It does seem like communication with almost all the rack vendors is spotty Gobi, Baja, Drabits not sure about K9 or Prinsu (sp?)
Good luck and maybe try one more e-mail with this thread linked? Might help to elevate the issue.?
2014 Trail Edition Premium, 285/70/R17 BFG KM2, RadFlo 2.5" Coilovers and Rear Shocks, 50qt ARB Fridge, OTRATTW Switches, BudBuilt Bumpout Sliders, Gobi Rack + Ladder / 40" Rigid E2 /Rotopax and MaxTrax mounted, ARB CKMTA12, 270amp Alternator, Southern Style Slimline Hybrid Front Bumper w/ Warn Zeon 10S and Front Fogs, Metal Oil Canister, Sound Deadening Insulation w/ Focal Front Speakers,Black Weather Tech mats and custom pin striping & dents (the trees & bushes did it for free)
05-11-2016, 03:24 PM
#28
Real Name: Keith
Real Name: Keith
Originally Posted by DesertCanyons
Keith,
Do you have pictures of your setup to share?
2015 TEP/KDSS
05-11-2016, 04:30 PM
#29
Real Name: Cole
Real Name: Cole
After reading this thread I went straight out to my vehicle and found the same issue. I am actually pretty surprised at the level of damage.
Each corner is damaged right under the stand. Additionally the roof rails have a slight buckle under the 2 middle stands a few inches down. The photo shows the buckle in the reflection of a near by buildings roof.
I have only loaded it up fully once with an approximate weight of 250 pounds (conservative est). That weight was for driving and the rack was empty while camping.
1995 4Runner 4x4
2004 Tacoma Prerunner
2015 4Runner Trail Premium kdss
2017 Tacoma TRD Offroad DCLB
05-11-2016, 05:24 PM
#30
Real Name: Brad
Real Name: Brad
Sounds like the OP isn't the only one with roof dents. The pics
@ Rein
posted makes me wonder why BajaRack wasn't concerned with this happening before ever putting these into production.
2016 TE white, LED light bar, and 2" leveling lift.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
