Originally Posted by dirtrunnerdave
Thanks Keith... Both for your other build thread and this on...
Your post convinced me that the front receiver hitch is the way to go. Love that it is so stealth!
I was curious to know a few things about the install.... I love the hinged license plate. Did you fab up the hinged assembly yourself or was that part of the hitch mount from CBI.... Did you just figure it out as you went along or were there any instructions from CBI? If not, do you have any pointers for those that would like to duplicate what you did? Anything that you learned and would do differently?
Is it possible to put in the hitch pin without cutting such a big hole in the bumper? (I note that you have the basket mounted through the whole in the license plate holder so I was wondering how that worked with the flip up holder....)
Did the hitch mount come with instructions on hole placement and size or was that discovered with trial and error?
What did you use to cut the hole in the bumper?
Thanks for your help in advance on this. It will be my first "cut into the body" mod on my 2016 trail...
David Brix
Hinge came with the kit. No directions, although they might have them now but I was one of the first kits out the door. There really was no need for them though, all pretty self explanatory. I dont have any recommendations. If you dont know how to take the bumper skin off I would recommend reading one of the few threads on that.
I cut the hole with a dremel and a cutting wheel for plastic. I wanted the hole as large as it could be without being seen when the license plate is closed so that I had plenty of hand room to get in there and attach a locking hitch pin or whatever else. If the plate covers the area, why make a smaller hole? I notched my license plate back-plate just so I could close it, not necessary just aesthetic.
Hope that helps.
