Lift all done!
6112 Front Shocks Model: 46-227294
I set them at the Fourth Perch UP for hopeful "2.5" lift.
Spacer used on top of hat drivers side to level the truck
The Coils that are paired with the 6112's for the T4R are Eibach 620's
Bilstein 5160 Rear Part number: 25-227611
ARB OME-895E 2" Lift Springs
Stock
Front done, rears stock
Issues;
the rear bracket for mounting the resevoir came with a mounting bolt that was an allen, but made from some weak metal.
The bolt hole that was threaded in the frame had corrosion and ruined the screw. Thankfully I used vice grips and pulled it out.
Underneath the car where you mount the sliders or side step bars are some bolts that are used as fillers. They are self tapping and can help you clean up the threads.
completed
Side by side.
Check out
my Build here
2014 Trail Premium - 285Dura - 5100/5160 2.5"F/2"R
