Old 10-25-2017, 02:56 PM #16
Tisoy281's Avatar
Tisoy281 Tisoy281 is offline
Real Name: David
Tisoy281 will become famous soon enough
Tisoy281's Avatar
Real Name: David
Originally Posted by Icefroggyfrog View Post
I am trying to figure out why this is happening to my 2014 Limited. It pops right back in. No known accidents I am aware of (wife's primary vehicle). Didn't see any body damage on the front bumper that would indicate otherwise.
Any thoughts on how this could be fixed?
Bumping this up because I have the same issue on a certified pre-owned 2014 Limited that I got less than a month ago. Spoke with the salesman, and was told that the Texas heat causes the separation. (Bunch of BS, I know). He said their body guy would essentially just glue the bumper, but we would have the chance of it ripping paint off if it came separated again. Debating on taking it up to the sales manager and getting a new bumper cover put on.
Tisoy281 is offline   Reply With QuoteReply With Quote
Old 10-25-2017, 08:06 PM #17
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
Bumper cover is around $220 unpainted. Mine is doing it too, and even gluing wont keep it on. The little tabs are too weak and the black retainer under the headlight that locks onto the bumper is just not locking on tightly enough. You can't even get behind the joint to screw it together either.
83Mule is offline   Reply With QuoteReply With Quote
Old 10-26-2017, 12:37 AM #18
hereinhelena hereinhelena is offline
hereinhelena is on a distinguished road
Originally Posted by Copp4 View Post
I can't seem to figure out why the area where the bumper meets the fender keeps separating. The separation will vary from a 1/4" to 1/2". Its the seem between the two directly under the headlight.
You can pop it back into place, but it barely wants to stay together. Once you drive it, it will separate again.
Sent from my XT1254 using Tapatalk
This is interesting - My 2017 TRD Pro has the opposite "problem". The gap (near the headlight is very tight (touching) on the passenger side - tight enough that the paint is abrading (if you look really closely). It is the only body panel gap that isn't perfectly uniform. I took it to the dealer - they said (after some discussion) it was covered under warrantee & sent me to a body shop. The body shop guys advised me to not touch it. They said that the tabs are prone to getting a loose fit if disturbed & may not reattach as firmly again if the panel is popped off. They offered to look at it - but said that may make things worse, & it is non-adjustable anyway. I wasn't sure whether to believe them, but decided, for better or worse, to leave it as-is.
hereinhelena is offline   Reply With QuoteReply With Quote
Old 10-26-2017, 07:48 AM #19
SR5Bart SR5Bart is offline
Real Name: Bart
SR5Bart has a spectacular aura about SR5Bart has a spectacular aura about
Real Name: Bart
Toyota knows about this and I just had 2 new 4Runners (Limited and Trail) in the shop and had guys from Japan actually come out to see whats going on with them. Needles to say both of the 4Runners got new bumper covers. So Toyota is aware of the issue now I guess we wait n see.
18 Trail. Cookie cutter built (SOLD)
14 SR5P (SOLD)
SR5Bart is offline   Reply With QuoteReply With Quote
Old 10-26-2017, 08:39 AM #20
Tisoy281's Avatar
Real Name: David
Tisoy281's Avatar
Real Name: David
They're sending someone out today to pick up my 4runner and take it back to the dealership (1.5 hour drive). I'm definitely going to make sure that it's replaced and fixed correctly before they bring it back. Thanks for the info, guys.
Old 10-26-2017, 08:48 AM #21
Slavic Slavic is offline
Real Name: J B
Slavic is on a distinguished road
Real Name: J B
Poor engineering.
Slavic is offline   Reply With QuoteReply With Quote
Old 11-03-2017, 11:14 AM #22
BCZECH's Avatar
BCZECH BCZECH is offline
Real Name: Ben
BCZECH is on a distinguished road
BCZECH's Avatar
Real Name: Ben
I believe I just talked with you on fb messenger.
Hopefully you get it corrected for good so I can tell my dealership how it was fixed.
BCZECH is offline   Reply With QuoteReply With Quote
Old 10-30-2018, 11:52 AM #23
zlicious24 zlicious24 is offline
zlicious24 is on a distinguished road
same thing is happening to my 2014 4 runner . I took it to dealer and they didn’t do anything about it.. I called 1800-331-4331 and representative opened a case about it . I encourage everyone to call and report this. Maybe they will than do something about it . Zlata
zlicious24 is offline   Reply With QuoteReply With Quote
Old 10-30-2018, 11:55 AM #24
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
Mine had this issue on the driver's side.
You can see it in this pic I took shortly after buying the truck:
I removed the bumper to install light bar behind grille, thought when I put the bumper back on I could resolve it. It didn't work so what I did was take a ~3 inch piece of 3m double sided tape and put it on the black bracket behind bumper, then when I installed the bumped I pressed it in on that spot and it fits flush now.
I stole this pic from someone else's thread to show the bracket.
Now whenever I remove the bumper (don't know why I would anymore) I will just use a new piece of 3m tape.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 10-30-2018, 12:05 PM #25
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
A story told in three parts...
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 11-03-2018, 10:36 AM #26
Muzzle of Bees Muzzle of Bees is offline
Muzzle of Bees will become famous soon enough
Mine separated when I scraped a short parking pole. When you remove the bolts under the fender and pull the bumper liner and cover away you see that the piece under the headlight fits into a narrow vertical slit to help line it up with the adjacent piece. See the pic posted on #24, look just to the left of the arrow in the pic for reference for the vertical slit. There are no clips there that I could see. I did notice that a gentle tap in that area shifted the pieces behind the bumper cover slightly towards the engine about a 1/4 inch. I was able to get a long persuader behind the area and move it a liitle which helped get the area under the headlight lined up. But, I think I want to remove the whole bumper cover to understand that whole area better. The front of my 4Runner has taken a beating so I don't really care to paint it nice. I just used a bunch of touch up paint.
Low hanging nicely painted plastic pieces on a truck like this is annoying.
2016 TEP
Muzzle of Bees is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 12:21 AM #27
osideplayer osideplayer is offline
osideplayer will become famous soon enough osideplayer will become famous soon enough
This thread needs a bump... I am sure more people are having this issue.
I did the fender mod recently and this starting happening immediately afterwards.
osideplayer is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 01:09 AM #28
6uam671_T4R 6uam671_T4R is offline
6uam671_T4R is on a distinguished road
I had the same issue but on the passenger’s side. Bought as a used car and even the dealership couldn’t fix it. When I removed my bumper to install some LED fogs I was able to fix it.
When I had it all apart I checked for any broken tabs on the bumper and bracket bolted to the fender. Nothing was damaged. When I put it back together, it would pop out. Every time I snapped it into place, the part under the headlight would pop out. So I held the part under the headlight in place while snapping the part where the bumper and the fender meet. It’s been over two months and so far so good.
6uam671_T4R is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 11:42 AM #29
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
What are you holding where?
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 12:01 PM #30
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Front Bumper to Fender Separation
Headlight brackets has holes for bumper guide pins. If not seated correctly, the area along fender will have a gap.
daytonaviolet is offline   Reply With QuoteReply With Quote
Front Bumper & Fender Help maulwoof 4th Gen T4Rs 2 12-04-2022 02:18 PM
WTB 3rd 96-98 Front bumper fender flares 3RDGENGuy Want to Buy/Trade 3 10-14-2014 11:59 PM
Body Gap: Front Fender to Front Bumper N/A 5th gen T4Rs 6 04-28-2014 04:50 PM
Front bumper fender bender... what should I do? Laubage 5th gen T4Rs 33 07-03-2012 11:36 PM
WTB 93-95 4runner Sapphire, Saphire Blue PS Front Fender & Front Chrome Bumper My Boy Blue Classifieds - buy & sell (no commercial ads please) 0 02-06-2011 02:39 PM
