Thread Tools Rating: Thread Rating: 5 votes, 4.20 average. Display Modes
Old 03-30-2018, 05:17 PM #76
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough oljedi11950 will become famous soon enough
Thank you Gracie !! And you are/were right that rear most on drivers side is a real B*^*H !! Lots of bad words .........
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
oljedi11950 is offline   Reply With QuoteReply With Quote
Old 05-29-2018, 05:16 AM #77
Fredward's Avatar
Fredward Fredward is offline
Real Name: Fred
Fredward is on a distinguished road
Fredward's Avatar
Real Name: Fred
Originally Posted by renau001 View Post
Maybe @Antman won't mind me adding here for the later models (2013+ I think) that have the air switching valves in the way of a few of the plugs. I wouldn't think there are too many folks that have many miles yet, but at some point it will come into play. With a 2016, I obviously haven't done this, so it's just pics of the interferences you'll have to remove. Sorry, I don't have the panache of Miss Gracie. You'll just have to bear with me on a boring writeup.
So this is an air switching valve that blocks access to a couple of the plugs. There is one on each side of the engine. They are not identically shaped due to mounting point differences, but other than that they are the same. The one shown in the picture is on the passenger side.
To remove the air switching valve:
1) First remove the attached air tube by removing the 4 bolts/nuts (yellow circles), 10mm socket. At each end of the air tube, there is a metal gasket. The gaskets will be replaced but be sure not mar the mating surfaces.
2) Disconnect the electrical connector and rubber hose from the valve (blue arrows). The rubber hose is attached with a standard spring clamp. Pinch the two tabs together with a pair of channel locks to widen the clamp for removal. Make sure you take note (or pic) of how the hose and clamp were aligned. There is a paint mark on the hose that lines up with a raised projection on the valve body. You will want the hose and clamp lined up properly when you reinstall.
3) Now you can remove the 3 mounting nuts (red circles), 12mm socket, and then remove the valve. The 2 that are visible are easy to get to. The one you can't see in the picture is behind that wiring harness. This nut may be the one thing that could complicate this job, so I'll focus on it for a second.
The FSM actually has you remove the air cleaner cap and hose before you mess with the air switching valves. The only reason I can see you would need to do this is for that one mounting nut on the passenger side air switching valve. So I recommend assessing this and trying to loosen that nut before starting this job. If you think you need to, go ahead and remove the air cleaner cap and hose before you start on the air switching valves. Here's how you would do that.
In the picture below
1) Unfasten the 4 hook clamps (red circles), just like your were replacing the air filter.
2) Disconnect the mass air flow connector (yellow circle)
1) Remove the rubber vacuum hose and detach the wiring harness (red arrows)
2) Remove the mounting bolt (yellow circle), 10mm socket
3) Sorry the next two are not pictured cos I was too lazy to take the engine cover off, but it should be obvious with it off
4) Remove the rubber ventilation hose, has a spring style clamp just like the hose on the air switching valve
5) Loosen the screw-style clamp on the hose where it attaches to the throttle body
6) At this point (unless I missed something) everything should be disconnected and you can wiggle and lift the air cleaner assembly out and set aside
With air cleaner cap and hose off, you should have no problem accessing all the mounting nuts and removing the passenger side air switching valve. For the driver side, it's basically the same except you don't have the air box in the way. After removing both air switching valves, you should be set up to do the spark plug replacement just like shown in the OP.
Installation of everything is essentially the reverse of removal. Just remember to get everything lined back up the same way. And also you're dealing with engine intake that is taking in air that goes through your filter so you do not want any foreign material getting in all that stuff during removal or installation, so keep it clean. Here's the torque specs for all the extra stuff and part #'s for the air tube gaskets, etc. that you'll need. I'll also point out that depending on your model year, the spark plug part # is different, so check that below as well.
Torques:
Air switching valve mtg nuts - 186 lb-in/21Nm (12mm)
Air tubes - 88 lb-in/10Nm (10mm)
Air filter hose clamp - 44 lb-in/5Nm (10mm)
Air filter hose mtg bolt - 44lb-in/5Nm (10mm)
Parts:
6 spark plugs
Toyota part # 90919-01233/DENSO SK16HR11 ('14-'16) or
Toyota part # 90919-01191/DENSO SK20HR11 ('10-'13)
4 gaskets for air tubes - Toyota part # 17377-38010
Hope this helps. First time doing something like this and I'm sure I messed something up or missed something. Certainly willing to take some feedback to make it better.
Just did the plugs on my 16 tep. 73,000 miles. They needed it for sure. I can confirm that it is quite easy. All you have to do is remove the egr air pumps as pictured above as renau001 mentions. You don't need to remove all 4 of the yellow circled screws for the small metal tube. Just disconnecting it from the air pump will do. Pay attention to the metal gasket on that tube and make sure it's there when reassembling.I also removed the braket holding the heater lines to the intake manifold. Also on the passenger side I removed the small valve above the air pump. Probably didn't need to but it made access easier. Took me about an hour.
Fredward is offline   Reply With QuoteReply With Quote
Old 05-29-2018, 08:48 AM #78
renau001 renau001 is offline
renau001 will become famous soon enough renau001 will become famous soon enough
So did you take the air intake box off or were you able to access all the nuts holding down the air pump without doing that?
renau001 is offline   Reply With QuoteReply With Quote
Old 05-30-2018, 05:37 AM #79
Fredward's Avatar
Real Name: Fred
Fredward's Avatar
Real Name: Fred
I took the intake off. The filter box stays. Just the one bolt, the hose clamps at the throttle body and the filter box, a small vacuum line, and a hose (I think it's a pcv hose) and that whole intake piece comes off to give you access to the front coil. It's pretty obvious once you get in there. A little girl could still do it.
Old 05-30-2018, 08:17 AM #80
jwscott79's Avatar
jwscott79 jwscott79 is offline
Real Name: Jason
jwscott79 will become famous soon enough
jwscott79's Avatar
Real Name: Jason
Nice shirt Gracie!!! Go Ravens!!!!!!!
jwscott79 is offline   Reply With QuoteReply With Quote
Old 08-20-2018, 02:49 PM #81
lowcel's Avatar
lowcel lowcel is offline
Real Name: Bruce
lowcel is on a distinguished road
lowcel's Avatar
Real Name: Bruce
Crap. I just made an appointment to get mine changed on Friday. Then I see a beautiful little six year old do the job. My pride just won't let me be outdone, I'm cancelling my appointment.
Thanks for the post Antman.
Audio - Kenwood DNX994S head unit, Helix Pro DSP MK2, Zapco Z150.6 AP and two Z400.2 AP amps, Morel Elate Ti 9 MW's, Audible Physics RG100, RG50, Ram 3a's, Morel Ultimo Ti SC 12" subs.
Non-Audio - Level 8 MK6 wheels, Nitto Terra Grappler G2 285's, Bilstein 5100's set to 2.5" front, 1.5" rear, LED's, 20% tint, Mesh grills, N-Fab bars/steps.
lowcel is offline   Reply With QuoteReply With Quote
Old 08-21-2018, 09:37 AM #82
fsroader's Avatar
fsroader fsroader is offline
fsroader is on a distinguished road
fsroader's Avatar
The current proper procedure for wire tipped plugs calls for NOT regapping and if they have shiny coated threads do NOT use anti-seize. Still a good write-up though.
fsroader is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 02:08 PM #83
RunningFourIt RunningFourIt is offline
RunningFourIt is on a distinguished road
Thanks for posting this tutorial! You did a fantastic job!
I'm going to try this for the first time. I was doing research and saw a lot of people recommending dielectric grease.
Should dielectric grease be used on the ceramic part of the spark plugs?
RunningFourIt is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 02:31 PM #84
I never have before when replacing spark plugs and never had an issue. There will be an audible tactile click that confirm they’re properly mates. It’s not called for in the FSM, so I’d say no.
Old 01-14-2019, 01:50 PM #85
HerT4R's Avatar
HerT4R HerT4R is offline
HerT4R will become famous soon enough
HerT4R's Avatar
Originally Posted by Antman View Post
I'm almost at 115,000 miles.
Our Honda Odyssey has 120,000 miles and last week it suddenly began running rough. One of the plugs actually cracked and the ceramic broke at the electrode. The ceramic was completely gone on one side of the plug- the engine apparently ate it!
Never seen that before but it prompted me to change mine sooner rather than later.
You can see that plug here, at the top of my workbench- it's all black around the bottom...
Attachment 206681
The CEL wasnt on when your Honda started running rough? Just curious as my 4runner is getting a slightly rough idle (only when stopped at a red light and in drive), and I am going to change the plugs asap but I had thought that the CEL would come on for sparkplug issues causing rough idle. I do have 126k on it and no sparkplug change that I know of since 51k when I bought it. Sparkplugs first, and if the rough idle continues its time to check other things but it definitely needs new sparkplugs anyway.
4RUNHER Owner: October 2014-October 2020
SOLD 2010 MGM TE w/ KDSS SOLD
Consolidated Slider Info Thread :: 5th Gen Features/Models/Differences :: New member? Please read this.
HerT4R is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 07:10 PM #86
HerT4R's Avatar
HerT4R's Avatar
completed my sparkplug change out with the guidance of this thread. It went quite quite smoothly, thanks.
The only tip I have is to have some penetrating spray (PB blaster, liquid wrench, etc.) handy. I had just hit 127k on my 4runner (yeah yeah I know I should have changed it out a while ago ) and I started on the rear most passenger side sparkplug and it was TIGHT when I was trying to remove it, it was making the creepy, unsettling creaking binding noise, so I stopped and had a friend bring over some penetrating spray and I sprayed it down in there while I started to work on the next plug. After I got the next coil connector off I went back to trying to unscrew the rear most passenger sparkplug and it broke free with ease, no more creaking or binding. WHEW! Thank you for this writeup.
Thanks @Antman !!!!!
heres to at least 100k more problem free miles!
Old 01-28-2019, 07:15 PM #87
Ghostrider Ghostrider is offline
Ghostrider will become famous soon enough
Is there a reason for not using it?
Ghostrider is offline   Reply With QuoteReply With Quote
Old 01-29-2019, 01:13 PM #88
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
I changed my plugs a little early (82k) because I was worried about them seizing if I waited 9 or 10 years.
They are designed to be used without additional anti-seize.
Here's a quote from NGK: "All NGK Spark Plugs are manufactured with a special trivalent Zinc-chromate shell plating
that is designed to prevent both corrosion and seizure to the cylinder head; Thus eliminating the need
for any thread compounds or lubricants.
Additional Information
NGK recommends only using spark plugs with metal plating on all aluminum head applications to
prevent damage to the head and plug. Metal shell plating acts as a “lubricant” which breaks away from
the main body of the spark plug during removal, preventing damage to the spark plug and or threads in
the cylinder head."
I can't find the offical Denso position, looks like the links are broken.
1000MPH is offline   Reply With QuoteReply With Quote
Old 01-29-2019, 03:15 PM #89
MAXISTYLES's Avatar
MAXISTYLES MAXISTYLES is offline
MAXISTYLES will become famous soon enough
MAXISTYLES's Avatar
Torque
Torque Specs will also be off if you use anti-seize.
MAXISTYLES is offline   Reply With QuoteReply With Quote
Old 04-30-2019, 10:36 AM #90
007Tacoma's Avatar
007Tacoma 007Tacoma is offline
Real Name: Mark the Common Sense Wizard
007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice
007Tacoma's Avatar
Now that Gracie is older, has she shown the Chevy forum how to replace a water pump or a transmission solenoid yet?
This thread is still the best. Gonna be employing my 7 year old to do this in 2 weeks.
I'm 007Tacoma.
...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
007Tacoma is offline   Reply With QuoteReply With Quote
Changed the plugs..Very easy ToolmanJohn Maintenance/Detailing 49 01-30-2016 08:45 PM
Spark Plugs rangermenace 3rd gen T4Rs 19 04-29-2011 06:48 PM
spark plug changes made easy rumme Classic T4Rs 3 04-05-2011 07:27 PM
Only 3 spark plugs? Spencer 3rd gen T4Rs 8 08-18-2009 08:56 PM
pultar pulse plugs (not spark plugs) 3rdgengrog 3rd gen T4Rs 2 11-15-2008 04:44 PM
