Originally Posted by Kent10
Hi All,
I have Bridgestone Dueler Revo 2 LT Load Range E tires on my 2011 4runner.
Years ago, when I purchased the tires I did extensive research and wrote down that I need 46-47 PSI in each tire. I don't remember where and how I got this information. It might have been a chart and using the weight of the 4runner.
Each time I go for a tire rotation, they lower it to 32 PSI and insist this is what it should be. I would only use more air if I am pulling a load.
So, how much air should I put in these tires? I am not pulling anything. Did I misunderstand the amount of air needed for these LT Load E tires?
Thanks very much, Kent
Here's the quick and dirty version. Your truck came with p-rated tires. At 32psi, they have a weight load rating of X. X is ideally matched to the capacity of your 4Runner. When you add LT tires to the 4Runner and run them at 32psi, the load rating for the tires (@32psi) is less than X. To ensure that your load rating is equal or greater than X, you need to inflate them to a higher psi, Y. Y will be determined by the size, brand and model of tire you have. There are a number of different threads on the site that talk, bicker and argue about LT tires and the pressures associated with them. So, to answer your question; most guys with e-rated tires (myself included) stick around the 40-45psi range because your load rating at that pressure is high enough to be considered "safe" and it doesn't make the ride unbearable. If you kit your truck out full expedition style, you'll need to increase the tire pressure accordingly. Hope this helps.
