Originally Posted by Keith_PDX
I thought it was common practice in Toyota vehicles to switch the ground? Only positive wire on the switch is for the illumination. No?
Hi Keith,
That was a dam good question!! You sent me back to the books to find the answer to your inquiry. You're right... most of our circuitry does use the
'Ground-side switching design'! But... the courtesy switch illumination circuits e.g., the Green wire at the switch is hot going into the switches LED, travels through and then grounds at the MB-ECU. Now the trigger circuit is allocated to the GND-side switching design as you have referred to! So there is a
HOT line at ALL of those switches on the dash that are illuminated with the parking light circuit!
...boy you guys are bout to send me back to school lol! Thanks for that question Keith; I've been staring at these diagrams for the last hour just so I could give you a sensible answer!
"Best to you!"
