06-24-2016, 01:33 PM
Where to run cables for solar?
I've tried searching for solar panel installs, but haven't really come across much other than an install on a 3rd gen where they ran the wires through the back, I believe it was. I was a little surprised at my lack of results, as it seems talk of solar panels on our trucks is frequent enough.
Anyhoo, I live in Arizona, where sometimes it gets warm. I also have an ARB fridge, which I've found drains my aux yellow-top battery in about a day or so, since the temp inside the 4R reaches 140-150 during the day. I bought the fridge to have cold drinks anytime, anywhere. Now with my job being only a 2 mile drive, I don't drive enough to keep the battery regularly charged. I was wanting to get a 100W panel to leave on my roof rack to try and keep the battery more charged.
Obviously, the best performance would be by having the shortest distance wires from the panel to the battery. But the wires are 10ga each, and if the 4R exterior panels on the A pillar are anything like the FJ's (from what I remember), I doubt I'd be able to get 2 under there and get the panel back on and looking stock. Am I wrong on that? Or are my only solutions to either go through the back (or maybe through the sharkfin) or otherwise, drill through the roof? I plan on keeping the 4R "forever", so I'm not completely against drilling, although it would be a last resort. Otherwise, does anyone know how much performance of a solar panel might degrade by running the wires to the back of the vehicle and then through the interior into the engine compartment, rather than the much shorter distance of either drilling or going down the A pillar?
Thanks!
05-19-2017, 01:49 PM
Real Name: Curtis
Real Name: Curtis
You might want to check this out for the things you were looking for a good read about this website is they specialize in solar powered equipment. Best of luck dude.
A Green Origin
09-19-2019, 09:38 AM
09-19-2019, 04:02 PM
Thanks for posting the pics
@ jhguth
!! I'm working on this same project currently and your tips are just what I needed.
I'm curious; how did you get the wires through the grommet (ie - make a clean hole without destroying it)? Also, any concerns about it leaking there? Cheers!
2019 T4R TRD ORP Silver | BFG KO2s | RSG Sliders | Rago MSP | SSO Roof Rack | Icon Stage 1 | CBI Steel Skid Plates
2005 UZJ100 LC | 200k miles strong
09-19-2019, 04:22 PM
@ jhguth
I just used a knife and made a small x, it's easy to remove the grommet and there is loads of space through the grommet and in the rubber boot. The hole is at the top so water shouldn't be able to get in and I have a drip loop on the wire, but I also covered with tesa tape to make sure none of the hole is exposed and the wire is loomed.
09-19-2019, 04:44 PM
Excellent. Thanks a million!
09-19-2019, 06:33 PM
2013 T4R SR5 stock 200,000 mile club
09-19-2019, 06:43 PM
Still need to clean up the engine bay wiring and mount the charge controller in its final spot, but i connected everything to test and it's working perfectly
Sent from my SM-G960U using Tapatalk
09-19-2019, 07:33 PM
I did a similar thing. Routed the wires slightly differently but ended up through the grommet. I brought mine down to where the jack is and plug it into my goal zero yeti when I have it in the truck. I also recently wired a chase light and also brought it through the grommet so i could bring it through the cab, through the firewall, to the battery.
Good luck! Its pretty easy overall. I did put some silicone on the grommet just to be safe.
2018 sr5P XP Predator. Needed that 3rd row. TRD Pro susp, Toytec trd pro 2inch lift (HD springs), Gobi stealth, Falken at3w 285s, Trd and rci alum skids, Arb breather, Upper grill light source lightbar, slee sliders, wilco high clearance, arb awning, pedal commander, treaty offroad recovery points, alpha rex pro headlights, trd intake/exhaust, goal zero solar setup, greenlane offroad bumper, warn winch. C4 rear bumper coming...
03-05-2020, 12:48 AM
@ jhguth
- Really like this setup. I have been looking for some examples of solar panels on different roof racks. I was curious how you secured the panel so neatly between the crossbars? Thanks again for the great post and pics.
03-05-2020, 10:12 AM
Originally Posted by ewbox
@ jhguth
I drilled through the side of the LFD crossbars and through the aluminum frame of the panel and used small SS screws to attach them together. When i aligned the holes i set the panel on spacers so that it is slightly recessed, i can still throw lumber or something on the rack without the panel being in the way (although in a couple minutes i could remove the whole assembly of crossbars and panel if i wanted with a single tool)
Only thing that didnt work well were the 3m wire clips to organize the wires under the panel, i think it wasnt real 3m adhesive and some of them have popped off. Need to take it off and and replace a couple with zip ties
Crossbar attachment - Album on Imgur
03-05-2020, 10:48 AM
I run the solar and lighting wires from my RTT down a conduit on the A pillar. Works fantastic.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
03-05-2020, 01:21 PM
I don't permanently mount mine. It's on for trips, off otherwise and stored in my garage. There's no reason I have to leave the wiring in place during driving. I literally just glued the charge controller to the back of the solar panel. So... when I'm parked at camp - I run aligator clips to my battery. When I'm driving - I coil them up and put them in the back.
In generally I think you'll find that you're better served to have solar panels that are not fixed to the roof. If it's hot - you want to park the car in the shade and have the solar panels in the sun. You will typically also want to move the panel orientation through the day to get the best charging. If I didn't already have rigid solar panels for my trailer - I would not buy rigid panels. I would buy a fold up solar setup.
03-05-2020, 01:52 PM
Thanks!
With a 100 watt panel, you could get away with significantly smaller than 10 AWG. Closer to 14 AWG would be adequate for the current generated by that panel.
Keep in mind the panel operating voltage is different than the cars electrical system. You only need to worry about wiring between the panel and the solar charge controller.
Under load from the solar charge controller the panel is usually sitting around 17.5 volts, and at 100 watts that would be approx. 5.7 amps, well within the capability of 14 AWG wire.
I highly recommend getting a nice MPPT controller like the Victron Smart Solar units. I have bought many over the years and these have been the best of the best.
SmartSolar MPPT 75/10, 75/15, 100/15 & 100/20 - Victron Energy
07-08-2020, 09:40 AM
Does anyone have good experience with mounting solar charge controllers in the engine bay? I'm currently trying to find a good MPPT that is weather proof but just wanted to understand the best location for it given the heat inside the bay etc. My current thinking is to mount it on top of the factory fuse box but that space may, in the future, be occupied by S-Pod so I really want to avoid doing that. Any good place on the passenger side?
2019 TRD Off Road| 285x70xR17 Falken WP AT3W| Dobinson C59-314/GS59-700 & C59-505/GS59-701| Total Chaos UCA| RCI front skid plate (steel)| C4 Fab. Low Pro. Bumper| Extreme LED Light Bar (bumper)| Baja Designs Squadron Sport Fog Lights (Amber)| Bud Built Ultimate Rock Sliders| Front Runner slimline II full-size Roof Rack with Wind Fairing| C4 Fab Summit Hatch Ladder| ARB CKMA12 Air Compressor| Xenon Depot HID Low Beam Head Lights|Renogy-20 Amp DC-DC Charger|Battle Born LiFePO4 Auxiliary Battery| Goose Gear rear drawer system (8")|National Luna 52L Legacy Fridge/Freezer| Alu-Cab tilting fridge slide (Small/Medium)| ROAM Adventure 8' Awning
