Old 07-05-2016, 10:42 AM #1
marlinsfan's Avatar
marlinsfan marlinsfan is offline
marlinsfan is on a distinguished road
marlinsfan's Avatar
Techstream help
I bought the cable & software from Fang Fei seller on Amazon last week:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The installation instructions were pretty bad but the seller has been good about communicating back and forth. I installed the v10 software that was on the cd (it actually had several folders with older versions too) and then installed the MVCI driver. I did it while the laptop was not connected to the internet, so no activation key was needed.
I'm running a Windows 7 N Ultimate 32 bit operating system. The software works and when I plug the cable into the OBD port and select Connect to Vehicle, i'm getting an error message that says that it is unable to connect to VIM
Has anyone gotten this error and had it resolved? The seller is now telling me to send it back for a refund, but I'd like to keep trying before I do that.
Thanks.
marlinsfan is offline   Reply With QuoteReply With Quote
Old 07-05-2016, 10:53 AM #2
chitown40's Avatar
chitown40 chitown40 is offline
Real Name: Rob B.
chitown40 is on a distinguished road
chitown40's Avatar
Real Name: Rob B.
I had trouble with version 10 as well, but got version 8 to work very well. Also, make sure you are using a USB 2.0 port if possible. The USB 3.0 ports tend to be flaky with the chinese cables.
2009 GX470 Sport Edition w/ KDSS
chitown40 is offline   Reply With QuoteReply With Quote
Old 07-05-2016, 11:00 AM #3
marlinsfan's Avatar
marlinsfan's Avatar
OK, cool. Will uninstall v10 and try v8.
Old 07-05-2016, 12:26 PM #4
cutty01 cutty01 is offline
cutty01 will become famous soon enough
Please let us know your results. I am interested in buying the same product you did if it works well.
2013 4Runner Limited | OPOR Sliders | BFG KO2 in 275/70R17 on TE Rims |Bilstein 6112/5160s and SAW 1.5" | Some RCI Aluminum Skids | SPOD | Gobi Stealth No-Rise | Aurora 40” and 6” Single Row LED Light Bars
cutty01 is offline   Reply With QuoteReply With Quote
Old 07-05-2016, 02:43 PM #5
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
In older threads about Techstream, guys were using Windows XP because newer versions of windows weren't working. Don't know how true that is now though.
Old 07-05-2016, 02:50 PM #6
jl2222 jl2222 is offline
Real Name: James
jl2222 is on a distinguished road
Real Name: James
I think they fixed the driver issue with it only working on XP. I was able to get it installed on 7.
jl2222 is offline   Reply With QuoteReply With Quote
Old 07-05-2016, 04:32 PM #7
keph13 keph13 is offline
keph13 is on a distinguished road
I bought this one:
It was from a different seller, but it's worked perfectly for me, running version 10 in a Windows XP VM on a Mac host. I've actually installed it twice now, and the second time had to modify an ini file:
How to solve Toyota Techstream ?Software Registration? error ? OBD365.com Official Blog
(Maybe because I was online?)
Not sure how much the sellers differ, though.
2010 4Runner SR5 4x4
keph13 is offline   Reply With QuoteReply With Quote
Old 07-05-2016, 04:58 PM #8
marlinsfan's Avatar
marlinsfan's Avatar
Originally Posted by keph13 View Post
I bought this one:
I have also modified the .ini file without success. Were you getting a resttration error or one you couldn't connect to VIM?
I'm going to delete the software (hopefully tonight), install an XP mode in my Win7 laptop, and install v8 and see how that goes. It may not be tonight, as I have a long honey-do list today, but I'll get to it soon and post back what happens.
Old 07-05-2016, 09:47 PM #9
I was just getting a registration error - everything else worked fine. I could be wrong, but I think that VIM error means it's not talking to the cable properly. if you go into device manager, does it show up/is there an unknown device in there? You might want to look for a different set of drivers online.
Another thing to check - you should get the "device connected" noise when you plug in the cable, independent of connecting to the car (the cable has a USB-Serial interface internally). If that doesn't happen, the cable's likely defective.
Old 07-06-2016, 10:26 AM #10
marlinsfan's Avatar
marlinsfan's Avatar
Made some progress last night, but not a ton. I uninstalled V10 of the Techstream software as well as the MVCI driver. I googled and found the Win7 XP mode, which I downloaded and installed but I could not find it anywhere on the laptop. After much more googling, I found that I also need to install a Windows Virtual PC. I downloaded it, but I have not been able to install it. It gets hung up on 'checking this computer for installed updates'. Sat there for an hour or so. I stopped it, rebooted, and tried again, this time keeping the computer off the internet. It went thru the installation process, but at the end it gave me an error that it was unable to install it. Will try again tonight. If that does not work, i'll just try to install v8 in the Win7 environment and see what happens....
Old 07-07-2016, 09:26 AM #11
marlinsfan's Avatar
marlinsfan's Avatar
I was unable to install the virtual pc software on my laptop. I tried several times and it never got past the 'checking for installed updates on this computer' stage.
So I installed v8 on the Win7 operating system. This time, I booted up the computer with the OBD cable attached to the car via the USB port, and ignition in the off position. When the computer booted up, it installed drivers for the 'new hardware' it found via the USB cable. However, when I launched techstream (with the ignition in the ON position, but the car still turned off), I got the same error that it was unable to connect with VIM.
I also checked the device manager to see if there were any driver issues, and there were 2, but neither were under USB. And both those issues were still there when I turned the car off and unplugged the cable.
Any ideas? I don't think it's a bad cable. Definitely seems like a software or driver issue.
Old 07-07-2016, 09:34 AM #12
Try this Techstream software package recently uploaded by Elusive01. He was running it on Win 7. I am going to buy the cable and try it myself. Make sure you do a clean uninstall of the prior version(s).
Elusive 15 TRDP/SW Build Thread
Old 07-07-2016, 10:18 AM #13
If that doesn't work, I can check how the cable is supposed to show up when I get home tonight.
Old 07-07-2016, 10:57 AM #14
marlinsfan's Avatar
marlinsfan's Avatar
@cutty01 - thanks, I will try that
@keph13 - that would be great if you could tell me. Do you run the software with the engine running? Or just the key in the On position?
Old 07-23-2016, 12:00 PM #15
Hi @marlinsfan , any luck with your Techstream installation?
TOYOTA TIS Techstream emy 5th gen T4Rs 491 08-03-2019 04:42 PM
drl on/off in techstream meanbaby 5th gen T4Rs 5 09-22-2016 05:12 PM
New Techstream Released toyo General Discussions 13 10-15-2015 09:37 AM
TIS TechStream reprogram question MadeInMaine 5th gen T4Rs 3 08-01-2014 03:33 PM
TIS Techstream TRDCal 4th Gen T4Rs 29 07-31-2014 12:58 AM
