08-10-2016, 06:58 PM
Real Name: Owen
Real Name: Owen
UCA install writeup?
I have seen write ups for doing installs for suspension on our 5th gens, but I haven't seen any that include UCA install.
Any help?
Thanks in advance
08-10-2016, 07:01 PM
Here's a video that I watched. I found it to be spot on for the 4Runner, even though it's for a taco.
Anyway, great vid
https://youtu.be/bbsTJgb6S_c
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
08-10-2016, 08:37 PM
Any help?
Thanks in advance
I'm with you. I am going to be by UCA's and I already have a lift installed. I've been wondering how easy just the install of UCA's would be. I also found the video linked above - it looks pretty straightforward.
However, I wonder if you can do the install without removing the coil over and the pressure on the lower control arm. If you can, it sure would be a simple job.
2015 Trail Edition w/ KDSS, Super White, Toytec Ultimate Lift, Airlift Airbags, 255/80/17 Cooper ST Maxx, RCI aluminum skids and bumpout sliders, H9/9011 Headlight Mod, Rear Diff Breather Mod, Homemade Roof Rack, Katzkin leather interior
08-10-2016, 09:02 PM
Real Name: Charles
Real Name: Charles
Yes, I just replaced my UCA bushings and DID NOT remove the coil over. That said, you must take pressure off the UCA by jacking up the LCA, this was somewhat tricky. I had to reposition the jack stands etc as it started to lift the truck up and I was not ok with doing work having it supported by the LCA.
2014 Trail Edition Premium, 285/70/R17 BFG KM2, RadFlo 2.5" Coilovers and Rear Shocks, 50qt ARB Fridge, OTRATTW Switches, BudBuilt Bumpout Sliders, Gobi Rack + Ladder / 40" Rigid E2 /Rotopax and MaxTrax mounted, ARB CKMTA12, 270amp Alternator, Southern Style Slimline Hybrid Front Bumper w/ Warn Zeon 10S and Front Fogs, Metal Oil Canister, Sound Deadening Insulation w/ Focal Front Speakers,Black Weather Tech mats and custom pin striping & dents (the trees & bushes did it for free)
08-10-2016, 09:07 PM
Real Name: Chas M
Real Name: Chas M
07-30-2023, 11:57 AM
This is the first post that came up when I searched asking about UCA Installs.
Thought I’d link my tutorial for anyone else that needs it.
4th & 5th Gen Upper Control Arm UCA Install - Write Up
Hope it helps.
2022 LUNAR ROCK TRAIL SPECIAL EDITION
2010 MAGNETIC GREY SR5 PREMIUM
2004 V6 WHITE 4RUNNER SPORT
1995 V6 3.0 BLACK 4RUNNER 4X4 (Retired)
4th & 5th Gen UCA Install Thread
08-10-2023, 08:03 PM
UCA's are pretty easy to install. Hardest part is getting the long bolt out of the passenger side. Battery comes out so the driver side isn't bad. Here are the instructions off the top of my head:
1. Remove both front wheels / tires.
2. Remove battery
3. Remove brake line retainers from OEM UCA.
3. Disconnect ball joint from knuckle.
4. Pull long bolts out.
5. Reverse these steps to install new UCA's. Use proper torque specs.
6. Get alignment.
SnailTrail4x4 and Tandem Offroad are good YouTube channels.
Sent from my Pixel 7a using Tapatalk
2022 4Runner ORP: Elka 2.5 DC, SPC UCA, 285 Cooper Rugged Trek
08-10-2023, 09:01 PM
never had to remove battery, its annoying though with that long bolt. when reinstalling use grease to hold the washers on or a helper.
