Originally Posted by RedBullGuy
So, they make anti-flicker links for the 2Stroke LEDs; however, they do NOT work for the 4Runner. Do NOT buy them. Installing them causes the LEDs to not work at all, either for DRL or High Beam. Thankfully, TRS was kind enough to let me return the links. I'm just going to deal with the flicker.
They actually do work, but you need to verify polarity of the circuit. Had to swap 3 of 4 of my connectors to make my 2strokes work with the flicker links. The only caveat is that they will be full brightness in drl mode, which is very bright.
I like my 2strokes, but I still want a proper lower output drl (without flicker). Highs are fantastic, but the more often used drl still need some tweaking to be 100%.
I'd honestly consider making a more custom drl and just using the 2strokes for the high beams.
