Old 08-17-2016, 12:16 PM #1
tvcraig tvcraig is offline
tvcraig is on a distinguished road
2013 TE Bad CV?
Hello,
I am just trying to get some help on determining what my problem is before I head to the mechanic (since I don't trust them for the most part). I feel a slight knocking when I turn and brake. Today I got under the 4Runner and could feel an obvious movement, I put video below...any help is appreciated. https://youtu.be/dIg45wtIc10
tvcraig is offline   Reply With QuoteReply With Quote
Old 08-17-2016, 02:16 PM #2
BLACK-FL4RUNNER BLACK-FL4RUNNER is offline
BLACK-FL4RUNNER will become famous soon enough
The cv joint looks tight, but the whole cage rocks in the case.
Are you sure it's snapped all the way in?
2014 Black SR5 4x4 - 285/70/17 Falken M/T, C4Fab Gas Tank Skid, RCI Steel Engine/Trans Skid, Shrockworks Sliders
https://www.youtube.com/user/Locked32114
BLACK-FL4RUNNER is offline   Reply With QuoteReply With Quote
Old 08-17-2016, 09:35 PM #3
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
Originally Posted by tvcraig View Post
Hello,
I just purchased a 2016 july . I did a pretty good inspection under over most all the vehicle .. your front diff axle movement is what I have at 400 miles. now on my 2000 GM silverado 4WD 170K miles there is no movement .
is this normal ? I was going to bring it in myself both side move IMO too much.
catrains is offline   Reply With QuoteReply With Quote
Old 08-18-2016, 12:21 AM #4
wfo9's Avatar
wfo9 wfo9 is offline
wfo9 has a spectacular aura about wfo9 has a spectacular aura about
wfo9's Avatar
Looks like the needle bearings are shot. It's a design flaw by Toyota in the carrier IMHO. Usually causes a vibration in the diff.
There are possible fixes. Search google for Toyota clam shell stub shaft bushing....
I don't know what "normal" play is. My front diff has an ARB carrier and there is 0 play on both sides. But that is comparing apples and oranges.
wfo9 is offline   Reply With QuoteReply With Quote
Old 08-18-2016, 07:22 AM #5
HerT4R's Avatar
HerT4R HerT4R is offline
HerT4R will become famous soon enough
HerT4R's Avatar
is there a fix for this issue?
like replacing the needle bearing with this?
this is the first time i have heard of this. I have a 2010 and dont have the issues the OP describes, but that doesn't mean i wont ever.
4RUNHER Owner: October 2014-October 2020
SOLD 2010 MGM TE w/ KDSS SOLD
Consolidated Slider Info Thread :: 5th Gen Features/Models/Differences :: New member? Please read this.
HerT4R is offline   Reply With QuoteReply With Quote
Old 08-18-2016, 10:31 AM #6
wfo9's Avatar
wfo9's Avatar
The issue I'm talking about is sort of hit or miss, I think. Toyota uses a cast design where the spider gear sits in the carrier (no machining). So there is some play and this puts some additional load on the sub shaft bearing. They can wear out fast depending on how accurate the cast was.
The typical symptom is a roar/vibration/noise from the left side CV. A lift will definitely exacerbate the issue, but it can also happen with stock ride height.
It was a huge problem on Tacomas for a while, but has not been talked about much for 5th gens...So IDK how common it is or if it will be as they age. It is the same diff and carrier. Maybe they revised the casting process at some point... not sure
This video explains the details. The solution is replacing the needle bearings with a bushing that provides a better fit with less wear.
cv joint , trail edition
4wd in 2013 (how to?) Vlaak 5th gen T4Rs 52 02-06-2015 11:43 AM
Another 2013 SR5 with ??? DM4RNR 5th gen T4Rs 10 05-23-2013 12:00 PM
2013 Lone Star Toyota Jamboree May 03-05, 2013 BigRogers T4R Meet Announcements & Info 14 04-02-2013 12:18 AM
2013 sr5 NN4runner 5th gen T4Rs 1 11-21-2012 11:06 PM
