Thread Tools Rating: Thread Rating: 7 votes, 3.71 average. Display Modes
Old 04-04-2021, 01:56 AM #166
Cytronus's Avatar
Cytronus Cytronus is offline
Real Name: Dave
Cytronus will become famous soon enough
Cytronus's Avatar
Real Name: Dave
Mod Stages updated, in progress and futures
Note the new weight in pounds. I've been meticulous about tracking added weight for a couple main reasons - 1) to keep within GVWR to ensure safe handling and braking and 2) to understand the impact of weight on fuel economy. The trailer isn't really a mod but it has gotten some mod attention as well. ;)
Cytronus 2016 4Runner Trail Premium Build Thread (Pic Heavy)-stageupdate_apr2021-jpg
'16 4Runner Trail Premium KDSS | 4.88 | Front E-Locker | ICON Stage 7 Billet 4" Lift | SSO Hybrid front | Warn Zeon 10-S Winch w/ RI 20" LED | Hefty Fab Alu rear dual swingout | White Knuckle Offroad Sliders | Full RCI skids | Dual Battery | ARB Dual Air | sPOD SC | TRD Wheels | 35" Cooper STT Pro | Prinsu full length | KC HiLiTES Flex 40 | OEMAudio+ Reference 500 | Much More
Build Specs, YouTube, FB & IG: https://linktr.ee/FugitiveOffroad
Cytronus is offline   Reply With QuoteReply With Quote
Old 04-04-2021, 04:07 PM #167
Cytronus's Avatar
Real Name: Dave
Cytronus's Avatar
Real Name: Dave
Crazy Air Tank System for running pneumatic impact tools
I had this crazy idea that it would be cool to build an air system off of the twin ARB air compressor with a compressed air tank positioned where the stock spare tire cubby is. The idea was to be able to run air tools long enough to quickly get a wheel off, a stuck nut or bolt on the trail or have enough air in the tank to fill a flat tire in the event the air compressor encountered a failure, which actually happened recently when my sPOD air circuit channel burnt out.
I built this system with a 4 gallon steel pancake air tank all w/ 1/4" NPT, 2 quick connects - one in each rear wheel to easily fill tires from either side, a 1/4" aluminum skid plate mounting into existing frame bolt holes, air/moisture filters and a pressure regulator to dial down the air pressure from the ARB compressor's output of 150 psi to 80-90 psi to run pneumatic tools.
For anyone that's ever thought about something like this, here's what I can say about the system, now that I've had it in for about 3 years - it's heavy and underutilized to warrant the MPG hit. At some point, I will either have a
larger custom aluminum tank made or remove the tank & skid and then simply run an air line from the ARB compressor toward the rear to a 1/4" NPT T joint, running 2 split lines to the current rear wheel well quick connects.
If a custom 8-10 gallon capacity aluminum pancake air tank could be made that would fit snuggly into that spare tire cubby, then I'd say a system like this might be worth it. There are those times on trail when something serious breaks, like a CV, where you or a friend really wants or needs to have a pneumatic impact wrench.
Cytronus 2016 4Runner Trail Premium Build Thread (Pic Heavy)-air-system-plumbing-diagram-jpg  Cytronus 2016 4Runner Trail Premium Build Thread (Pic Heavy)-regulator-jpg  Cytronus 2016 4Runner Trail Premium Build Thread (Pic Heavy)-preinstall1-jpg  Cytronus 2016 4Runner Trail Premium Build Thread (Pic Heavy)-img_8127web-jpg  Cytronus 2016 4Runner Trail Premium Build Thread (Pic Heavy)-img_8574web-jpg  Cytronus 2016 4Runner Trail Premium Build Thread (Pic Heavy)-sideview-jpg  Cytronus 2016 4Runner Trail Premium Build Thread (Pic Heavy)-aircap1-jpg  Cytronus 2016 4Runner Trail Premium Build Thread (Pic Heavy)-air-cap-3-jpg
5th gen , mods , tep , trail premium
Cytronus Build Thread (pic heavy) Cytronus 3rd gen T4Rs 82 07-27-2019 03:42 PM
Balistikboy '14 T4R Trail Premium Build Thread balistikboy 5th gen T4Rs 28 08-14-2016 10:31 AM
DPM's 2016 Trail Build Thread: Kaiju DreadPirateMoyer 5th gen T4Rs 18 04-09-2016 07:25 PM
Txbonds 2016 Trail Premium & 2015 F350 thread txbonds 5th gen T4Rs 17 04-02-2016 08:16 PM
