08-26-2016, 01:36 PM
Real Name: Jeff
Real Name: Jeff
Removal/replacemnet of tail light assembly on 2016 runner
Hey everyone, due to some expert parking I have to replace my passenger side tail light assembly. I would love to do it by myself as I can find replacements for around $120 whereas Toyota wants $270 for just the part. My issue is that I am unable to find any videos or info on how to remove the whole assembly and install the new one. Any help or links would be greatly appreciated!
2016 SR5 Premium 4X4 Magnetic grey, A-TRAC, bluetooth, XM, weather tech, moon roof, running boards, leather seats, OPT7 LED headlights, Lamin-X yellow fog light covers
08-26-2016, 02:12 PM
Real Name: Steve
Real Name: Steve
There are (I think) 2 bolts to loosen from the back side under the access panel. Then you have to push firmly from the back to pop it out. There are pegs that keep it in place pretty snug.
'15 Mag Gray LE -- TOTALED | '14 TE wheels - dipped black, Falken AT3W 285/70/17 | SPC Adjustable UCAs | Daystar 2.5/1.5 top spacer lift | RCI Fuel Tank Skid (Steel) | Shrockworks Step Sliders (trimmed LE Rocker Trim) | SR5 front end conversion
'08 BP Urban Runner -- 5100 fronts at .85 with Toytec 620# springs | SPC Adjustable UCAs | Plastics Guy Front Bump Stops | ICON VS 2.0 Rear with Toytec Superflex 2 inch springs | RCI Transition, Front and Transmission Steel Skid | LT275/65/18 Falken Wildpeak A/T3W | 1.25 inch wheels spacers
www.4runnerfamily.com | IG: Runn4est
08-26-2016, 02:25 PM
there are a couple of nuts then you pull straight out the rear . plastic clips hold it in place which have fingers to keep it secure .
$120 sounds right on the price. spray some soapy water around the fixture outside so it may slide easier.
08-26-2016, 02:56 PM
Real Name: Jeff
Real Name: Jeff
Thanks for the help! Ordered and on it's way. I will take pictures of the before, install and after if that is beneficial at all.
08-27-2016, 03:31 AM
Yep only 2 nuts to remove that are behind the trim panel...but...the hard part is pulling the assembly away from the quarter panel. I would describe removing the assembly as more like yanking the head off a gator...I tried for about 2 hours thinking that I would break something....please use gotta rip em off...
08-27-2016, 08:26 AM
Here's a video showing how to remove the tail lights. You do have to pull firmly.
http://youtu.be/ixRhoT70P0s
2016 4Runner Trail Edition (the DD)
1999 F250 Superduty (the tow rig)
1969 Mustang fastback ( the fast car)
09-01-2016, 08:47 AM
Real Name: Jeff
Real Name: Jeff
Originally Posted by Stangboy
Thanks! Looks like he removed the white plastic clips prior to the video. I am assuming those are what require the extra force to remove the assembly. The new tail light came yesterday so I will hopefully get it installed (with pictures) today if I have time after work.
09-01-2016, 09:10 AM
Good luck! That's quite a price difference between your cost and the dealer cost.
09-01-2016, 09:33 AM
The $120 ones are probably aftermarket TYC lights.
09-01-2016, 09:41 AM
Real Name: Jeff
Real Name: Jeff
Yes, they are TYC. They are a perfect match and feel and look very high quality. Reviews were great as well. Hopefully they continue to impress once connected.
09-01-2016, 12:37 PM
Real Name: W
Real Name: W
I have 2014+ TYC's on my 2011 and have nothing bad to say about them.
2011 SR5 4Runner Blizzard Pearl Tan Leather
2014+ Taillights
Black TRD rims
DBA 4k rotors with red TRD pads
09-01-2016, 01:04 PM
Real Name: Jeff
Real Name: Jeff
Good to hear! Pictures of the busted light and replacement. Dunno why they are sideways but you get the idea.
09-01-2016, 04:05 PM
I have them on my truck as well. I was just stating that I doubt for $120 they were OEM.
They are a great match, however, I've received two that started getting water into them. Both were passenger side. My driver side has been great. I'm waiting for my third passenger side to come in the mail. The second time I put a bead of silocone around the opening when I installed it and it still got A LOT of water in it. Fingers crossed third times a charm.
I know some OEM lights had this problem too.
09-01-2016, 04:15 PM
Real Name: Jeff
Real Name: Jeff
That's good to know as well! I will keep a close eye on them after the install. Hopefully they will be fine otherwise I guess I will bite the bullet and get from dealership. Although it sounds like those may leak as well. Stupid reckless pole
09-01-2016, 08:49 PM
I find it best to "firmly" strike them. It does take some force to get those clips to release.
