Originally Posted by AnthonyMV
Old post resurrection
Mr Brennan :
Did an eernternet searchy and found your review. Couldn’t really find any other review.... besides a northstar review... looks like my 2012 is (probably preemptive) gonna need a new battery soon....
How’s the odyssey battery holding up ?
I’ll more than likely make the purchase based on your answer..... needs that $12 space too? Yes ?
I don't have a long term review to help you out but: yes you will need the spacer. I have had the Odyssey for about 6 months and it has seen -30 to 100+ F temperatures and runs strong. You will also need to buy a voltage booster as the oem charging voltage is not sufficient and you will kill an AGM battery quickly without it. If you are looking for a good, simple OEM replacement, buy a higher-end normal lead acid type or the same panasonic OEM.
