Old 09-30-2016, 12:12 PM #1
cryption1's Avatar
cryption1 cryption1 is offline
cryption1 is on a distinguished road
cryption1's Avatar
MTS / offorad Settings for deep sand
Friends,
I'll be going to do the Matagorda, TX Seashore tomorrow. 30 miles of beach driving, fishing, and fun. I've been trying to figure outt exacttly what settings to use on my 4x4, and looking for some deep sand experience.
My plan was 4lo with MTS in the Mud, Sand, Dirt setting. If I get stuck, I can use A-TRAC instead, and lock the rear diff, and if that doesn't work I can use crawl control to work my way out.
My understanding is A-TRAC works like MTS on the highest setting, and stops wheel slippage more. Having the MTS in sand will allow for a little more wheel spin.
Does that sound like a good plan to everyone? It's my first time with a system like this.
cryption1 is offline   Reply With QuoteReply With Quote
Old 09-30-2016, 12:19 PM #2
mace.'s Avatar
mace. mace. is offline
mace. is on a distinguished road
mace.'s Avatar
4hi and 18 psi in the tires. Bring a shovel and a board to place under your jack.
mace. is offline   Reply With QuoteReply With Quote
Old 09-30-2016, 12:30 PM #3
cryption1's Avatar
cryption1's Avatar
4hi would work better then 4lo in this instance?
Old 09-30-2016, 12:35 PM #4
SecretSquirrel's Avatar
SecretSquirrel SecretSquirrel is offline
SecretSquirrel is on a distinguished road
You should be fine in Matty in 4hi all the way past the shell banks.
Go try all the settings out and get a feel for what they do.
Sent from my XT1585 using Tapatalk
Builds:
The Yeti
Bleu
SecretSquirrel is offline   Reply With QuoteReply With Quote
Old 09-30-2016, 12:38 PM #5
cryption1's Avatar
cryption1's Avatar
I was going to take 2031 to beach road, and just head east when it dead ends off the sand. I've never been out there before, anything in particular I should look out for? I've been looking at it on google earth satellite and it looks like there are a bunch of trails and stuff that go through the dunes.
Old 09-30-2016, 12:39 PM #6
e60ral e60ral is offline
Banned
e60ral is on a distinguished road
Banned
generally yeah, 4-hi
if the sand is sufficiently deep and soft enough that you don't get movement until you get a lot of revs then all the sudden your wheels spin, then you might want 4-lo to better control your torque output. If you do find yourself in that situation you have to go easy or the extra torque from 4-lo will just bury you. basically, always use the highest gear you can.
i use MTS-sand, a-trac could be too agressive
e60ral is offline   Reply With QuoteReply With Quote
Old 09-30-2016, 12:41 PM #7
cryption1's Avatar
cryption1's Avatar
Will MTS work in 4hi? I was under the impression it would only work in low range.
Part of this journey is the first time I'll get to go offroad and learn how all this stuff works so thanks for humoring my stupid questions.
Old 09-30-2016, 12:47 PM #8
1engineer's Avatar
1engineer 1engineer is offline
Moderator
Real Name: Greg
1engineer is a jewel in the rough 1engineer is a jewel in the rough 1engineer is a jewel in the rough 1engineer is a jewel in the rough
Moderator
1engineer's Avatar
Real Name: Greg
You can play around with all the settings and see what each does. In reality for most beach sand is drop the tire pressure, put it in 4HI and go. It's not complicated.
1engineer is offline   Reply With QuoteReply With Quote
Old 09-30-2016, 12:50 PM #9
Muzzle of Bees Muzzle of Bees is offline
Muzzle of Bees will become famous soon enough
MTS works in 4HI too.
2016 TEP
Muzzle of Bees is offline   Reply With QuoteReply With Quote
Old 09-30-2016, 01:00 PM #10
Banned
Banned
it will
RTFM
look at the chart on page 254
Mud&sand can be activated in 4hi or 4lo, the others are 4lo
you must be going < 7mph to activate
Old 09-30-2016, 01:13 PM #11
Salvo Jimmy's Avatar
Salvo Jimmy Salvo Jimmy is offline
Real Name: Ted A Hamilton
Salvo Jimmy will become famous soon enough Salvo Jimmy will become famous soon enough
What he says. Been driving Bodie, Hatteras and Ocracoke Islands beaches in NC for decades and almost never need 4LO. The real key is to air down to about 18-20 psi depending on load.
Ted A. Hamilton
(aka Salvo Jimmy)
Salvo NC / Hampton VA
2016 SR5 4WD 3rd Row Seat
Only MOD. Curt 31367 front hitch receiver.
Salvo Jimmy is offline   Reply With QuoteReply With Quote
Old 09-30-2016, 01:18 PM #12
Nothing really to worry about, except to watch out back in the dunes and bayside trails. The ground can be deceiving and you could end up frame deep in soft mud in the blink of an eye. (Take recovery gear)
Watch where you walk back on the dunes as well - I've seen a few rattlers back there.
Builds:
The Yeti
Bleu
Old 09-30-2016, 01:18 PM #13
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a jewel in the rough BobsTrail is a jewel in the rough BobsTrail is a jewel in the rough BobsTrail is a jewel in the rough
BobsTrail's Avatar
Real Name: BobH
Sand is a good place to try the other settings as stated above.
I use MTS and 4 Low in the soft stuff to reduce the engine load. I usually air down to 15 and avoid quick or sharp turns. When I use the locker in sand it feels like it causes more slip and on a side incline I have had it cause the rear to slide sideways so I leave it off most of the time.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 09-30-2016, 01:21 PM #14
Banned
Banned
If you are travelling with a group, intentionally get yourself good and stuck and then see if crawl control walks you out of it and then post the video
I've been waiting for winter when the beach is quiet so i can try it out myself without causing a traffic jam for annoying rednecks on squatted trucks run LED bars during the daytime
Old 09-30-2016, 01:27 PM #15
This thread on another board might help you out
Driving in the Sand Info | OBX Connection Message Board
Ted A. Hamilton
(aka Salvo Jimmy)
how deep can you go?? TC2002SE 3rd gen T4Rs 25 04-18-2014 10:46 PM
Toe settings Tooltime19 4th Gen T4Rs 4 12-12-2013 03:42 AM
Straddlin' deep (deep enough) gully TNations7 4th Gen T4Rs 5 11-17-2013 03:50 AM
How Deep? greyghost4x4 3rd gen T4Rs 14 03-16-2008 11:10 AM
How Deep? lojeff 4th Gen T4Rs 19 08-25-2007 04:08 PM
