Originally Posted by salong53
As far as comparing the 4wd systems, they're all essentially the same between the 4Runner, Tacoma, and Tundra unless you go for the limited 4Runner. Body on frame design with the ability to lock the center differential. The Tacoma and 4Runner might actually be better in the mud because they weigh less. The Tundra on the other hand would have no problem hauling your ATV in the bed. You could throw your harvest in the bed of a truck if you went that route, but the 4Runner has a lot more weather-protected cargo space. I definitely think 4wd would benefit you, but I'd suggest test driving each of the three to determine which truck is your best option.
I'd say the 4WD system in the Tacoma and the 4Runner are a bit more complete than in a Tundra. Tundra has no rear locker and none of the electro-nannies the Trail has.
OP, if I was in your boat I would seriously consider a Tacoma. I'd say 4Runner but where do you put what you catch? You can't go wrong with any of the above really.
If you want to keep your rig now, add a selectable locker and a winch up front. Mild lift, M/T tires and you can get in plenty of trouble.
