Old 10-23-2016, 10:52 AM #1
Hugo Stiglitz's Avatar
Hugo Stiglitz Hugo Stiglitz is offline
Hugo Stiglitz is on a distinguished road
One more Bilstein 5100 front lift, 0 rear lift question.
Over the last 2 weeks I have read and searched every bilstein thread I can find.
I have not seen anyone post pre lift measurements of ground to top of wheel well in the FRONT and BACK of the 4Runner.
First Q, How much lift do you usually get on the front with the 1.75" slot?
My 16 TEP sits stock at 36.5" at the Rear, 34" at the Front (If I don't get more than 2" at the front it seems the 1.75 may work for me)
I have KDSS so I am trying to get this right the first time. I don't want to lift the rear, only the front in hopes of having a little bit of rake and close to level.
I know from reading 1.75 has put a lot of rigs here with a tad of negative rake, hence my question (about pre measurements of front and rear).... what actual lift is the 1.75" bilstein notch yielding?
And has anyone documented this particular lift (front only) with PRE front and rear measurements and then POST front and rear measurements?
It seems, if I go the 1.75, I should still have slight rake, maybe dead on level.
If anyone has documented the Pre and Post ground to fender well measurements and also documented what measurements the bilsteins have yielded afterward it would greatly help in my decision making.
There are many pics of end results of the lifts but few measurement pics of before and after. Sorry for long winded question but I was trying to explain my needs as best I could.
Thanks in advance everyone
2016 4R TEP KDSS
TRDP Wheels, AT2's, Billy 5100's, TRDP Front grill etc weathertechs n more
Is it me or did this trip start going downhill after we ran out of Lucky Lager....?
Hugo Stiglitz is offline   Reply With QuoteReply With Quote
Old 10-23-2016, 11:53 AM #2
3wbdriver's Avatar
3wbdriver 3wbdriver is offline
Real Name: CJ
3wbdriver will become famous soon enough
3wbdriver's Avatar
Real Name: CJ
When I put in my initial 1.75 front 0 rear setup I ended up with 36 3/4" at the front and 36 3/4" at the rear fenders. But my frame had a slight (~1/4 - 1/2") reverse rake. So my setup with factory springs actually yielded 1.75" on each front corner.
The 0.85" setting is the one that actually still leaves you with a slight forward rake, and is considered leveled when unloaded.
2014 Trail Edition -
Build Thread
2015 Epic in my own mind trip
3wbdriver is offline   Reply With QuoteReply With Quote
Old 10-23-2016, 12:04 PM #3
Thanks for measurements! Do you know what your front measurements was prior to lift the front end?
2016 4R TEP KDSS
Old 10-23-2016, 12:06 PM #4
3wbdriver's Avatar
Real Name: CJ
3wbdriver's Avatar
Real Name: CJ
I didn't measure my actual vehicle before, but I did measure a Limited that was parked in the same hotel the weekend we got the SSO bumper installed. It pretty much matched what you posted above.
Build Thread
Old 10-23-2016, 12:10 PM #5
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
No measurements but -- 0.85 and stock in the rear looks like this. 1.75 without a 1 inch spacer may look tail low with a load.
One more Bilstein 5100 front lift, 0 rear lift question.-085-jpg
BobsTrail is offline   Reply With QuoteReply With Quote
Old 10-23-2016, 12:10 PM #6
mybabydaddy's Avatar
mybabydaddy mybabydaddy is offline
mybabydaddy is on a distinguished road
Sorry... I don’t think I ever posted this info... Probably should have. Here ya go:
2014 TEP w/ KDSS
Pre-Lift (measured using top of wheel wells)
DF - 34 inches
DR - just shy of 37 inches
PF - just shy of 34 inches
PR - 36 inches
...as you can see, I had a nice “KDSS Lean” going on, lol.
POST 5100 install with ONLY 1.75 Front setting (nothing in rear), measured using wheel wells):
DF - 36 inches
PF - just over 35.5 inches
PR - 36 1/4 inches
POST 5100 install with ONLY 1.75 front setting (nothing in rear), MEASURED USING FRAME:
DF closest to tire = roughly 14.5 inches
DR closest to tire = just shy of 14.5 inches
PF closest to tire = 14 inches
PR closest to tire = 1/16 shy of 14 inches
REMEMBER - All trucks vary a little, and none truly “sit” the same pre or post lift.... but ROUGHLY you can expect the following with 1.75 setting up front and nothing added to the rear: about a 1/4 inch NEGATIVE frame rake front to back... But your wheel wells will look pretty much level (more or less).
This is NOT what I am currently running; I have since added 1 inch rear spacers to give me a hint of rake back (which I prefer/like)... plus, now the entire truck has a small lift (which I like as well).
Hope this helps.
2017 Porsche Macan GTS - Carmine Red w/ matching side blades
2014 Black TEP w/ KDSS / nFab steps / Yakima Cross Bars / Bilstein 5100s (front at 1.75) / 1 inch rear Cornfed Spacers / FN Countersteer Type X / Nitto Terra Grappler G2s 265/70/R17 / RCI Aluminum (front) Skid - sold
2011 Silver Limited - sold
2007 SE Shadow Mica - sold
mybabydaddy is offline   Reply With QuoteReply With Quote
Old 10-23-2016, 12:15 PM #7
Wow guys, thanks! Already great info I needed. I thought I'd actually get flamed a tad, lol, but I've seriously searched and searched.
I plan on installing my bilsteins tomorrow morning. Hopefully all goes well. I will post back up.
Thanks again!
2014 TEP w/ KDSS
DF - 34 inches
PR - 36 inches
DF - 36 inches
PR - 36 1/4 inches
Hope this helps.
2016 4R TEP KDSS
Old 10-23-2016, 12:21 PM #8
This looks like what I am wanting to achieve.
Looks like the .85 will save me a lot of mental anguish (OCD) and staring at the 4R and convincing myself the 1/4" negative rake is a bad thing lol
2016 4R TEP KDSS
Old 10-23-2016, 12:22 PM #9
If anyone else info IRT my original post - please keep posting up.
I will return the favor of you guys helping me out by posting all PRE/POST measurements
Thanks again
2016 4R TEP KDSS
Old 10-23-2016, 12:32 PM #10
For the Record
My 2016 TEP
PRE Lift Measurements
DF - 34'
PF - 34 1/8"
DR - 36.5"
PR - 36 3/4"
2016 4R TEP KDSS
Old 10-23-2016, 01:16 PM #11
gbarr gbarr is offline
gbarr is on a distinguished road
Hope you read this before you install 5100's.On my SR5 2014 I installed 5100's in the front set at the 1st notch up from stock which should have been a raise of .85 inches and the rears with no spacers. This setup actually raised the front exactly 1.25 inches and the rear remained the same as before.I know yours is a trail and mine was an SR5, so you could end up with some reverse rake which I think is a terrible look, you may be ok with this. I was really glad I did not ose the 1.5 notch. I know they all different but??????
gbarr is offline   Reply With QuoteReply With Quote
Old 10-23-2016, 02:09 PM #12
I'm with you. Cannot stand negative rake. Even a little drives me insane. I have read a lot and it does seem the .85 gets a little over an inch. So I'm going to roll the dice and just do the .85 notch and hope she looks good.
I'm a good 2.5" difference now as she sits. That's why I've been trying to decide.
2016 4R TEP KDSS
Old 10-23-2016, 02:20 PM #13
TRDfan2011's Avatar
TRDfan2011 TRDfan2011 is offline
TRDfan2011 is on a distinguished road
TRDfan2011's Avatar
Nice stance! That's the look I'm llooking for on my 2011 SR5.
TRDfan2011 is offline   Reply With QuoteReply With Quote
Old 10-23-2016, 02:27 PM #14
karmatp karmatp is offline
karmatp is on a distinguished road
You will be happy with .85, which will give you 1" lift, maybe a tad more. That is what I did and it is perfect. 1.75 will give you reverse frame rack unloaded, loaded rear and it just looks silly.
If you go 1.75, you need to add a 1" rear spacer to not look odd driving down the road.
karmatp is offline   Reply With QuoteReply With Quote
Old 10-23-2016, 02:28 PM #15
Thanks for the input!
2016 4R TEP KDSS
Urgent: >2" rear lift with Bilstein 5100's 07V8 4th Gen T4Rs 1 07-23-2015 01:31 AM
Lift question: Bilstein 5100 and rear spacer bob3dsf 4th Gen T4Rs 2 06-09-2015 08:50 AM
Bilstein 5100 lift question ProfessorChaos 4th Gen T4Rs 3 03-23-2015 10:22 AM
Question on Bilstein 5100 front lift for 05 SR5 Z man 4th Gen T4Rs 1 05-14-2013 06:50 PM
Help! Bilstein 5100 with > 2 inches of rear lift childsusn 5th gen T4Rs 5 07-25-2012 10:16 PM
