Originally Posted by ForeRunnerSi
I recently purchased a used 2011 4Runner w/o nav or jbl. I've come to discover that the drivers side rear door and rear hatch speakers were not working. Through a quick visual inspection I found out the previous owner replaced the rear hatch speakers with some infinity kappa 652.9i. The driver side hatch speaker wires broken off from the solder connection.
Hi ForeRunnerSi,
The reason that you had no speaker operation at the rear doors and tailgate is because the tailgate and rear doors are wired
IN-SERIES; much like a string of Christmas lights with one bad bulb; they are all dependent upon all bulbs to work! When your
'Party-mode' feature is off, ALL rear speakers are in series. When you have the
'Party-mode' system activated, that system disconnects the rear door speakers and uses ONLY the tailgate speakers; that should explain why you had no rear speaker operation! If you reconnect the tailgate speakers, they will all be operative!
"...Anyways they used a speaker adapter for the speakers on the rear hatch but only one hole lines up and they drilled 4 others to make them fit. Anyone know of an adapter that fits the factory mounting pattern?"
Here's what you can do about fitting all of your aftermarket speaker choices:
Metra speaker mounting kits Just type in the vehicle year and model and they will provide you the model number that fits your truck (cost: around &20 bucks/pair)! Here (Below) is the kit that I used for my front door adapters:
"the alpine 1" dash component review" and here's a tutorial that explains just how the party mode works:
The "Party mode" tweak! (non JBL) 'Best to you'
rig
